Mighty Stripes
Tags: ,
Old Apr 1st, 2008, 04:51 PM   #1
neilobe
Local Time: 03:24 PM
Unblocking R56 Bonnet Scoop
So has anyone unblocked / Drilled holes in there R56 S Bonnet scoop grill bit , im meaning cause its only for show, would opening it up improve air flow at all ??
Anyone done it or thinking about it too ??
United Kingdom Male View neilobe's Astro Black & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 1st, 2008, 06:35 PM   #2 (permalink)
futureal33
futureal33's Avatar
I've heard if you've got an open filter (CAI) like the Alta one, then it supposedly increases air flow to the filter - whether it makes much difference in the 'real world' is to be debated I am sure.
Just bought a Mini Cooper S !!
United Kingdom Male View futureal33's Pepper White & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 1st, 2008, 06:47 PM   #3 (permalink)
adam_Randell
07' Cooper
adam_Randell's Avatar
Send a message via MSN to adam_Randell
I think it should improve air flow a little, will also help the engine stay a little cooler.
If you have the Alta air filter, you can get a triangle bit of plastic to go inside the bonnet, which attaches to the air scoop and when the bonnet is closed links to the filter too to its a very direct air feed!
Old Apr 1st, 2008, 07:12 PM   #4 (permalink)
nicknbecka
Local Time: 07:24 AM
I can't find where I'd seen it before, but I've run across a post where someone claimed that opening up the scoop grill would increase the air pressure beneath the bonnet and behind the intercooler- actually decreasing the airflow through the intercooler and making for worse performance rather than an improvement.
EDIT: Of course, it doesn't apply to the closed circuit systems like DDM Works or Alta's in adam_Randell's post..
Old Apr 1st, 2008, 07:25 PM   #5 (permalink)
Tigger, Eeyore & Roo
Retiring from Mini2
Tigger, Eeyore & Roo's Avatar
That was me, thanks for remembering
A lot of serious racing cars / motorcycles mount their radiators at the rear of the car as negative air pressure behind the radiator is really important for the free flow of air through the radiator. If the holes were to achieve any significant airflow then it would only increase air pressure behind the radiator. Being water cooled, efficient cooling of the radiator is far more important than just drilling a few holes in the bonnet and "hoping for the best"
Tigger.
PS: Not quite certain why I've written this as no one seems to be reading it!
To register your interest in The New MINI Kernow Cornish Oggy Run, Summer 2008 please click HERE and welcome to Cornwall! Visitors welcome! English spoken!!
Last edited by Tigger, Eeyore & Roo : Apr 5th, 2008 at 01:10 AM. Reason: Added PS!
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 2nd, 2008, 08:53 AM   #6 (permalink)
terabytesmyass
terabytesmyass's Avatar
Local Time: 12:24 AM
I have a oct 2007 Cooper S with approx 4/5ths of the holes in the bonnet scoop open. This is how i purchaced- 'factory' no mods. Not sure if the scoop is different in any way ? but all seems to work fine.
Pernaps no longer just for show?
Australia View terabytesmyass's Lightning Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 2nd, 2008, 10:12 AM   #7 (permalink)
tommo13
twin scroll
tommo13's Avatar
Yep my 2008 Cooper S has about 4/5ths of the holes open also. I wonder if this was done to help cure the red hot bonnet problem that some early R56 owners reported ?
Either way I can't see any problem with opening the holes up on an early scoop if this is the way they are leaving the factory now. Unless MINI are just hoping for the best ?
United Kingdom Male View tommo13's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 2nd, 2008, 12:29 PM   #8 (permalink)
X8 JOC
Posts: n/a
Well i have an 08 cooper s and have taken our the little black grille in the scoop, dont know if it makes a performance difference. But it does make it look nicer and cleaner from the front, also it helps cooling of the turbo charger which is right behind the scoop. I know that after i have done some hard driving and i park the car i can see that like mirage effect coming through the scoop where all the hot air is escaping. So i think yes it does help the engine but maybe only by ading cooling. But still a help.
Visit my Blog at the Motorcade   Reply With Quote
Old Apr 4th, 2008, 04:36 PM   #9 (permalink)
josh b
Hi all, i'm new here and looking at cheap and simple things I can do to my 07reg MCS to make it go that little bit faster (its a company car you see).
I just unscrewed the black bit and took it out. Cant understand why everyone is drilling it?!?
I've got an open filter and it does make a little difference in throttle response.
Old Apr 12th, 2008, 06:39 PM   #10 (permalink)
caesar
caesar's Avatar
Thats strange, my June 07 build MCS scoop has most of the slots open
Old Apr 12th, 2008, 09:22 PM   #11 (permalink)
Mutley MCS
Endorphine Machine Addict
Local Time: 01:24 AM
I have had my scoop open for some time now and have had not had any problems with engine cooling as a result. The radiators are well and truly efficient enough to cope with any pressure change that this mod will make to under bonnet pressures.
