| Tags: bulbs, newministuff |
| I can't get no sleep Join Date: May 2002 Location: Capital of Culture Local Time: 11:24 AM
Online | Bulb guide for R56 MIni A quick guide to bulbs you can change Headlights; Non xenon models Easy to change, 1 bulb does both dip & main beam unlike the older R53 model You can increase the light output by fitting xenon enhanced bulbs. These are legal & e marked. Typically giving 50% more light. 2 types in stock Osram Silverstar; a white light, clear when off NewMINIStuff.com Powerbulbs; slight blue tint, blue when off NewMINIStuff.com Front sidelights; all models. Easy to change, the factory ones look very yellow Osram halogen; brighter & whiter NewMINIStuff.com Powerbulb halogen; not as bright, purple light LED; very bright white, not e marked Front indicators; only models with clear indicator lenses (std on Cooper S, optional on other models) Easy to change, factory ones make the clear lens look orange. 2 types stocked. Silvatec; silver when off, orange when on. Slightly dimmer than standard bulbs but e marked & legal NewMINIStuff.com Osram diadem; slight blue tint when off, orange when on. As bright as standard bulbs & e marked. NewMINIStuff.com Rear indicators; only models with clear indicator lenses Easy to change, factory ones make clear lens look orange. 2 types stocked Silvatec; silver when off, orange when on. Slightly dimmer than standard bulbs but e marked & legal NewMINIStuff.com Osram diadem; slight blue tint when off, orange when on. As bright as standard bulbs & e marked. NewMINIStuff.com Side repeaters; only on models with clear lenses Easy to change, factory ones show orange dot in lens Silvatec; silver when off, orange when on. Slightly dimmer than standard but e marked NewMINIStuff.com Door puddle lights. Easy to change. Osram halogen; give a brighter light to show more pavement NewMINIStuff.com Last edited by mikeythemini : Jan 19th, 2007 at 07:18 AM. |
| MINI2 Regular Join Date: Aug 2006 Location: London/Stockholm Local Time: 10:24 AM
Offline | Hi Mikey I got the bulbs - cheers for sending them so quickly. I've changed the front and rear indicators (fronts through the circular hatch in the wheel arch, rears through the side cubby holes in the boot) and I've changed the front sidelights (through the lower circular hatch in the wheel arch). However, the only way I can see to change the sidelights is by having tiny hands and reaching down from under the bonnet. Alas my hands are too big! Is there another way to change the sidelight bulbs - you mention it as being easy, so I'm hoping there is! |
Offline | Aha! Sussed it out in the end. Slide the whole side repeater assembly towards the front of the car. Once it's come away, you can rotate the bulb holder out from the rest of it and change the bulb very easily. Easier than the rest of them in fact. Quick and effective mod for the R56 and under £50 for the whole lot. Cheers Mikey. |
| R56 spare bulb kit | sprite | General Discussion | 4 | Oct 20th, 2007 09:07 AM |
| R56 tail/brake bulb | picard | 2nd Gen Exterior | 8 | Aug 16th, 2007 10:52 PM |
| R56 Indicator Bulb type | DerekH | 2nd Gen Exterior | 15 | May 27th, 2007 05:23 AM |
| R56 MCS bulb types | DerekH | 2nd Gen Exterior | 8 | Apr 11th, 2007 06:46 PM |
