Performance Torque
Old Jul 27th, 2006, 01:39 AM   #1
Wooly
Mad fer it
Wooly's Avatar
Local Time: 06:15 AM
Gearboxes.
Sorry about this, second topic in a matter of seconds
Activating the sports switch, the driver is able to enhance the highly dynamic qualities of the car to an even higher standard by shifting gears even faster in this special Sports Mode. A further benefit is that the driver is now able to shift gears manually by means of paddles on the steering wheel, like in Formula 1. In other words, the driver is not required to take his hands off the steering wheel when shifting gears and is able to fully concentrate on the process of controlling his car especially in an extreme situation.
so just to clarify, all manual models will have 6 gears, there will a normal automatic with that 5 clutch thing, and above with the paddles. the paddle one, will it be incorperated with the cvt transmission so you can either flick it to auto or you can use the paddles? (i dont know anything about the current cvt it might already be like that )
oh, and i havent found out who are supplying the gearboxes, who are making them?? is it still clunky and a bit stiff to change.
oh, im on mini overload at the minute
Old Jul 27th, 2006, 01:45 AM   #2 (permalink)
Paul
Trained Monkey
Paul's Avatar
Local Time: 05:15 AM
The new manual 6 speed set up felt pretty much identical to the current set up, although the throw actually seems maybe a little longer, but not by much.
Not CVT, just automatic, and yes, the current Cooper S already has this type of function.
Old Jul 27th, 2006, 06:53 AM   #3 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Also it only says the Cooper and S will have six speed and doesn't specify anything about the One at the moment.
It was acceptable in the 80's
England Male View Root Ginger's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 27th, 2006, 12:56 PM   #4 (permalink)
Zipperblues
Zipperblues's Avatar
Local Time: 01:15 AM
Send a message via AIM to Zipperblues
No more getrag?
Old Jul 27th, 2006, 02:52 PM   #5 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 09:15 PM
Quote: Originally Posted by Zipperblues
No more getrag?
The post originator is talking about an automatic ... I'm sure the manual will be a Getrag
Old Jul 27th, 2006, 03:50 PM   #6 (permalink)
Zipperblues
Yes, but they didn't mention a getrag anywhere in the press release, and this used to be a big selling point. They also said that the car was completely redesigned--it seemed to imply that the gear box was different.
Any issues with gearboxes on R56 Goonery 2nd Gen Faults & Fixes 10 Aug 22nd, 2007 09:41 PM
gearboxes and clutches johnlummis Faults & Fixes 0 Mar 7th, 2006 01:46 PM
Changing 5 speed gearboxes - Midland to Getrag - Will it work!? jasonfields007 Faults & Fixes 7 Apr 30th, 2005 10:53 AM
Mini Gearboxes: Getrag 5 Speed - new in 2004 Pritch Future Variants 16 Jul 24th, 2004 06:47 PM
New Engines & Gearboxes Jupiter General Discussion 1 Jun 18th, 2004 12:52 PM
