Mighty Stripes
Old Jan 31st, 2007, 10:02 PM   #21
MrMini748
DU07 OHO
MrMini748's Avatar
Local Time: 07:58 AM
Send a message via ICQ to MrMini748 Send a message via MSN to MrMini748 Send a message via Yahoo to MrMini748
How long before someone puts a noisy dump valve on the R56's turbo... any bets? :P
Old Jan 31st, 2007, 10:36 PM   #22 (permalink)
dsakko
dsakko's Avatar
Local Time: 04:28 PM
NOOOOOO! NOT A FLANGE!!!!!!!!
Whoa! Sorry - just woke up from a nightmare....
Looking at that second photo brings back some repressed memories of the Classic Mini exhausts. Anyone who's had one with the stock cast manifold knows what I'm talking about...
Feb 02 R50 6sp Getrag, JCW brakes, Superchips ECU, Green filter, SuperSprint exhaust, ProMINI Brace, Fidanza flywheel, XTreme Clutch, Cobalt sump guard. 128dB stereo.
Australia View dsakko's British Racing Green & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 31st, 2007, 11:07 PM   #23 (permalink)
bugiz
R56 Nut
bugiz's Avatar
Local Time: 04:58 PM
yea... read the same review... they say it's by Garrett.. they can't be wrong..
the GTi and the Volvo C30 T5 uses the KKK while theR56 uses Garrett.. according to them
Australia Male View bugiz's Sparkling Silver & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Feb 1st, 2007, 12:12 AM   #24 (permalink)
Ryephile
Deals Gap Junkie
Ryephile's Avatar
Local Time: 02:58 AM
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
It's the same article they say in the specs that the GTI is running 26.1psi of boost, and the R56 has electrohydraulic steering; the first of which is not likely, the second of which is totally false. Not a credible write-up in the technical accuracy department.
United States View Ryephile's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 1st, 2007, 09:08 AM   #25 (permalink)
msh441
msh441's Avatar
Local Time: 11:58 PM
Yeah. That was the very article that made me want to ask the question again...
...I was hoping by now someone in Europe would have taken a close enough look at the turbo and pulled the part number off it (or better yet seen the word "Garrett" or somthing printed on the side), or spoken with their local parts guy to correctly determine the manufacturer.
Founding member of R56 Anonymous: "Hello. My name is Mike. I'm a driving enthusiast... and I still like the R56"
United States Male View msh441's Dark Silver & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Feb 12th, 2007, 11:11 AM   #26 (permalink)
AlexF2003
AFRacing
AlexF2003's Avatar
Send a message via MSN to AlexF2003
The turbo I have seen is a KKK unit!
The numbers are:
grosse/Kunds-NR : 75556970-03
Lader-NR : HK7310010225 008
Ausf-NR : 5303 950 0073
You might be surprised how the waste gate is controlled... its not boost that opens the valve! Vacuum is used to hold it shut as naturally its sprung open.
Alex
Alex F - AFRacing LTD
United Kingdom Male View AlexF2003's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 13th, 2007, 08:54 AM   #27 (permalink)
Maaij
Local Time: 06:58 AM
The turbo is a Garrett: 11:6-psi (13:8-psi overboost)
Netherlands   Reply With Quote
Old Feb 13th, 2007, 01:14 PM   #28 (permalink)
AlexF2003
AFRacing
AlexF2003's Avatar
Not calling you wrong but the engine I have stripped is a BW KKK!!
So unless they are using 2 suppliers one of us is wrong!
Where have you seen the Garrett? on your car? at BMW group academt UK?
Alex
Old Feb 13th, 2007, 02:15 PM   #29 (permalink)
Ryephile
Deals Gap Junkie
Ryephile's Avatar
From the pictures I've seen, the turbo looks to be a Borg Warner, like AlexF2003 says.
--->AlexF2003: Have you taken any measurements of the turbo itself? [inducer and exducer diameters for compressor and turbine wheels; housing A/R's?]
Old Feb 13th, 2007, 04:19 PM   #30 (permalink)
Maaij
@AlexF2003, first I must say I have zero experience with turbo motors.
I only read it @motoringfile:
MotoringFile » Archive » MotoringFile 2007 MINI Q&A: The Answers
Reader: msh441; Who makes the turbo for the R56S MINI/PSA engine? Model or part number?
MF: Garrett: 11:6-psi (13:8-psi overboost)
Old Feb 13th, 2007, 08:02 PM   #31 (permalink)
AlexF2003
AFRacing
AlexF2003's Avatar
arr ok Maaij ! - I was hoping you'd seen a few - I've only seen two and only 1 in detail and that engine is a fairly early one
"Have you taken any measurements of the turbo itself? [inducer and exducer diameters for compressor and turbine wheels; housing A/R's?]"
nope - but I can do if you like... there doesn't seem to be any AR info on the outer casing but thats not that uncommon.
Alex
Last edited by AlexF2003 : Feb 13th, 2007 at 08:03 PM. Reason: didnt say what I meant to 1st attempt!
Old Feb 19th, 2007, 06:43 AM   #32 (permalink)
msh441
msh441's Avatar
Yes... and I kinda think MotoringFile (as reliable as they are) are just repeating what Winding Road stated.
It wouldn't be completely unheard of to have a couple different manufacturers for the same PSA twin scroll design. I just was hoping for some hard factual info backed up by part numbers and such (Thanks AlexF2003). Before I would even consider any type of tuning or add ons for the new car I want to know what's on there as stock.
Old Feb 19th, 2007, 12:15 PM   #33 (permalink)
gabe
gabe's Avatar
Local Time: 01:58 AM
I believe it's a Borg Warner KKK from what I remember from the official R56 launch event. The Garrett thing was told to me by someone also at the event and then was in Winding Road. However I'm pretty sure that is incorrect.
United States View gabe's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 27th, 2007, 06:37 AM   #34 (permalink)
msh441
msh441's Avatar
Yep.
3-for-3 of the R56S cars I've seen this week were clearly badged as KKK units.
MotoringFile and Winding Road are indead incorrect unless MINI is getting them from multiple suppliers.
Old Mar 6th, 2007, 10:32 AM   #35 (permalink)
AlexF2003
AFRacing
AlexF2003's Avatar
The diesel lump has a garrett... could that be the misunderstanding?!
BMW win design awards for Coffee Maker, Kids Bike, MINI and more! Paul General Discussion 5 Jun 28th, 2007 12:18 AM
Turbo baraboab MINI One 17 Oct 16th, 2006 06:21 PM
Uk Number Plates Maker brett UK & Ireland Discussion & Event Planning 2 Jun 26th, 2005 08:05 PM
Your chance to see everyone's favorite film-maker, Kevin Smith, LIVE in the UK!!! DemonMF777 UK & Ireland Discussion & Event Planning 0 May 28th, 2004 04:34 PM
