| MINI2 Newbie Join Date: Jul 2005 Local Time: 05:13 AM
Offline | 2007 S Drops Weight?!? From Gabe's Motoringfile.com it's reported the 2007 Cooper S will be 180 lbs lighter! http://motoringfile.com/2006/07/25/s...0lbs/#comments |
| | #8 (permalink) |
| MINI2 Regular | it also says power is going up to 175 for the msc. i thought it was widely accepted that it wasnt going up. be smashing if they were both true though ![]() http://www.myspace.com/scorpionking1982 People should not be afraid of their governments, governments should be afraid of their people |
| | #9 (permalink) |
| MINI2 Regular Join Date: Jul 2004 Location: Wisconsin Local Time: 12:13 AM
Offline | Despite my skepticism, 180 is not out of the question with the aluminum block and frame--does still seem a bit high though. Who knows, maybe the tires will be filled with helium this go round.... |
| | #10 (permalink) |
| MINI2 Regular | just realised how much 180lbs is, its like a whole person! that is rather a lot http://www.myspace.com/scorpionking1982 People should not be afraid of their governments, governments should be afraid of their people |
| | #11 (permalink) |
| Trained Monkey Join Date: Jan 2001 Location: Big grey box Local Time: 05:13 AM
Offline | In case you missed it, in our exclusive reports from the test drive Detlev Welter and his team confirmed the new Cooper S to weigh around 10kg more than the outgoing model.Sorry I couldn't confirm and clear this up earlier, but embargo times cant be broken. |
| | #12 (permalink) |
| Vroom! Join Date: Jul 2003 Location: Calgary, Alberta Local Time: 10:13 PM
Offline | Oh thats too bad, I thought the aluminum block would help matters a little. From the press release the Cooper would be a tad bit lighter than the current model, that would be nice, although HP and torque remains pretty much the same (but it does have 6spd instead of 5 for the Cooper). Sounds like the cooper's performance would only be marginally better than the current model. |
| | #14 (permalink) |
| MINI2 Regular | i better get down the gym and lose 10kgs then, even things out ![]() http://www.myspace.com/scorpionking1982 People should not be afraid of their governments, governments should be afraid of their people |
| | #15 (permalink) |
| Countdown to Ecstacy Join Date: Apr 2006 Location: Indy Local Time: 01:13 AM
Offline | one of the artilces mentioned that bmw touted the weight savings as offsetting new structure stiffening and crashworthiness improvements for a zero net impact. ( 10 kg is zero for all intents and purposes ) 06 MCS JCW PH/PH premium, sport, webspokes, black leather, anthracite dash and headliner. |
| | #16 (permalink) |
| MINI2 Regular Join Date: Jun 2006 Local Time: 07:13 AM
Offline | The new engine has a lot more torque at lower and higher engine speeds, because of the double vanos and valvetronic. I'm positive it will be noticibly faster. The old Cooper only had a peak at 4500rpm, and doesn't pull well below 3000rpm. The new one will be different. Maybee the torque curve will even bee flat (which would spoil some of the fun). The new engine's will have a higher compression ratio: Cooper: 11:1 CooperS: 10,5:1 Which will bee good for fuel consumption. Variable oil pump, which save's up to 1,25kW |
| SCCA Drops Stage Rally Program After 12/31/04 | Dave&Stacy | MINI in Motorsport | 1 | Oct 26th, 2004 09:38 PM |
| How to Remove Emulsion Paint Drops from Bodywork?? | AidenL | General Discussion | 26 | Jul 14th, 2003 09:04 AM |
