Old Jan 24th, 2007, 02:30 PM   #61
Griffer
Now Cooper D Clubman
Local Time: 07:17 AM
The Sport button does make a noticeable difference to the steering and the pick up of the engine under hard acceleration but does improve the MPG when cruising on the motorway when switched off. Well worth having. The old MCS was permanently in "sport" mode and as a result drank like a fish. I have got 36 to 40 MPG out my R56 MCS compared to 18 to 28 in my MCSC.
England Male View Griffer's Pure Silver & Black 2nd Gen MINI Cooper Diesel Clubman Profile   Reply With Quote
Old Jan 25th, 2007, 12:58 AM   #62 (permalink)
Ryephile
Deals Gap Junkie
Ryephile's Avatar
Local Time: 03:17 AM
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
That's an impressive delta Griffer! Are you driving the R56 easier to help those fuel economy figures?
United States View Ryephile's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 28th, 2007, 09:39 PM   #63 (permalink)
Lardy Lambert
Lardy Lambert
Lardy Lambert's Avatar
Local Time: 08:17 AM
The reason the old MCS had bad FUEL consumption had little to do with throttle responce.
i drive with the sports botton on all the time because i hate a sloppy throttle and i get the same MPG as you. The new MCS engine has been built with economy in mind and is more economical
than my old MC which is amazing.
Old Feb 15th, 2007, 03:14 PM   #64 (permalink)
NickyG
Hello all, people seem to have sorted this out now but yeah, the sport button just alters the steering and throttle response! All it basically means throttle wise is that with the sport button on, you don't have to press the accelerator pedal down as far to get the same opening on the throttle butterfly! It just makes it more sensitive, no more power or anything. I think it's a good idea though as when it comes to driving in traffic / parking etc you may want the sport button off, if it's on all the time it's a bit more difficult to drive smoothly.
Someone mentioned about the Astra VXR... I test drove one last weekend and that was difficult to drive smoothly all the time, with the sport button on, it was even more sensitive but you'd just get used to it. That sport button also doubled as a button for turning off the traction control / esp. If you held it down for 3 or 4 seconds it turned it off. On reading the brochure I think you could have an option that in controlled suspension stiffness also, not sure if it's the same method but on top gear I saw some car (can't remember what it was) that when you pressed a button it turned on electromagnets in the dampers and moved iron filings that are inside, changing the damping!
The guy that sat in when I test drove the VXR also said that one of his mates has courtney tuned one that when the sports button is on also activates the remap, therefore he has something like 300bhp with it on and the standard 240 with it off, so that's a good idea!
2002 BMW 330 Ci Sport with M Sport Pack - soon to be 2008 Mini Cooper Diesel
1990 Ford Escort RS Turbo
Old Apr 2nd, 2007, 04:59 AM   #65 (permalink)
naruto16
naruto16's Avatar
Send a message via MSN to naruto16
Canada
Quote: Originally Posted by OneDriver (original)
This might be me not knowing enough about things... but if the sport button is wired directly to the ECU to change its mapping... won't this make blue finning in the future more difficult? or can superchips overcome variable maps like that?
Just a thought...
actually... if that's the way the sport button works, then it would be fun~ say they figure out everything in the ECU, they could let the non-sport mode be stock, and when u press the sport button u go into ULTRASPORT MODE(the remapped map!).
That would turn it into a true "M" button!
Cheetahs are pussies! Next to the Cooper SSSSSSSS
Canada   Reply With Quote
Old Apr 2nd, 2007, 08:12 AM   #66 (permalink)
moog5
moog5's Avatar
Local Time: 09:17 AM
So, for the slightly less bright among us (by which I mean me!), what are we actually saying here?
- In traffic, parking, and motorways: Sport Button OFF
- Twisty B roads, not much traffic, when you want to play - Sport Button ON
Is that right?
Old Apr 2nd, 2007, 08:50 AM   #67 (permalink)
devaisl
devaisl's Avatar
Yep
Lovin' the sports button on the country roads round here....
Ireland Female View devaisl's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
MCA + sport button performance? C&A's Mini 2nd Gen MINI Cooper 2 May 11th, 2007 09:12 PM
can sport button ... mph999 2nd Gen MINI Cooper 0 Apr 4th, 2007 10:43 PM
Sport button Sowellman 2nd Gen MINI Cooper 0 Feb 13th, 2007 11:40 PM
Sport Button Telboy81 2nd Gen MINI Cooper S 7 Nov 30th, 2006 07:32 PM
Difference in ride height between Sport Suspension and Sport Suspension Plus ? GUSS Suspension 0 Jun 20th, 2005 07:28 PM
