Mini Pirate
Old Sep 3rd, 2008, 08:48 PM   #1
Matg28
Enjoying the new 'S'
Matg28's Avatar
Local Time: 01:06 AM
DIY Radio Service Menu (Hidden!)
Not sure if anyone's found this before....
I was chatting to an old mate the other night (who used to work in a mini dealership), and he said that there was a hidden service menu on the new Mini's..... - there's a sequence using the m button with the ignition on.
Well, here it is...
Key in slot
Ignition on (start-stop button pushed, but clutch up)
Turn stereo ON
Key out
Key in slot
Turn stereo OFF
Turn stereo ON
Hold "m" until the service menu appears, then let go.
(note, all this has to happen within 8 seconds of the stereo off)
Just be careful - there are some options that can be changed - use the right-hand +/- buttons to cycle the displays.
Interestingly, there is a software/revision display showing, so might be of use to someone....
Note - changing radio regions clears all presets, so be warned!
Old Sep 4th, 2008, 01:26 PM   #2 (permalink)
brett
1st MINI Owner in QLD !!!
brett's Avatar
Local Time: 11:06 AM
what changes are possible?
1968 Mk1 Morris Cooper S 1310cc Downton Lake Green - White
1974 Leyland Mini 1098c Country Cream
2008 MINI Cooper S Chilli Pepper White - Black Roof
Australia View brett's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 4th, 2008, 04:15 PM   #3 (permalink)
Lonz
Send a message via MSN to Lonz
Very interesting, not going to try it until I know what I can bugger-up!
Old Sep 4th, 2008, 05:19 PM   #4 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 08:06 PM
Online
What model MINI do you have? This is the one that sounds very familiar to the boost radio from the 02-06 and 07-08 cabrio. Typically you can turn the radio on and before pushing any other buttons simply hold the "M" button down for about 10 seconds. In the menu there are a few things that you can do...
1. Test the display.
2. Set speed setting sensitivity for loudness. (Non HK only)
3. Region setting
4. Signal strength
5. Fimeware version number (nothing that we can do with to date).
and a few others.... The region setting was handy for me as the USA only uses the odd stations to tune in. So, if you are in USA mode and in Europe, you can't get half of the stations. However, if you change that it changes the mode to allow the additional stations. Once you select what you want, you simply turn the radio off and on and all is well.
The radio on the R56 is supposed to be different. I have yet to try it so if someone will confirm it; it would be great to know.
Innovation doesn’t come from following the same path over and over.
Global Moderator
United States Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 4th, 2008, 05:31 PM   #5 (permalink)
Matg28
Matg28's Avatar
it's a 2008 S, born in April - standard CD/Boost (but soon to be enhanced with amp and speakers)
Had a bit more of a play today - from memory, the options are:
Firware/software version
display test - 7 options
aerial selection - auto/1/2/3
dsp/volume (mine simpy says DSP 0/VL xxx where xxx is the current volume)
signal quality - doesn't seem to ever change
frequency / rds check (updates in real-time - some changes are possible)
continent selection - EUR/USA/OCE/JAP
speed sensitive volume 0 to 5
Key Memory on/off
an interesting mode - Line Tool, RDS Tool, OS Tool....... haven't a clue what these do(!)
I think that was about it...
Oh yep - you can also do this with the engine runnning - just turn off the radio, turn it back on and hold m
Old Sep 5th, 2008, 03:26 AM   #6 (permalink)
DaFlake
DaFlake's Avatar
Online
As I mentioned I am curious if this is a cabrio... The cabrio's are based on the 02-06 build (supercharged and all).
Global Moderator
Old Sep 5th, 2008, 07:38 AM   #7 (permalink)
Matg28
Matg28's Avatar
It's not a cabrio - it's a 2008 S, hard-top.
Old Sep 5th, 2008, 05:08 PM   #8 (permalink)
Maxwell
Any suggestions for those who have the integrated NAV?
Line Tool, RDS Tool and OS Tool all sound very interesting....
