Visit Mini Mania UK
Old Mar 24th, 2008, 06:54 PM   #1
npalao
npalao's Avatar
Local Time: 03:18 PM
DIY R56 (early 2007) cluncking noise
I got my R56 in early June of '07. After about 3 months, and only 1000 kms in the odometer, I noticed a cluncking noise coming from the front left. The noise appears on low speeds on bumpy or very uneven roads (like old roads made out of river stones). I did not bring the car to the dealer until about 7 weeks ago, with the odometer reading only 3500 kms. The car has been in the dealership ever since. They have changed the bushings in both front and rear swaybars (which is a factory recall), left steering arms, steering column, electronic steering aid box, all of the left suspension components (including the shock), and finally the gearbox and differential. Nothing has solved it! Any ideas? I am so frustrated. BMW nor the dealer want to do anything about the car any more!
Mexico   Reply With Quote
Old Mar 29th, 2008, 09:51 PM   #2 (permalink)
red_S
red_S's Avatar
Local Time: 10:18 PM
Send a message via MSN to red_S
Hi!
I have a similar problem. Think the reason is to be found on the front right side of the engine (looking from front of the car) - at the top of the gearbox. There the connection ("wires") to the gearox lever are located. It is a kind of a metal lever and I tried moving it up and down and noticed it makes the like a metal-to-metal cluncking noise. But didnt report it at the dealer.
Try to find it and try moving the lever by hand to see if it makes the noise... :-)
Regards,
Damir
Slovenia Male View red_S's Chili Red & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Mar 29th, 2008, 10:39 PM   #3 (permalink)
adam_Randell
07' Cooper
adam_Randell's Avatar
Local Time: 09:18 PM
Send a message via MSN to adam_Randell
I had a clunking sound coming from my clutch. i went in for a total of 5 days of warrenty repairs. One garage saying 'we found the problem. it was the clutch pedal, so we lubricated it for you'. Was it bo***cks. Took it to another garage and they had it for 3 days and its still clunking 11 months on. My sister also had a clunking sound, and went to Nick Whale in Stratford and they fixed it no problem. But hers wasnt to do with the clutch
Old Mar 30th, 2008, 12:42 AM   #4 (permalink)
S8RAH
Away with the Fairies
Online
Glad i found this thread, I thought the noise was my exhaust, they've tightened it up this week but noise is still happening. Now I know its not just mine I'll push them to investigate whilst they're changing more timing bits on my car ( still sounds like a tractor!!)
Old Mar 30th, 2008, 07:53 PM   #5 (permalink)
red_S
red_S's Avatar
Quote: Originally Posted by adam_Randell (original)
...My sister also had a clunking sound, and went to Nick Whale in Stratford and they fixed it no problem. But hers wasnt to do with the clutch
Could you tell us what was it?
Regards,
Damir
Old Mar 30th, 2008, 10:53 PM   #6 (permalink)
adam_Randell
07' Cooper
Mine also sounds abit like a tractor/diesel but when i contacted MINI UK i was told that 'its a charictoristic of the R56'.
My sisters was to do with the suspension....not sure exactly what it was sorry.
Old Mar 31st, 2008, 11:31 PM   #7 (permalink)
npalao
npalao's Avatar
Angry no repair yet
This is the 9th week, and they finally gave up on the car. They (dealer and BMW Mexico) claim they do not have anything else to do, but the car was safe to drive. The checked the transmission once again for the lever and the actuating wires, and that was not the cause. I am still searching for the solution! I will contact BMW's (Mexico) president sometime next week.
Old Apr 5th, 2008, 09:45 PM   #8 (permalink)
S8RAH
Online
[quote=adam_Randell;3381679]Mine also sounds abit like a tractor/diesel but when i contacted MINI UK i was told that 'its a charictoristic of the R56'.
Three's a whole thread on this issue, don't let them fob you off !!
I had the strut mounting or something replaced yesterday, the stealers said it had gone, unfortunately the clunking hasn't gone. Back to the drawing board.
Old Apr 10th, 2008, 06:27 PM   #9 (permalink)
metromel1
metromel1's Avatar
Local Time: 04:18 PM
Have them check the engine and transmission mounts. I had a tranny mount go bad on my R56 MCSa after 10k miles The transmission would clank and you could feel it through the pedals off the light, right after 2000rpms.
Old Apr 22nd, 2008, 05:04 PM   #10 (permalink)
S8RAH
Online
some tracking bushes this time, still not fixed!
Old Apr 23rd, 2008, 10:01 AM   #11 (permalink)
Boro Boy
npalao, S8RAH, red_S - just to let you know, my car also produces a similar knocking noise as you describe, but as it is only ever apparent at low speeds over certain kinds of bumpy surfaces (and with the stereo off) I've lived with it. It's funny that when you read about someone else with it too, you suddenly become more sensitive to it! I've now had my head under the bonnet trying to wiggle gear rods, etc .
S8RAH, have you made your dealer aware of red_S's suspected cause? I think he may be closer to identifying the culprit.
