Visit Derek Woodman MINI
Tags: , ,
Old Nov 10th, 2007, 11:03 AM   #1
adam_Randell
07' Cooper
adam_Randell's Avatar
Local Time: 11:16 AM
Send a message via MSN to adam_Randell
Air Bag Help! Urgent!
Hi guys. Think i just cut through my airbag cable.....
went to halfords to check a wire which i thought was my audio wire for the rear speaker, the guy said it was because german cars tent to have the cables wrapped round each other for the audio. Anyways, i come home to wire my amp in - by chopping this wire and wiring it to a converter. I choped it, wired it and turned the ignition on and the music was still coming through the speaker and a picture of a man in a seat with an aid bag came up on the dash. Can anyone help me!?
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Nov 10th, 2007, 12:35 PM   #2 (permalink)
adam_Randell
07' Cooper
Old Nov 10th, 2007, 12:38 PM   #3 (permalink)
Paul
Trained Monkey
Paul's Avatar
Afraid not. I'd suggest you wait for the ICE experts to pop-up before you do anything else though.
Old Nov 10th, 2007, 01:44 PM   #4 (permalink)
adam_Randell
07' Cooper
Old Nov 10th, 2007, 04:55 PM   #5 (permalink)
KenL
KenL's Avatar
Can you not just re-join it?
You could solder it back together or use something for joining wires together. You should be able to get something from Halfords or any car audio shop.
Old Nov 10th, 2007, 09:21 PM   #6 (permalink)
adam_Randell
07' Cooper
Yea, ive re connected them with the white electrical connectors but i thin kthe system may need re-setting. anyone know how much this would cost?
Old Nov 10th, 2007, 09:49 PM   #7 (permalink)
James
James's Avatar
hmm if its your airbags i'd get it sorted by BMW (which you would need to anyway to get the light reset), if they're stuck together using tape or something they could go off while driving..
Old Nov 11th, 2007, 11:10 AM   #8 (permalink)
adam_Randell
07' Cooper
ok cool. ill get in touch first thing tomorrow!
Old Nov 12th, 2007, 05:09 PM   #9 (permalink)
adam_Randell
07' Cooper
Took my car in to MINI today, and they said i couldnt get the wires repaired - id have to get a new loom - is this correct? he said it would cause too much resistance??
Old Nov 12th, 2007, 05:21 PM   #10 (permalink)
FergusM
FergusM's Avatar
Possibly correct, the system is probably sensitive...and doubt a set of white connectors will make an adequate connection. Possibly a very good auto electrician can do something ? Though whether they will want to touch it with being connected to an air bag is another question.
And to be honest you don't want to muck around with connections to air bags...implications of it going off at wrong time are too big to risk.
Guessing a new wiring loom is big ££
Scotland Male View FergusM's Dark Silver & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Nov 12th, 2007, 05:41 PM   #11 (permalink)
KenL
KenL's Avatar
This is most likely nonsense, There is no way you will need a complete re-wire.
I would try and find an experienced auto-electrician for their advice.
A proper re-join using solder will add an almost unmeasurable increase in resistance.
Old Nov 12th, 2007, 06:02 PM   #12 (permalink)
adam_Randell
07' Cooper
Ive just spoken to someone - he said that you can solder the wires back together and with a shrink soldering gun which reduces the resistance (apparently). Hes doine it in his Lotus and various other cars with no problems apparently.
Old Nov 12th, 2007, 09:22 PM   #13 (permalink)
mikeythemini
I can't get no sleep
mikeythemini's Avatar
Online
Yes you can solder them
Solder will make a better connection than the crap connectors all manufacturers use under the seats for airbags that cause a resistance & therefore airbag light errors
Old Nov 13th, 2007, 06:43 AM   #14 (permalink)
adam_Randell
07' Cooper
Awsome, im taking it to L&J audio to get it sorted! Thanks for all the advice guys
Old Nov 21st, 2007, 07:04 PM   #15 (permalink)
adam_Randell
07' Cooper
Hi guys. ive had the wires solderd and heat shrank, but the light is still on. do i have to get MINI to reset it or can i go elsewere?
Old Dec 12th, 2007, 01:23 PM   #16 (permalink)
rgn
Hi, have you still got the problem with the air-bag light?, only just seem your post! I have a reste tool (if your Mini is before 2003) and I'm only in Leigh Sinton, Nr Malvern
Old Dec 12th, 2007, 04:30 PM   #17 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
Depends where you cut it. If its in the section thats detachable then i believe the part is around £30-60. If its a whole new loom thats ££££££!
He is probably correct a repaired wire would probably continue to set the warning light off as it would see the power fluctation as a fault on the airbag line.
The light needs to be reset by BMW (or a friendly rich person with the right BCU reset tool) ... i believe BMW charge in excess of £50 but stand to be corrected I'm sure
Old Dec 12th, 2007, 04:32 PM   #18 (permalink)
adam_Randell
07' Cooper
Hi mate, thanks for the offer but its an R56!
Old Dec 12th, 2007, 04:33 PM   #19 (permalink)
adam_Randell
07' Cooper
I took it in and was supposed to be £40.99 but the ECU wouldnt talk to the diagnostics so they want to charge me £103.60+VAT per hour to find out how to do it and still charged me £40.99 today even though they didnt do anything!
URGENT need some help Minigirl18 Interior & Ice 4 Sep 17th, 2007 11:21 AM
Urgent - Please help! ChrisBuer General Discussion 6 Apr 18th, 2006 03:33 PM
* Urgent* Help needed!! Dez General Discussion 0 Oct 4th, 2005 07:16 PM
urgent help dundun Interior & Ice 4 Aug 29th, 2004 09:57 PM
Urgent Help!!!!!!! Phil321 Exterior 3 Oct 1st, 2003 03:43 PM
