Mini Pirate
Old Apr 26th, 2007, 07:06 AM   #1
BlueCooperR56
BlueCooperR56's Avatar
Local Time: 06:57 AM
Sat Nav Aerial?
I've ordered Sat Nav on my R56, just wondered if it has a different type of aerial (like BMW's stubby aerial) than the usual aerial? If not, would replacing the standard aerial with a beesting stubby aerial have any effect on the GPS signal?
Thanks!
Old Apr 26th, 2007, 07:29 AM   #2 (permalink)
bugiz
R56 Nut
bugiz's Avatar
Local Time: 03:57 PM
Good question.
Australia Male View bugiz's Sparkling Silver & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 26th, 2007, 09:36 AM   #3 (permalink)
moog5
moog5's Avatar
Local Time: 07:57 AM
I'd be interested to know this as well, hadn't thought of that!
Male   Reply With Quote
Old Apr 26th, 2007, 09:58 AM   #4 (permalink)
118
Twixys Rubber Ducky
118's Avatar
Send a message via MSN to 118
I picked up my new S yesterday and have sat nav - the aerial is the same as the standard one, but not sure if a stubby would affect it, I've been wondering the same thing. I can't see any reason why it should tbh
United Kingdom Visit my Blog at the Motorcade Male View 118's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 26th, 2007, 11:23 AM   #5 (permalink)
Purple Dave
According to the RealOEM site, there is a unique part number for Sat Nav/Bluetooth/DAB.
It must be upgraded in some way to improve reception.
United Kingdom Male View Purple Dave's Dark Silver & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Jun 13th, 2007, 11:51 PM   #6 (permalink)
jmemannix
Hi all,
Ive just picked up my r56 mini one with a sat nav and the first thing I needed to do was replace the aerial with a stubby beesting aerial as the original aerial would hit the top of my car port everytime otherwise ha ha ha. As far as I can tell the sat nav still works fine and the radio is just as good.
Hope this helps.
Old Jun 15th, 2007, 07:45 AM   #7 (permalink)
BlueCooperR56
Great! Thanks for that!
Old Jun 15th, 2007, 08:53 AM   #8 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 01:57 AM
I believe that the nav GPS receiver is in the base and not the actual antenna used for the radio. So, you should be ok. I have swapped the one on my R53 with no problems at all.
Global Moderator
United States http://www.mini2.com/forum/Visit my Blog at the Motorcade Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 15th, 2007, 10:31 AM   #9 (permalink)
BlueCooperR56
That's good, I'll get one when I get the car! Thanks
Old Jun 16th, 2007, 07:13 AM   #10 (permalink)
FergusM
FergusM's Avatar
Sure the Alta shorty on Lohen specifically states that the 4" one should be used with satnav, and that the 2" is only if you just have radio.
I got the 4" one though I have no satnav as to be honest it is tiny.
Scotland Male View FergusM's Dark Silver & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Jun 16th, 2007, 08:47 AM   #11 (permalink)
BlueCooperR56
That's good cause that's the one I was looking at! Thanks!
Old Jun 18th, 2007, 04:43 AM   #12 (permalink)
Sowellman
Quack Quack Oregon Ducks
Sowellman's Avatar
Local Time: 10:57 PM
I have the four-inch Alta antenna and the sat nav works fine with it. It's my understanding that the removable antenna only affects the radio and that the sat nav receiver is in the base. I sent a question to Adam from Alta and have asked him to supply a definitive answer.
Update: Adam confirmed that the antenna is strictly for the radio, not the sat nav. You should be able to use any length of antenna -- or none at all -- and still receive the GPS signals.
United States Male View Sowellman's Mellow Yellow & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Jun 23rd, 2007, 01:46 PM   #13 (permalink)
BlueCooperR56
That's brilliant, thanks!
Old Jun 23rd, 2007, 01:49 PM   #14 (permalink)
BlueCooperR56
Just following on from that then, do you notice any difference in radio quality between Alta four-inch and the standard MINI aerial? Thanks
Old Jun 23rd, 2007, 02:58 PM   #15 (permalink)
Sowellman
Sowellman's Avatar
Overall, the Alta performs admirably.
The only difference I notice is when I try to pull in a signal from an FM radio station that I like that is 70 miles (113 kilometers) away. That signal was fairly weak and dropped off at mile 68 or so with the antenna from my previous Honda Civic and with the stock Mini aerial.
I was at the absolute limit of that station's reception from the combination of station signal strength, aerial reception capability and hilly terrain.
That said, the dropoff point using the four-inch Alta is slightly greater. So I lose the signal a few miles sooner than I did with the other. However, when I am tuning local stations or travel to Eugene where the other station is located, the reception is fine. I haven't noticed any difference in those applications between the Alta and the longer staff of the stock antenna.
Old Jun 23rd, 2007, 06:29 PM   #16 (permalink)
BlueCooperR56
Thanks very much for that! I'll probably find the same in Reading. The station I listen to tends to drop in the very centre of town, possibly because it's low down in a built up area! But if I get that with the stock aerial anyway so it would probably just go a bit earlier! Thanks again!
R53 Sat Nav vs R56 Sat Nav Perm 2nd Gen Interior & Ice 34 Jun 22nd, 2008 04:16 PM
2005 Aerial & Aftermarket Sat Nav jd2_uk Interior & Ice 1 Feb 18th, 2005 12:31 PM
Mini Sat Nav Aerial number.two Exterior 2 Aug 18th, 2004 11:38 AM
Splitting MINI OEM radio aerial for TMC/has standard aerial plug? Spookyfish Interior & Ice 1 Jun 14th, 2004 07:45 PM
Non Sat-Nav cars: Utilised Sat-Nav area WAY Interior & Ice 1 Nov 1st, 2002 02:46 AM