Old Sep 5th, 2008, 07:26 PM   #9 (permalink)
DaFlake
DaFlake's Avatar
Online
Cool to know that the same information is available in the R56! Thanks for clarifying that.
Global Moderator
Old Sep 22nd, 2008, 04:33 PM   #10 (permalink)
Maxwell
Radio Service Menu - for Nav equipped Cars
Discussion at NAM - I would post the url, but I haven't enough post's yet.
Hat's off to my Canadian friend, Chernobyl for the information.
Quote: Originally Posted by Chernobyl (original)
Try this in a NAV equipped MINI to get into service mode (don't have NAV so I don't know if it works or not):
WDS Wiring Diagram System
The Service menu is called up as follows:
* Select the start menu.
* Press the controller for approx. 15 seconds, then let go.
* Turn the controller three positions to the right.
* Turn the controller three positions to the left.
* Turn the controller one position to the right.
* Turn the controller one position to the left.
The "start menu" is the four option menu (Navigation, Communications, Entertainment, Setup)
Old Sep 22nd, 2008, 05:09 PM   #11 (permalink)
Troy
Troy's Avatar
I had a go at that in my car, and it didn't seem to work. Don't know if I was doing something wrong, as you press the controller down it selects whatever you hover over as normal.
It's a Mini Adventure.
United Kingdom Male View Troy's Chili Red & Body Color 2nd Gen MINI One Profile   Reply With Quote
Old Sep 22nd, 2008, 05:35 PM   #12 (permalink)
Maxwell
Trying another tack with posting the url....
www (dot) northamericanmotoring.com/forums/showthread.php?p=2458066#post2458066
Thread title: MINI COOPER :: North American Motoring - RDS/PTY Questions
There seems to be a bit of art and timing to open the back door.
Old Sep 22nd, 2008, 08:09 PM   #13 (permalink)
nicknbecka
Local Time: 05:06 PM
Here's a clickable link- I tried it this morning and didn't get anything either. Someone else posted that they tried again from the setup menu and it worked. I guess I'll try that- or maybe my seconds are too long or something...
Curious if your cell works with the Second Gen MINI?
See the R56 MINI Bluetooth Cell Compatibility Matrix
Old Sep 23rd, 2008, 02:16 AM   #14 (permalink)
rellik666
Keeping The Top Off!
rellik666's Avatar
Send a message via MSN to rellik666 Send a message via Skype™ to rellik666
[quote=Matg28;3539437]
Well, here it is...
Key in slot
Turn stereo ON
Key out
Key in slot
Turn stereo OFF
Turn stereo ON
/QUOTE]
Didn't realise the Cabrio had a start/stop button!
OH MY OH MY! I own a Sidewalk!Almost.........
Australia Female View rellik666's Pepper White & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Sep 23rd, 2008, 11:51 AM   #15 (permalink)
brett
brett's Avatar
umm you could also press the speech button on your steering wheel and say service. that will pull up the service display to check control messages and service warnings.
Old Sep 23rd, 2008, 06:16 PM   #16 (permalink)
Maxwell
Not the same service menu. This menu allows for configuration changes in the radio stack. A number of US car have been delivered with the RDS set to Europe vs. the US. Access to the menu will preclude a trip to the somewhat limited dealer network.
Old Sep 26th, 2008, 08:05 PM   #17 (permalink)
Maxwell
It does work!
* Highlight the setup menu
* Press the controller for approx. 15 seconds, then let go. It will enter the set up options.
How do i tune the radio in? (Access OEM Hidden Menu) funkcityb Interior & Ice 4 Aug 1st, 2006 02:52 PM
H/K hidden prefs... barbaloot Interior & Ice 6 Jan 18th, 2006 07:33 PM
dsp vol setting on hidden menu (HK) MickyD Interior & Ice 0 Feb 3rd, 2005 11:10 PM
Hidden Sat Nav Setup Menu rjwhittington Interior & Ice 16 Oct 22nd, 2004 05:43 PM
