Visit Out Motoring!
Tags: ,
Old Mar 9th, 2008, 01:44 PM   #1
genik
Local Time: 04:31 PM
flash blinking 3 times
Trying to make the flash indicator blink 3 times after one click, but cant. I follow the instructions as said on the manual, but cant find the flash indicator logo on the display. All only the time and date logos show up, after pressing the flash indicator leaver and nothing else! What im i doing wrong?
Old Mar 9th, 2008, 02:25 PM   #2 (permalink)
Martin F
Making it add up
Local Time: 05:31 PM
You need the ignition on to do this. Not necessarily with the engine running but it needs to be on
Old Mar 9th, 2008, 10:25 PM   #3 (permalink)
genik
But the ignition is on, if its not i wouldnt get any notifications! I can set time and date, therefore it is on!
Old Mar 9th, 2008, 10:28 PM   #4 (permalink)
supa-dupa-cooper
In S Club Heaven!!
supa-dupa-cooper's Avatar
Mine was only set at one flash when I picked up the car, but I soon changed it to 3 when I got home. Ive got the Sat Nav though, so programmed it easily through the Nav screen.
Do you just have the normal set up?
United Kingdom Female View supa-dupa-cooper's Chili Red & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Mar 13th, 2008, 08:20 PM   #5 (permalink)
Yoastie
http://www.mini2.com/forum/2nd-gen-i...lock-help.html
"you set the 3 flashes via the obc. Press and hold the computer button in, select Set/Info, select the indicator option, select the 3 flashes, again by holding in the button. All done, exit using Home and it should be set for auto 3 flash!!"
Thanks to Tiger3388 http://www.mini2.com/forum/members/41684.html
Old Mar 15th, 2008, 09:39 AM   #6 (permalink)
LizzyG
LizzyG's Avatar
You need to put the key in the slot and then press the start button but without your foot on the clutch, so not starting the engine. Then you can get into the full menu and change all sorts of things like doors locking automatically etc and also obviously the indicators. I changed mine to 3 flashes.
United Kingdom Female View LizzyG's Chili Red & White 2nd Gen MINI Cooper Profile   Reply With Quote
Old Apr 19th, 2008, 10:56 PM   #7 (permalink)
genik
Its not relevant but i believe that those 3 flashes are not enough for a safe turn or lane change. If i were to decide id set it for 4-5 flashes! What do you think?
Old Apr 19th, 2008, 11:06 PM   #8 (permalink)
JG02JSG
JCW Fitted
JG02JSG's Avatar
Send a message via MSN to JG02JSG
i do alot of motoway driving and 3 signals is plenty for lane change, and when iam turning i keep it on fully each to there own
Old Apr 20th, 2008, 11:27 AM   #9 (permalink)
andrewcregan
Andrew ATC
andrewcregan's Avatar
I would prefer 4 or 5 flashes, but I believe that 3 is the maximum
Old Apr 20th, 2008, 11:49 AM   #10 (permalink)
genik
yeah me too, i only hope there is a way to tamper minis software to make the 3 blinks to 4 or 5 that would be excellent!
Good times and bad times to buy and sell cars (esp MINIs)? Paul General Discussion 11 Dec 7th, 2007 03:24 PM
Cruise control blinking... worrferret Faults & Fixes 7 Dec 6th, 2007 09:50 AM
Blinking outside temp. reading MoMini General Discussion 26 Mar 28th, 2005 07:51 PM
Blinking indicators when unlocking Harry@Piekarnia Faults & Fixes 2 Feb 15th, 2004 07:44 AM
Blinking Indicators Eric Faults & Fixes 17 Jan 31st, 2002 03:55 PM
