| Tags: signal programming |
| MINI Fan Join Date: Jul 2007 Location: Calgary, Canada Local Time: 04:17 PM
Offline | Turn Signal Programming I am trying to find out if the 2007 Mini's are able to have their turn signals programmed similar to that of any Bangle designed BMW. (New style 5 series and newer) What I am trying to find out is that on the BMW's you can touch the turn signal and the indicator will automatically blink 3 times (typically for lane changes). this would make it easier instead of holding the turn signal down (or up) to make a lane change. Seems that most BMW's in my area have this feature as well as a few loaners I have driven. Takes a bit to get used to, but is great once you have adapted to it. Thanks for the advice, searches were unsuccessful. |
| MINI2 Regular Join Date: May 2007 Location: Hong Kong Local Time: 06:17 AM
Offline | My R56 came standard with the short three times blinking with a little touch and constant blinking with a harder touch on the directions shifter. So, I assume you may be able to program it. |
| | #6 (permalink) |
| MINI2 Regular Join Date: Jan 2007 Location: Athens, Greece Local Time: 12:17 AM
Offline | As fellow members said, YES you can programme it to blinik either once or three times. It is done through the settings, when the ignition is on....refer to the manual for details. Same way you programme many features, like daylights, auto lock, follow-me-home lights etc. Caedite eos. Novit enim Dominus qui sunt eius. |
| | #8 (permalink) |
| MINI2 Senior Join Date: Apr 2007 Location: Glasgow Local Time: 11:17 PM
Offline | Very much doubt it... and you feel a definite progression from the 3-flashes to the older "on till steering wheel centres" function. Never heard of this feature on the r53's... |
| | #11 (permalink) |
| MINI2 Newbie Join Date: Jul 2007 Local Time: 11:17 PM
Offline | Well, I took delivery of my new Cooper last Friday. According to my dealer, from August onwards BMW have now programmed these settings with the most sensible defaults up front. So you'll probably find it does 3 flashes by default -- it did for me. Strangely, the options in the menu to change this didn't appear until I'd driven the car the 2nd time but as most of the options seem sensible, I confess, I've not had any reason to change anything. |
| | #12 (permalink) |
![]() Quack Quack Oregon Ducks Join Date: Oct 2006 Location: Oregon Local Time: 02:17 PM
Offline | The most sensible default would be to give us five flashes and eliminate the single flash. Three means you have to move pretty quick to get into the other lane. |
| Turn signal broken | tompr1 | Faults & Fixes | 1 | May 30th, 2006 05:00 AM |
| Hyperactive turn signal / turn indicator behavior | CooperCooper | Faults & Fixes | 3 | Mar 14th, 2005 11:15 PM |
| Broken turn signal socket?!? | naparish | Faults & Fixes | 2 | Apr 29th, 2004 09:05 PM |
| White rear turn signal | peppericee | Exterior | 7 | Dec 8th, 2003 11:44 PM |
| White Turn Signal in Front | 94SwiftGT | Exterior | 9 | Apr 13th, 2003 11:11 PM |
