Carccessory.com
Old Dec 12th, 2006, 08:23 PM   #1
extigy
Local Time: 11:45 AM
Spot lights
Took delivery of my mini the other day and when i went to pick it up i noticed the spot lights are not in a fixed position horizontally. i.e they swivel from side to side a bit. The dealer told me this is how they were intended, but after driving at night with them on, you can really see the lights moving over bumps. Anyone else noticed this ? or is just my car ?
Old Dec 12th, 2006, 10:31 PM   #2 (permalink)
Eddie501
Smile Lights,
My light bobble about a bit too.....mind you Im too busy burning peoples eyes out to worry !! ha ha .......Better than daylight !!
It's gotta be yella'
Old Dec 13th, 2006, 08:03 AM   #3 (permalink)
Paul
Trained Monkey
Paul's Avatar
I haven't seen these, but I cant see how lights are supposed to be loose fitting?
Old Dec 13th, 2006, 08:11 AM   #4 (permalink)
rec
Not a happy bunny.
rec's Avatar
Send a message via MSN to rec
just means they vibrate up and down as they're only fixed on 1 point.
this is like putting a piece of bluetak on a straw, and shaking the bottom, the movement will be amplified the other end.
you cant stop this, it's physics. unless, of course, you fashioned a mounting bar that went from the top of the spot light to the bonnet itself.
England Male View rec's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Old Dec 13th, 2006, 08:18 AM   #5 (permalink)
Paul
Trained Monkey
Paul's Avatar
Surely they should not move horizontally though? As in left/right?
Old Dec 13th, 2006, 08:25 AM   #6 (permalink)
rec
Not a happy bunny.
rec's Avatar
would a light move horizontally due to a vertical bump tho ?
i doubt you'd be able to distinguish a horizontal movement of a spotlight as much as you would be able to distinguish a vertical one...
Old Dec 13th, 2006, 10:37 AM   #7 (permalink)
ScottieCoop
Shopping
ScottieCoop's Avatar
yeh mines move from side to side aswell. can't say I've noticed a wobble when on main beam.
figure this was how they are meant to be as the spot lights on my LandRover D3 do exactly the same.
Cooper D (2007)
Scotland Female   Reply With Quote
Old Dec 13th, 2006, 10:40 AM   #8 (permalink)
CC07ERS
TYPE R GT VTEC POWERED
CC07ERS's Avatar
did menzies do your fi
Old Dec 13th, 2006, 05:30 PM   #9 (permalink)
extigy
I have had a closer look at the spot lights today and there is a support that protrudes from the front grille (built in) and mounted on this post is a U shaped bracket with a pin thorugh it securing the light. The movement from side to side is the lights swivelling on these pins. (I'll take a picture tomorow) I don't really see how they can be fixed in position which is quite annoying.
Old Dec 13th, 2006, 05:50 PM   #10 (permalink)
ScottieCoop
Shopping
yip
Cooper D (2007)
Which spot lights are better!? matt1985 Exterior 29 Feb 10th, 2007 07:14 PM
spot lights Snotta MINI Cooper S 5 Sep 17th, 2004 12:46 PM
spot lights ono Exterior 3 May 12th, 2004 09:25 AM
Spot Lights WarGod Interior & Ice 3 Oct 22nd, 2003 08:08 PM
Spot Lights for a ONE? piersberry Exterior 0 Aug 16th, 2002 09:20 AM
