| | #21 |
| Trained Monkey Join Date: Jan 2001 Location: Bedfordshire Local Time: 01:58 AM
Offline | Try doing the same again without the rear window heater, as they're not related. |
| | #22 (permalink) |
| Making it add up Join Date: Apr 2006 Location: Sussex Local Time: 01:58 AM
Offline | This is what someone else posted "The heated mirrors on R56 initiate at 15 degrees C on a low power setting. When the temperature drops below 3 degrees they will then work on full power." Maybe its true |
| | #23 (permalink) |
| MINI2 Newbie Join Date: Jan 2007 Location: ipswich east anglia Local Time: 12:58 AM
Offline | Had the same problem this week with my 07 r56,phoned dealer and confirmed that you need to press the rear windscreen button for mirrors to heat up,im sure my old cooper s used to work automatically though? |
| | #25 (permalink) |
| MINI2 Regular Join Date: Nov 2006 Location: Stratford Upon Avon Local Time: 01:58 AM
Offline | Ooopps! All I asked was a straight forward question Im just gonna set off now to Robert Stern in Worcester so will let you know the outcome of the findings!! Should prove interesting..... |
| | #26 (permalink) |
Offline | This sounds most reasonable: "The heated mirrors on R56 initiate at 15 degrees C on a low power setting. When the temperature drops below 3 degrees they will then work on full power.". As I've seen nothing to suggest they tie in with the heated rear screen. |
| | #27 (permalink) |
Offline | Well I have been, and they advised me after checking wires / fuses that they do not work until the temp drops below 3 Degrees......... So my next question is where is the ambient temp sensor so i can pop some ice around it and say if they work !!! As luck would have it my speaker was playing up on the way over so they fixed that too!! Not so much a wasted journey then.... Mini Adventure I guess??? ![]() |
| | #28 (permalink) |
Offline | yeah ,thats right head honcho,im telling you what they told me so chill out!!! and if it does not work by the rear windscreen button then the manager of my dealership doesnt know his job,funny,you think he would!!!!!!!!!!!!!!!! |
| | #31 (permalink) |
Offline | **UPDATE** Went out this morning, mirrors had dew on them again, BUT it was 3 degrees outside!!! And guess what ------- they actually worked!!! So no fault, but confirms that they work at 3 degrees or less!! Warmed my hands on them too!! ![]() |
| Heated Mirrors? | Enders | MINI Cooper | 13 | Nov 22nd, 2004 10:44 AM |
| Heated Mirrors | minimalini | Exterior | 3 | Oct 28th, 2004 11:38 AM |
| Heated mirrors, windscreen jets and electrically folding mirrors | AnthonyD | Australia | 10 | Oct 6th, 2004 08:41 AM |
| Heated mirrors | Nicaf | MINI Cooper S | 4 | Jun 14th, 2003 11:23 PM |
| heated mirrors | grumpy07470 | General Discussion | 10 | Mar 31st, 2003 10:47 AM |
