Mini Pirate
Old Sep 29th, 2007, 10:49 AM   #1
ianreeves
Local Time: 01:58 AM
Auto-Wiper Sensitivity
Hi,
DOes anyone know if the auto-wiper and lights sensitivity can be adjusted ?
Mine are way too sensitive and go into a fast wipe at the earliest spot of rain.
I have a 1 series as well and this has user adjustment and is perfect !
Even if this is a dealer thing..
United Kingdom View ianreeves's British Racing Green & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 29th, 2007, 12:35 PM   #2 (permalink)
Greenscaile
Local Time: 02:58 AM
I have the instructions for mine in the manual.....
If yours doesn't, drop a note back and I will transcribe it.
Old Sep 29th, 2007, 03:17 PM   #3 (permalink)
ianreeves
Thanks, that would help
Old Sep 29th, 2007, 03:26 PM   #4 (permalink)
Greenscaile
Courtesy of mini manual.
Adjusting rain sensor sensitivity
1. Switch on the ignition
2. Briefly press the button in the turn indicator lever repeatedly until 'SET/INFO' appears
3. Keep the button pressed until the display changes
4. Briefly press the button repeatedly until the symbol and 'SET' appear
5. Keep the button pressed until the display changes
6. Press the button to select the desired sensitivity
7. Wait until the display switches. The settings are stored.
I hope this helps/works for your wee beastie.
Old Sep 29th, 2007, 04:35 PM   #5 (permalink)
ianreeves
Not got anything in the Set section, maybe it was an update ? Ours in a early R56
Old Sep 29th, 2007, 04:45 PM   #6 (permalink)
Greenscaile
Okay...
Sorry it didn't work, mines a bit later than that.
Auto Lights - Cannot set sensitivity Laser_Chris 2nd Gen Faults & Fixes 6 Apr 10th, 2007 10:02 PM
Can you adjust the sensitivity of the auto wipers? Root Ginger Faults & Fixes 9 Feb 14th, 2006 04:49 PM
Auto Headlight Sensitivity MTRREF General Discussion 1 Dec 15th, 2005 06:02 AM
PDC sensitivity Tomasz General Discussion 4 May 31st, 2005 05:45 PM
Wiper Sensitivity Adjustment? tfisher General Discussion 1 Aug 1st, 2003 03:42 PM
