Mighty Stripes
Old Oct 13th, 2007, 09:12 AM   #1
Bombers_son
Local Time: 07:23 PM
England What exhaust to use
People im looking at buying the Alta full exhaust system and the miltek catalytic converter down pipe,
would this be a sensible buy ??
Feed back would be welcome
This for the new turbo'd cooper s
Last edited by Bombers_son : Oct 13th, 2007 at 10:09 AM. Reason: mention of model mini
Old Oct 13th, 2007, 05:36 PM   #2 (permalink)
Keegan141
Local Time: 10:23 AM
I bought the Miltek system and am having CEL problems due to the downpipe. I wouldn't buy the downpipe if I were you.
Old Oct 13th, 2007, 05:46 PM   #3 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
Hello,
Do you mean the manifold when you say down pipe?
If so then the reason you have CEL lights coming on is due to the manifold being so free flowing and the sensor picks this up, this is not a problem unless the car seems to have a problem i.e not driving as it should, if the car is driving normal then its a common thing to happen when the manifold has been changed.
I drive with the CEL light on permantly, but there is a cure
02 Simulator - CEL / MIL Fix - O2 Sensor Simulator
Use this, it is a spacer that is plugged into the o2 sensor on the manifold and then the o2 sensor plugged into this, its a spacer so the sensor does not sit inside the pipe and then the gasses dont touch the sensor and set the light off.
Ive never seen a car in the UK with an Alta exhaust but it does look like a quality exhaust i dont think you will go wrong there!
Some one in the UK has just had an Emissions test and it passed with this light on!
Best regards Scott.
Old Oct 13th, 2007, 05:52 PM   #4 (permalink)
Bombers_son
cheers for the replys
Old Nov 27th, 2007, 01:54 AM   #5 (permalink)
danielo
Local Time: 02:23 AM
Isn't the CEL light a general warning that something is not within the allowable perimeters?
It could be lean issues, sensor problems etc.
Malaysia Male   Reply With Quote
Old Nov 27th, 2007, 06:56 AM   #6 (permalink)
ScottyBoy
ScottyBoy's Avatar
Yes both are true but more likely to be being lean! Although it will still run fine etc
ohh and that company i mentioend above DONT use them, im now wating over 2 an half month for the part!
Scott
Old Nov 29th, 2007, 12:57 PM   #7 (permalink)
Zeodare
Local Time: 08:23 PM
So if you have a European Car and mount all Alta exhaust Cat-back + downpippe the CEL light will be on but the car will work right?
Spain   Reply With Quote
Old Nov 29th, 2007, 04:11 PM   #8 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
I have both the milltek exhaust and the milltek manifold with sports cat. At the time of fitting my mate just unbolted it and put the new set-up on. No lights showed up no faults registered etc etc. If this happens with a manifold with a cat fitted then theres something not right, either with the car or the sensor. Any vehcile still running a cat should not get o2 sensor issues unless there is a problem or a fault on sensor. If you remove the cat then yes the o2 sensors will register and issue despite the car being fine in real life.
If you have a catted manifold and this light is on try a new sensor and resetting the fault code on ECU. Or if this doesn't work then theres an issue with the cat iself possibly.
No-one I know with a milly manifold or JCW or MINI mania or GTT who has left the cat in has had lights on afterwards, unless they had a dicky sensor. They may have got it for a bit but its reset itself, or if reset manually its never returned. It should not just stay on even after resetting....unless the sesor is bust or there really is a fault on car/cat.
The alta exhaust has had fitting issues ... because of having only 1 back box/hanger set-up. The milly is fiddly but seems to regularaly be the best exhaust for power. The Janspeed and GTT manifolds are better than Milltek, mainly as more versitle with decat option (for track only ). but the milly does perform well on road and rollers as a cheaper option
Old Nov 29th, 2007, 04:51 PM   #9 (permalink)
FergusM
FergusM's Avatar
All these options available for the R56 ?? Never heard of a GTT manifold for a R56.
Scotland Male View FergusM's Dark Silver & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Dec 30th, 2007, 03:41 PM   #10 (permalink)
BoomersMCS
Local Time: 11:23 AM
Please see my posts under Milltek downpipe withdrawn in the US.
I'm asking for help to get Milltek to come up with a fix for this issue.
I have their cat back system and when I purchased it in Nov. 07 was told by the US distributor that the downpipe was recalled but would be back on the market shortly after they resolve the CEL light issue. Late this month they informed me, Milltek has no plans to release a revised downpipe in the US and were selling in the UK & Europe with a disclaimer re the CEL issue.
Rubbish! Milltek should have the resources to find a fix. It's either in the Cat design or the O2 sensor bungs are not allowing the sensor to be seated properly and therefore the CEL is triggered thinking there is a problem.
Please, let's try to get Milltek to address this issue by contacting them. Maybe when they realize the market potential they will step up with a fix.
Cheers.
Old Feb 2nd, 2008, 10:03 AM   #11 (permalink)
pfmagic
Just thinking about getting the Miltek downpipe for my Oct 07 JCW stage 1 CS. I spoke to a guy at Lohen yesterday and this was not mentioned, I'll give him a call next week to check if it's an issue.
With the current JCW upgrade they change the back box of the exhaust with not too much difference in sound from the original does anyone have an idea of the increase in noise if I fit the downpipe, basically I don't want to wake the neighbours eberytime I go out !!
Old Feb 21st, 2008, 05:06 PM   #12 (permalink)
minichara
So, basiclly, Miltek is OK for EU cars?
What I mean by 'OK", is that there is no "check engine" light or whatever.
Is that correct?
Greece   Reply With Quote
Old Mar 7th, 2008, 05:21 PM   #13 (permalink)
kentistos
www.mini-tuning.at
kentistos's Avatar
Local Time: 06:23 PM
I specifically have on my car a superspint which performance wise i think is one of the best you can get , however it is quite noisy, another solution is Bastuck exhaust which are quite
Greece Male   Reply With Quote
Retro fitting JCW exhaust tips to MCS Exhaust Cooooooperslad Exterior 13 Jul 3rd, 2007 01:33 PM
JCW GP Exhaust on Mini One(dyno inside without\exhaust) Innuendo MINI One 13 Feb 25th, 2007 10:15 PM
05 exhaust vs 02 exhaust St00ge Engine & Drivetrain Tuning 2 Feb 19th, 2006 02:09 PM
05 stock MCS exhaust sound vs. JCW exhaust - pops or no?? MiniMelSF Engine & Drivetrain Tuning 7 Jul 1st, 2005 07:10 AM
**UK** Magnaflow Cooper S exhaust swap for other aftermarket s exhaust B4d4Bing For Sale 3 Apr 11th, 2004 05:51 AM
