Visit Mini Mania UK
Old Sep 18th, 2006, 09:38 PM   #1
Berger
Berger's Avatar
Local Time: 06:19 PM
When to change oil..?
I've driven my 03 MCS 10.000 kms since I last changed the oil. However, the speedo tells me that there is approximately 15.000 kms until next oil change.
Can this be correct? I've usually changed every 10.000 kms on my previous cars, so I find it a bit strange to be driving 25.000 without doing anyting...
Norway   Reply With Quote
Old Sep 20th, 2006, 10:26 PM   #2 (permalink)
MarkL
MarkL's Avatar
Local Time: 07:19 PM
In general, yes, just make sure you check the oil level regularly and top up if necessary.
However, oil does age, so you should change it every two years, at least.
United Kingdom Male View MarkL's Lightning Blue & White 2nd Gen MINI Cooper Profile   Reply With Quote
Oil Pressure Light After Oil Change tpwmini Engine & Drivetrain Tuning 6 Apr 20th, 2005 02:50 PM
Oil Pressure Light after Oil Change tpwmini Faults & Fixes 0 Apr 16th, 2005 03:46 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
oil cooler-Does it drain when when having oil change? yorobby MINI Cooper S 4 Sep 29th, 2004 12:00 AM
First oil change> Do I have to drain oil cooler ? yorobby Maintenance & MINI Care 3 Sep 26th, 2002 07:44 PM
