| Tags: aeroinstructions |
| JP :-) Join Date: Sep 2003 Location: Northern Ireland Local Time: 11:46 AM
Online | R56 Aero Kit Retro Fit Guide (Side Skirts Added) Decided to treat myself to an early Christmas present last week and ordered a Pre-Painted Aero Kit, on ordering I was told 6-8 weeks delivery and got a shock when 2 days later I had a call to say it was in stock. At this point I would like to point out that there is no way the kit will fit in the back of a Mini so if your picking one up sometime soon get something a little bigger, thankfully I have a Disco3 at my disposal so it wasn’t a problem. Anyway Sunday morning brought an early start and so I wanted to get cracking with fitting the kit. Please note the BMW/MINI Instructions are useless I decided to start with the rear bumper so…….. Rear Bumper
[IMG] [IMG] The above has to be completed on both sides before you can begin removing the old bumper.
There is an assortment of screws and torx screws holding the bumper in place, first is to remove all the torx screws from the base of the bumper, as far as I could make out these are just used to hold the spare wheel box in place, which I took the opportunity of removing completely as it serves no purpose with Runflats. The main screws holding the bumper in place are located where the wheel arch trim normally is and also at the boot lining (See Pics): [IMG] [IMG]
[IMG]
[IMG] Without using any instructions I would say this process incl removing the wheels & lining took approx just over 1hr The new aero kit rear bumper has exactly the same fixing points as the old bumper so It’s just a process of following the above steps in reverse order, the only difference is that you are required to re-wire the fog lights to allow for the both side, unfortunatly I found the wiring that BMW Supply with the kit does not fit so I was forced to do a bit of DIY. Once completed your new rear should look like this: [IMG] Side Skirts This is the easiest of the mods to make to the R56 and really transforms the car IMO. Again a quick glance around the existing skirts and it’s fairly obvious what has to be removed.
[IMG]
[IMG]
Time to put on the new skirts:
It screws onto the base of the car in about 8 different positions. Unfortunatly though it is extremely difficult to attach the new side skirt while this trim is attached to the body of the car, so I removed it again and decided to attach it to the new skirt first, it allows for easier alignment. It’s fairly straightforward where the extra trim attaches to the new skirt.
Once in position your new side skirt should look like this: [IMG] You are also supplied with the JCW Side Sills with the R56 Aero Kit Package Last edited by JpMcC : Oct 24th, 2007 at 11:30 AM. |
| MINI2 Master Join Date: Mar 2007 Location: Fraserburgh Local Time: 12:46 PM
Offline | Bmw instuctions are useless your are 100% correct there i wasted 2 hours on fitting spot lights as most important part not detailed , good report looking for skirts info now thanks Derek ![]() |
| How To ??? Fit R56 Aero Kit | specky 1 | 2nd Gen John Cooper Works | 4 | Jul 26th, 2007 06:31 AM |
| Bluetooth kits for R56 Mini - retro fit, works with MFSW from £160 | mikeythemini | 2nd Gen Interior & Ice | 20 | Mar 15th, 2007 12:01 AM |
| Retro-Fit Aero Wiper Blades | venox22 | Exterior | 4 | Aug 19th, 2006 12:01 AM |
| Help Guide for fitting Aero Kit for Cooper S? | monkeynuts | Exterior | 4 | Aug 23rd, 2005 08:59 PM |
| aero kit guide | wrappa | Exterior | 3 | Sep 2nd, 2004 01:01 PM |
