Visit Lohen!
Tags: , ,
Old May 4th, 2007, 07:09 AM   #1
d9hug
Local Time: 07:25 PM
MCS Whistle and Squeak
I went in for the Alternator recall a few weeks ago and since then (maybe it's just a coincidence) but I have had a whistle that I can hear on quite low revs .... So I took it back to the dealer and they could not find anything;
Also there a squeak at idle that comes and goes followed by another one when turning off
Have a look at these three videos - and let me know if you have any ideas what it could be !!!!
http://web.mac.com/darren.huggins/iW...e%20Noise.html
Preview of the link did not look correct so here it is again
Old May 4th, 2007, 07:36 AM   #2 (permalink)
burack
burack's Avatar
Local Time: 08:25 PM
Those kinda resembles me turbocharger and blow-off valve sounds, but yours are a "little bit" different from a normal sound. not sure, though. Good luck mate.
Turkey Male   Reply With Quote
Old May 4th, 2007, 09:36 AM   #3 (permalink)
R60 Mike
R60 Mike's Avatar
Send a message via MSN to R60 Mike
Mini R56 Engine Noise
mine does that
at last i have some one else with the same problem, mine is in at the moment trying to be fixed,
I am glad that there is now proof that there is a problem,
How many miles have you covered? and when was your build date?
mine was a november build date and covered 3000 miles
United Kingdom Male View R60 Mike's Pure Silver & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 4th, 2007, 11:43 AM   #4 (permalink)
CBCooper
November build Diesel MCS
CBCooper's Avatar
Local Time: 06:25 PM
Send a message via Yahoo to CBCooper
The whistle i presume is the turbo spinning up? (not a mechanic) Mine used to make that squeak though, say, after a long drive, come home and if you revved the engine like you do in your vids, as the car reached idle it would squeak, but it wasnt as bad as yours and intermittent enough so that when i went to the dealer it wouldnt do it!&$%#&*$ Bloody hell im getting frustrated looking at this stuff! Did your car make this noise at the dealer? Those vids are very clear and i know i sound like a stuck record from previous posts but that is not right! It could be something small and easy to fix and maybe someone with a more mechanical mind could shed some light as to what it could be, but dont get fobbed off, insist it gets investigated. Mine was a November build with approx 3,700 miles btw
Old May 4th, 2007, 11:45 AM   #5 (permalink)
d9hug
R60 Mike,
Just covered 3300 miles and was a Jan 07 build - I have just been over to the dealers again armed with my footage and they have booked it in again - initially they suspect that air is leaking from somewhere - your guess is as good as mine :-)
Old May 4th, 2007, 12:17 PM   #6 (permalink)
R60 Mike
R60 Mike's Avatar
R60 Mike,
I was told the same first time that it was an air leak, but then told that performance would suffer and havent noticed any drop off
second tec guy last friday then said it may be some thing to do with the air con and told me to keep the button on all week but the noise was still there
I wonder when I pick my car up if it will be yet another characteristic of the car, my car certainly has alot of character at the moment and its not a good one
Old May 4th, 2007, 06:11 PM   #7 (permalink)
R60 Mike
R60 Mike's Avatar
just watched your videos again and its Identical to my car
if you find out a fix before me then please let me know
Old May 4th, 2007, 07:44 PM   #8 (permalink)
d9hug
Will do - it's back in on Thursday
Old May 4th, 2007, 08:52 PM   #9 (permalink)
Den W
Now Aero Kitted!
Den W's Avatar
I'm not a mechanic but the squeak to me sounds like a bearing drying out,I wonder if the alternator should have been greased or something before being put back into the car. with the whistle that could be the turbo spooling up,but i notice on mine that sometimes I can hear the turbo other times I can't......weird
good luck anyhow
Den
ESSEXMINI2ERS
United Kingdom Male View Den W's Lightning Blue & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 11th, 2007, 06:31 PM   #10 (permalink)
d9hug
Well after a visit to the dealer, the tech guy was excellent they have decided to replace the alternator, belt etc...... will have to see what happens once thats done.
The techie also went on a road test where we reproduced the "ruler twang" so this has also been logged for further investigation.
Old May 31st, 2007, 01:59 PM   #11 (permalink)
d9hug
Alternator / belt replaced fault still there - another case is being raised with Mini but suspect water pump area may be causing it. Have to wait and see !!!
Old Jun 13th, 2007, 11:47 PM   #12 (permalink)
bradders_181
bradders_181's Avatar
Send a message via MSN to bradders_181
I cant get on to the links but im guessin it could be what my car did. I had the alternator and all the bit conected to it replanced and also the steering pump and it still made lots of funny noises, it turned out to be the water pump and the bits conected to to that, all been replace now and its not making the noises anymore :-)
Old Jun 16th, 2007, 06:31 PM   #13 (permalink)
Evergreen
Evergreen's Avatar
Local Time: 11:25 AM
Engine Noises
My regular cooper is making that squeaking slash whistling sound only more consistently. No way to tell if they are the same problem, but the sound is similiar. I would call it a whistle for us because it doesn't cut in and out, it stays at one pitch. It only happens when our engine gets warm and sits at idle, the squeak or whistle is pronounced and sustaining. Once we drive off or rev the engine the noise goes away. Depressing the brake or clutch changes the tone of the whistle for just a moment, then it goes back. When the engine cools after idling for a few minutes, the noise goes away. Sound like we're sitting in the same ballpark?
One other thing, I've noticed the noise seems to be coming from the passenger side of the engine block, down aong the side near one of the spinning belts. I wish I knew specific names, sorry.
I have an appointment for mine next week.
PS, Brilliant video! Makes talking about all these things much easier. We all should have it.
United States Male View Evergreen's Pure Silver & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Jun 17th, 2007, 09:38 AM   #14 (permalink)
wiggis
VW GT Sport 170 TDI
wiggis's Avatar
Hmmm. Watched your videos.
I reckon they just didn't set the auxilliary belt tension correctly when they re-assembled stuff and it is slipping a little. Either that, or there was some grease/oil on the belt and that is now what's causing the slipping.
Anyway, it doesn't sound at all serious to me. I would drive it like you stole it until something blows up or the noise stops. Certainly it wouldn't bother me enough to take it to the dealers until it got a lot worse.
Whistle and flute speccing northandy MINI2 Charity Ball 107 Apr 7th, 2006 07:45 AM
Squeak...squeak...squeak from the engine bay? v8voodoo MINI Cooper S 15 Dec 31st, 2003 05:19 PM
whistle revisited mcminicar Faults & Fixes 7 Dec 2nd, 2003 03:36 AM
Whistle LMB Faults & Fixes 7 Dec 4th, 2002 05:42 PM
