Visit Mini Mania UK
Old Jan 11th, 2008, 05:22 PM   #41
TallAndy
Taller Than You!
Local Time: 11:43 PM
Send a message via ICQ to TallAndy Send a message via MSN to TallAndy Send a message via Yahoo to TallAndy Send a message via Skype™ to TallAndy
This is very interesting so let me get this straight, in the attached picture where I have coloured red, there are holes which go vertically for noise deadening. You guys have covered the holes up so the bypasses this lump of plastic and goes straight into the filter?
Cheers,
Andy
Spose I should just take it apart and look
England Male View TallAndy's Chili Red & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Jan 11th, 2008, 07:03 PM   #42 (permalink)
J1JPE
Engaged to Laura on CNY
J1JPE's Avatar
Wink get it bypassed
Cheers,
Andy
Yep !
'tis a resonator box which makes a brum (diesel engine like noise) which is supposed to be sporty; bit like blowing over the top of a milk bottle ;}
air going in is not getting to the engine, flow is disturbed, power is reduced ...
u can either cover the holes or use a tube, pipe to connect the inlet hose to the bit that goes into the air filter housing;
my way is quick & easy, James' more fiddly but gives a neater result
Does anyone know which in theory is better - a narrower tube, increased pressure = faster flow so more air or a wider tube = more air volume even if travelling slower ?
England Male View J1JPE's Sparkling Silver & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Jan 11th, 2008, 07:50 PM   #43 (permalink)
J1JPE
J1JPE's Avatar
Thumbs up 44.2 MPG to 52.5
Reset the computer the other day and avg consumption has improved 18.8% with the tube mod !!
for a 56 Nov 06 car without stop/start, given the way I drive, not bad ...
official combined for the manual is 52.3 MINI - MINI Cooper - Tech Spec
Old Jan 12th, 2008, 06:13 AM   #44 (permalink)
TallAndy
Taller Than You!
I'm lucky if i get 40mpg now - Changing my wheels to 18" JCW from the standard 15s has made consumption drop quite a lot...
Anyway back on topic, thanks for the reply! I'll have a nosey under hood this weekend me thinks!
Old Jan 12th, 2008, 10:34 AM   #45 (permalink)
J1JPE
J1JPE's Avatar
Lightbulb round the corner
Am just up the road at Middlebrook, Horwich Mon - Fri 9 to 5;
bit dark & wet lately but happy to pop 'round for a brew, have a nosey, bring a tube for you to try etc ... if u like
Old Jan 14th, 2008, 10:33 AM   #46 (permalink)
TallAndy
Taller Than You!
What do you do up there? I work in Prestwich 9-5 usually.
Old Jan 14th, 2008, 06:52 PM   #47 (permalink)
J1JPE
J1JPE's Avatar
me do
Npd
Old Jan 27th, 2008, 10:57 PM   #48 (permalink)
TallAndy
Taller Than You!
So is everyone happy with their ITG filters? You've gone very quiet!
And also the resonator mod, still working okay? Any comments on noise/performance?
Old Jan 28th, 2008, 12:04 AM   #49 (permalink)
jamesbeaumont
Addicted to MINI...
jamesbeaumont's Avatar
Send a message via MSN to jamesbeaumont
Yup Im very happy. The combination of the two have made a big difference to my car. Its mostly the torque between 1 and 2,000 rpm where the car now pulls much smoother and strongly. I can now plonk it in straight in 5th from 3rd in a 30 zone and it will easily pull from there. Its meant my around town mpg has risen from 35 to 38 which is nice! Noise wise i dont think theres much difference, just sounds a bit happier when cold. Which is another change, my car used to struggle on cold mornings when i changed up a gear the revs would dip and then rise again giving a light jerking action until it had warmed up. this has now completely gone so I wonder if it was related to airflow. By the way my airbox mod that i did with the laminate plastic has worked great, it has stuck well is well worth the 50 pence it cost!!
Chili Red R56 Cooper aero kit side repeaters, ITG panel filter, Eagle F1 GSD3's, Silver vision bulbs and soon to have a cat back exhaust and chip
Scotland Male View jamesbeaumont's Chili Red & White 2nd Gen MINI Cooper Profile   Reply With Quote
Old Jan 28th, 2008, 08:40 AM   #50 (permalink)
TallAndy
Taller Than You!
Cool stuff. My car isn't great on cold mornings, can be a bit ropey. Think I might get the filter and mod the airbox soon
Old Jan 29th, 2008, 10:00 PM   #51 (permalink)
J1JPE
J1JPE's Avatar
DIY still h.a.pp.y
More torque, 4th to 6th at 30ish pulls easily
quieter and less judder when cold; accelerate hard & induction / zorst vroom noticeable
Fuel econ still improved
v happy
& airbox mod cost nothing bar brain power & tinkering time
Just waiting for ITG to be £40ish rather than £63+p&p
Come on Andy - get it done lad ! ;}
Old Jan 30th, 2008, 03:45 PM   #52 (permalink)
extigy
i would be interested in getting that filter for a cooper in a group buy.
Also, I sourced a tube the right length (paint roller ) and put it in the resonator to block the holes. The tube goes right to the end and my concern is that it is actually limiting the air flow a little by having a smaller total diameter, so i am looking at the laminate idea, just a question, to get the whole resonator box off, i see it is connected to the air panel housing but can't see exactly where or how.
Also, where did you get your clear laminate from, would high quality duct tape do the job as well ?
Old Jan 30th, 2008, 06:04 PM   #53 (permalink)
jamesbeaumont
Addicted to MINI...
i removed the whole resonator box, this was done by removing inlet hose from the front and then pulling the box upwards and untwisting it from the back and it simply comes out, very easy to get back in again my doing the opposite and pushing it in to the hole (this can be done by feeling with your fingers) and pushing down (anticlockwise) with regards to the laminate, i got it from makro but it would be available in some bookstores i would imagine, however anything sticky and flexible would do. good luck!
Old Jan 31st, 2008, 09:14 AM   #54 (permalink)
neilians
neilians's Avatar
Smile
I'm very happy with my ITG filter, car seems a bit more responsive & improved economy, now averaging 47mpg on a long run & 45mpg day to day.
Old Jan 31st, 2008, 01:06 PM   #55 (permalink)
TallAndy
Taller Than You!
okay okay.... ordered the ITG filter
Old Feb 1st, 2008, 06:13 PM   #56 (permalink)
jamesbeaumont
Addicted to MINI...
Good stuff, let know what you think. Try doing the resonator box mod at the same time so you get a more noticeable difference!
Old Feb 3rd, 2008, 02:25 PM   #57 (permalink)
SteveBrass
SteveBrass's Avatar
Just fitted ITG filter.
will report back.
R56 AB Cooper
United Kingdom View SteveBrass's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Old Feb 4th, 2008, 10:01 AM   #58 (permalink)
TallAndy
Taller Than You!
Not had chance to tinker with the resonator box, quickly fitted the filter in the evening on Friday just before a rush down to London.
Seems bettter mpg is up, and the journey was fairly *cough* quick Seems to pull better in gear on the motorway too.....
Old Feb 5th, 2008, 09:46 PM   #59 (permalink)
rochie
rochie's Avatar
any news on them for the r56 mini one?
Old Feb 7th, 2008, 04:18 PM   #60 (permalink)
TallAndy
Taller Than You!
Is the filter not exactly the same on the one?
Show Printable Version