It will also increase clean air flow under the bonnet, assisting with lowering of under bonnet temps.
You will note that I live in Australia and I have driven this car pretty hard on 35 degree celsius days, still not problems with temps.
I can see the theory of this concern over engine temps but in practice I do not believe this is the case due to the capacity of the cooling system.
As for the intercooler, because it is mounted lower than the motor, I do not see how the airflow through this will be affected opening the scoop.
Australia Male View Mutley MCS's Mellow Yellow & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 13th, 2008, 07:53 PM   #12 (permalink)
caesar
caesar's Avatar
Open slots in the air scoop grill would certainly help to cool the turbocharger which gets very hot. I have noticed on a run when the turbo has been working hard, and you stop for some reason and its raining there is quite a lot of steam coming from the grill !!!
Old Apr 13th, 2008, 08:01 PM   #13 (permalink)
neilobe
I will problary open mine up then next weekend, i have emailed mini uk and asked them if there was a change in any later build cars having the scoop partly opened. waiting for a reply back.
Mines an April 07 build.
Old Apr 13th, 2008, 08:29 PM   #14 (permalink)
caesar
caesar's Avatar
There were a lot of threads on this topic last year. My MCS is a June 07 build and I posted a photograph of the grill which showed the open slots. The general consensus of opinion was in favour unless you lived in the Arctic
Old Apr 13th, 2008, 09:04 PM   #15 (permalink)
Paul
Trained Monkey
Paul's Avatar
They changed the scoop (opened it up) and it was to aid cooling, although when I suggested that the 'mock' scoop had actually been updated to serve a purpose again (cooling) the thought was pretty much dismissed for some reason.
Old Apr 17th, 2008, 09:24 AM   #16 (permalink)
neilobe
Well after waiting few weeks, Mini finally emailed me back today .. here is what they say on the subject :
Dear Neil
Thank you for your email to MINI Customer Information, and please accept our apologies in the time taken to get back to you.
The bonnet scoop has not been unblocked for 2008 model year MINIs, the mesh of the scoop was changed in 2007 in design however the vent is still blocked. The engine has more than sufficient cooling with its current set up which is why it is unnecessary to unblock the vent.
We trust this information is of use and please feel free to contact us should you have any further questions.
Yours sincerely
Christian Gorton
MINI UK
Product Information Advisor
Ellesfield Avenue
Bracknell RG12 8TA
Old Apr 17th, 2008, 09:31 AM   #17 (permalink)
tommo13
twin scroll
tommo13's Avatar
They know what their talking about then
Old Apr 30th, 2008, 09:18 PM   #18 (permalink)
Nath316
I'm avin 'oops
Nath316's Avatar
Send a message via MSN to Nath316 Send a message via Yahoo to Nath316
would be interested to see this on Pepe
Jul 07 S and to be honest I hate the fact that the holes are not completely open as I do not believe aesthetically that it looks right
I may just undo the "panel" for want of a better word and see what is likely to happen!
More Air + More Fuel = More Power!!!!!!!!!!!!!!!!!!!
England Male View Nath316's British Racing Green & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 1st, 2008, 08:04 AM   #19 (permalink)
caesar
caesar's Avatar
As I said in an earlier thread my June 07 build MCS Scoop Grill has most of the slots open. You could remove it and then open the slots carefully using a drill.
Old May 1st, 2008, 10:47 AM   #20 (permalink)
Boro Boy
I had MINI replace the mesh on my Nov '06 MCS to the revised partially-opened version early last year. In my opinion, the scoop in the R56s is a necessary vent to allow hot air from the turbo to escape when coming to a standstill after a spirited run, especially in summer. Oddly, it's only necessary I think because of the plastic scoop housing. The Cooper D has a turbo, but no vent - no problem here as the steel bonnet conducts the heat and spreads it over the bonnet to radiate it evenly, if you see what I mean.
Given the choice, I would have opted for a bonnet without scoop when I bought the car.
DerekH had posted a pic (link below) of the Challenge car with a deflector fitted behind the scoop which I think will allow hot air to escape (when coming to rest) more easily. I wonder if the new Factory JCW has this mod. Does anyone know if the deflector is available separately?
http://www.mini2.com/forum/attachmen...5&d=1190110524
England Male View Boro Boy's Pure Silver & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Bonnet scoop GTT 280 GT Tuning 16 Jan 29th, 2008 07:23 PM
R56 bonnet scoop genik 2nd Gen Exterior 6 Nov 14th, 2007 05:50 AM
Bonnet Scoop mcs_jcw Exterior 2 Nov 3rd, 2007 11:20 AM
How to fit R56 MCS Bonnet Scoop? nephilin 2nd Gen Exterior 9 Jul 2nd, 2007 08:01 PM
Bonnet Scoop pubert Exterior 9 Jul 31st, 2006 10:53 PM
