Visit Out Motoring!
Tags: , ,
Old Mar 30th, 2007, 10:31 AM   #1
hayesl
hayesl's Avatar
Local Time: 12:33 AM
R56 Recall: Wheel-Side Gaiters
I haven't found details of this in any other posts, so I was wondering, has anyone else had a recall notice relating to the wheel-side gaiters? I've just received a recall notice from my dealer:
"Quality monitoring at the factory has revealed that the wheel-side gaiters for the output shafts may tear as a result of a manufacturing defect. The grease filling for lubrication of the constant velocity joints may wear out prematurely and cause noise.
To ensure your vehicle is in perfect condition, we would like to check the wheel-side gaiters and the output shafts and replace them if necessary."
England Male View hayesl's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Mar 30th, 2007, 10:55 AM   #2 (permalink)
Paul
Trained Monkey
Paul's Avatar
Local Time: 01:33 AM
Not heard of this one before on here. Sure we'll hear more now it's "out there".
Old Mar 30th, 2007, 11:24 AM   #3 (permalink)
jef the ref
MCS SS/B
jef the ref's Avatar
My R56 went in to the dealers to have a new sunroof fitted and to investigate the occasional diesel noise from the engine.
When I went to collect my car the engineer told me that he had carried a recall notice of changing the driveshaft Gaiters because there was as you described "a manufacturing defect" and they are prone to splitting.
I hope this helps, anyone else heard of this?
jef the ref
Old Mar 30th, 2007, 12:02 PM   #4 (permalink)
medilloni
The Stig's Dad
medilloni's Avatar
jef the ref
Hey Jef the ref, if you could keep me posted with your problems I'd greatly appreciate it. My MCS has exactly the same problems (roof and diesel impression). It goes in on 3rd April for a final attempt to fix them; the engine noise is beyond belief (have managed to record it for them).
I've informed them that I'll be rejecting the car unless a permanent fix is found on the 3rd April - also informed MINI customer services.
Many thanks.
EDIT: Come to think about it, I've wondered why there is so much grey gunge on the front wheels - I'll have a look at the gaiters tonight..........
"He fell for her like his heart was a mob informant, and she was the East River."
England Male View medilloni's Dark Silver & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Mar 30th, 2007, 12:22 PM   #5 (permalink)
R60 Mike
R60 Mike's Avatar
Send a message via MSN to R60 Mike
What are wheel-side gaiters?????????
sorry to sound stupid? any pics of any thing?
i am going in tomorrow with mine, after reving and returning to idle my car screeches like an old fiesta with a slipping fan belt
i thought people were looking at my car coz it was nice, not becuase of the high pitch noise every time its at idle.
United Kingdom Male View R60 Mike's Pure Silver & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Mar 30th, 2007, 01:25 PM   #6 (permalink)
mark-o
MINI2 4 ME
mark-o's Avatar
Local Time: 05:33 PM
I figure they're referring to the CV boots on the wheel side of the driveshafts.
cracked boot = dirty CV joint = early driveshaft failure
-M
Canada Male   Reply With Quote
Old Mar 30th, 2007, 04:28 PM   #7 (permalink)
daro911
daro911's Avatar
United-Kingdom
jef the ref
My sunroof rattles in the open venting position only (at the moment) what was the problem with yours. I have emailed my dealer asking him to call when BMW have a fix but heard nothing back since
Too many freaks not enough circuses
Tell a man that there are 400 billion stars and he'll believe you.
Tell him a bench has wet paint and he has to touch it.
United Kingdom View daro911's Laser Blue & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Mar 30th, 2007, 04:49 PM   #8 (permalink)
jef the ref
MCS SS/B
My sunroof would not open, it would move slightly and then jam. I took it to my dealers and left it with them for a week while I went Snowboarding in Canada.
I gave them a list of 3 things to sort out:
1. The jamming sunroof (it would open if I gave it a helping hand
2. The clunking noise at low revs pull away (approx 1100-1500rpm)
3. Xenons shining too low, I could only 20 yards infront of the car!
They replaced the sunroof, because it apparently jammed solid on them. The new one works great.
The clunking noise at low revs is not resolved, the car is going in on Monday to have a timing belt tensioner fitted. The Engineer also heard the occaisional noisy DIESEL sound when it was with them and hopes the Timing belt tensioner may sort that too.
Xenons adjusted to correct shine height, I can see at night now!
I also had the gunge on the passenger side front wheel, but that was AFTER the work was carried out. I assumed it was residue from the job and it has not reappeared.
Old May 30th, 2007, 08:46 PM   #9 (permalink)
J1JPE
New Job = $£€ +STRESS :o{
J1JPE's Avatar
hi guys, is this on the Cooper, S or both ?
United Kingdom Male View J1JPE's Sparkling Silver & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old May 31st, 2007, 09:26 AM   #10 (permalink)
hayesl
hayesl's Avatar
My R56 is a Cooper S, but I don't know if the recall was limited to Ss or applied to Coopers as well. They replaced one output shaft on mine. Mine is a November '06 build.
I also had a few squeaks and rattles (trim inside C pillar rubbing against glass, both front windows rubbing on seals and a squeak in the driver's seat springs). These all got fixed at the same time.
Have to say it's running beautifully at the moment, although I've had two odd problems:
  • One day, while driving, both front windows started moving erratically up and down by a few mm, changing direction every half second or so. Very odd, but hasn't occurred since and the dealer couldn't find any fault.
  • One day, when starting, the engine sounded VERY rough, a high pitched clatter. I stopped and restarted (the old tech support classic!) and it had gone. I'm more worried about that one than the windows, but it hasn't happened again.
I've just remembered something else - twice now I've come out to the car to find the windows have dropped down. Once and I can put it down to leaning on the button in my pocket. Twice and it becomes less likely. Three times and it'll be going back in...
While I'm having a bit of a whinge, Hexagon of Highgate have provided poor service. When I took my car in for the gaiter recall, they (despite them having given me the appointment time) didn't have the necessary parts in stock. I then had to remind them about it two weeks later before getting the work rescheduled. Almost without exception they are polite and helpful to deal with, but they are terribly disorganised. I'll be taking the car to Stephen James in Enfield for the first service, see if they're any better!
Special Offer: JCW Aero Side Skirts - 2nd Gen chris at woodman bmw Derek Woodman MINI 15 Dec 26th, 2007 06:53 AM
R56 side repeaters berty 2nd Gen Exterior 10 Jun 5th, 2007 09:34 PM
R56 Turbo Belt Recall Taffcd 2nd Gen MINI Cooper S 5 May 31st, 2007 06:17 AM
R56 JCW Side Skirts DerekH 2nd Gen Exterior 17 Apr 28th, 2007 10:35 PM
r56 s side repeaters CC07ERS 2nd Gen MINI Cooper S 17 Feb 7th, 2007 07:26 PM