England Male View Boro Boy's Pure Silver & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 23rd, 2008, 04:46 PM   #12 (permalink)
red_S
red_S's Avatar
I am not sure anymore about that. I had my dealer look at it. And the fact is when a gear is engaged the lever does not move any more...so they said it can not be the reason for the knocking...
Regards,
Damir
Old Apr 25th, 2008, 04:50 PM   #13 (permalink)
willhoo
Local Time: 08:18 PM
Bought my R56 in January 07. From the beginning I was told the rattling is part of the Mini experience!! Then when i complained about it during the 1st Mini recall (sometime in July) I was told they found a suspension problem and completed the necessary repairs (took them 3 days). Now 15 months into my Mini experience the problem is back again. What's worst apparently now a 'suspension bar' needs to be replaced. So they booked me another appointment only to be told after a whole day of repairs that they ordered the wrong parts to begin with. All I want to say is persevere with your complains even if they may look at you like you are a fool sometimes... thanks Ken for encouraging the purchase of small cars. I miss my 911.
Old May 6th, 2008, 05:30 AM   #14 (permalink)
Benibiker
Benibiker's Avatar
Local Time: 10:18 AM
Quote: Originally Posted by red_S (original)
Hi!
I think you're right red S and I may have found the same problem and a solution... In the picture I've attached, you'll see a part that sits just under and slightly behind the radiator overfill reservoir as you look down from the front of the car. This thing attaches to the gear shifter through a cable and sits on top of the gear box. If you wiggle this part up and down you'll hear the very clanking sound you might be hearing and I was hearing in my car. I attached a 5 inch spring from the hole you can see on this part down to a clamp almost directly below this part. You want the spring to just have enough tension to keep this part from clanking around but not too much tension or it might make your shifting difficult. My clanking is gone at a last and my shifter feels more solid and not so wiggly!!! This should be service bulletin or something, some dealerships are changing all sorts of parts and not fixing the problem. Try it and see if it works for you, it's worth a try and it worked for me.
Name:	drive box 1.JPG
Old May 6th, 2008, 09:05 AM   #15 (permalink)
Boro Boy
Hats off to you, Benibiker, if this is a cross-the-board solution! I'll get my head under the bonnet again this evening to investigate. Your attachment wouldn't load for me though, may just be my PC having a bad day ...
PS Where did you get your spring?
Old May 6th, 2008, 07:06 PM   #16 (permalink)
red_S
red_S's Avatar
Quote: Originally Posted by Benibiker (original)
I... Try it and see if it works for you, it's worth a try and it worked for me.
Hi!
Nice work. Could you post some more pictures ilustrating where you placed/attached the spring. I will certainly try it in the next days...
Regards,
Damir
Old May 7th, 2008, 04:39 AM   #17 (permalink)
Benibiker
Benibiker's Avatar
I bought the spring from a hardware store (Home Depot). Any hardware story should have them. It's just a spring with a loop or hook on either end. If it's too long you can cut it and just make another loop or hook the end.
I'll try to get some more photos, It's dark by the time I get home from work during the week. But it's pretty simple, just attach one end of the spring to the hole in the picture above and the other end to anything below it. I attached mine to the clamp on the rubber hose on the intercooler. That should give you just the right tension.
Old May 8th, 2008, 04:02 AM   #18 (permalink)
Benibiker
Benibiker's Avatar
Hey guys, unfortunately the noise came back... I had enough of searching and wiggling stuff around to find it on my own so I dropped it off at the dealer this morning. Hopefully they'll have better luck at finding it. I drove around with a technician and we duplicated the sound so they know it's there, the question is will they be able to fix it... I'll keep you posted.
Old May 9th, 2008, 05:42 AM   #19 (permalink)
Benibiker
Benibiker's Avatar
Wow, 3 posts in a row... What a joke, got my car back today, they said one of the hood bushings was out of alignment... I wasn't even a block away and heard the noise again. No fix, wondering if I should just live with it or take it back and risk them doing more harm than good by replacing all sorts of parts and not fixing it... What do you all think?
Old May 9th, 2008, 08:01 AM   #20 (permalink)
Boro Boy
That all depends on whether you find you can live with it ... some people are more sensitive than others to rattles, knockings, buzzings and clankings. I always try to sort them out myself first before resorting to taking the car to the dealer, but if I can't and the rattle is annoying enough ... to the dealer I will go.
Adding sport button on early R56 S Fredrik 2nd Gen MINI Cooper S 2 Jan 2nd, 2008 05:56 AM
Anyone buying a R56 (2007 MINI) bugiz Australia 428 Jul 19th, 2007 01:30 PM
R56 Week 23 Production 2007 howdyem Delivery, Shipping & Order Tracking 6 Jun 13th, 2007 09:36 AM
Saw My first R56 2007 Cooper S Blacky Australia 32 Feb 11th, 2007 10:17 AM
2007 R56 MINI Cooper - Who's with me ? smartbomb 2nd Gen MINI Cooper 1 Aug 24th, 2006 04:39 PM
