Performance Torque
Tags: ,
Old Feb 28th, 2008, 05:17 PM   #1
astilla
Hmmmmm
astilla's Avatar
Local Time: 06:30 AM
Send a message via MSN to astilla Send a message via Yahoo to astilla
Bluetooth/USB - audio formats supported?
I'm picking my new Mini up on Saturday and it'll have the Bluetooth/USB kit installed. I'm just in the process of creating a memory stick from some of my iTunes playlists to keep in the car and suddenly wondered what audio formats the Bluetooth/USB supports - does anyone have a list please?
Most of my music is in AAC or MP3 with a few Apple lossless ones kicking around.
Thanks!
1988 Mini 'Designer' & 2008 MINI Cooper 'S' Works
Old Feb 28th, 2008, 05:52 PM   #2 (permalink)
rkw
Local Time: 10:30 PM
If you connect an iPod, it will play anything that the iPod can play.
If you are using some other mp3 player or memory stick:
The USB audio interface (SA 6ND, SA 6NE) supports the common compression formats MP3 (mp3), AAC (aac, m4a, m4b), WAV/PCM (wav) and WMA (wma, asf) as well as playlists in the M3U format.
United States View rkw's Pepper White & Black 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Feb 28th, 2008, 05:55 PM   #3 (permalink)
astilla
Hmmmmm
astilla's Avatar
If you are using some other mp3 player:
Excellent - thanks for the list :-)
Last edited by astilla : Feb 28th, 2008 at 06:01 PM. Reason: Not engaging brain due to lack of food
Old Mar 9th, 2008, 01:08 AM   #4 (permalink)
brett
1st MINI Owner in QLD !!!
brett's Avatar
Local Time: 03:30 PM
so , I have an Ipod with Itunes. If I was to save the Itunes My music folder to an external hard drive, I could plug it in and work. MY external hard drive has a external power point I was going to use a power invertor
Australia View brett's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 9th, 2008, 07:01 AM   #5 (permalink)
Stiggy
Automatic for the People
Stiggy's Avatar
If you boughtt your music from iTunes it will be copy protected, so that won't work. If they are plain MP3s etc. it should work.
United Kingdom Male View Stiggy's Sparkling Silver & Black 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Old Mar 9th, 2008, 07:49 AM   #6 (permalink)
rkw
Some people have experimented but not been successful at using an external hard drive. However, it has been reported that for a BMW (which should have the same or similar USB system), a hard drive works if reformatted using a special utility:
http://www.e90post.com/forums/showthread.php?t=80270
As Stiggy says, whatever music files you want to play must be unprotected. But if you already have an iPod, why not simply use it and bypass all these issues?
Old Mar 9th, 2008, 09:31 AM   #7 (permalink)
brett
brett's Avatar
an Ipod outputs in anologue, while hard drive is Digital.
Old Mar 9th, 2008, 10:10 AM   #8 (permalink)
adam_Randell
07' Cooper
adam_Randell's Avatar
Send a message via MSN to adam_Randell
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Mobile Phones Supported by Phone Kit kcollins 2nd Gen Interior & Ice 9 Jan 26th, 2007 04:03 PM
Audio - Where To Put It All? K-Mark Interior & Ice 2 Jul 13th, 2006 09:41 PM
JL Audio amp cooper7 Interior & Ice 0 Aug 8th, 2004 05:03 PM
help please new mcs audio babyblues Interior & Ice 1 Mar 24th, 2004 06:56 AM
Sat-Nav & Audio? diverse Interior & Ice 7 May 31st, 2002 06:08 AM
