| Tags: questions |
| MINI2 Regular Join Date: Jul 2005 Local Time: 06:22 AM
Offline | some quick q's just some quick q's: 1. when you open the window, it automatically goes all the way down unless you tap it up, but then if you want it to be a certain amount open, it is impossible to get it to the way you want it. how can i make it go down/up bit by bit? 2. when you unlock the car, how can you make the front two reading lights turn on automatically? i've tried some settings but for some reason when i lock the car, the lights stay on?! 3. just making sure as this is my first mcs- when in stationary the engine sounds a bit like a diesel, is this right? |
| Trained Monkey Join Date: Jan 2001 Location: Big grey box Local Time: 05:22 AM
Offline | 1) If you "tap" the window switch it goes into "all in one" mode, if you press and hold it it will only move until you release the switch. 2) I don't think there's a way to switch the reading lights on, the interior light (central) etc should come on, but not the map reading lights. 3) They do a bit yes. |
Offline | thanks paul, i'll give that a try yes, the centre light comes on i also get the hissing sound even after the car is off for about 15mins so it must be cooling down? also, for the start/stop button, do you have to hold it down or just press it and let go? (just making sure as i don't want to ruin anything) also, i was told to put the clutch down before you turn on/off the car, is this necessary as i didn't do this before? |
| New Member with a few q's | mikeossy80 | General Discussion | 11 | May 7th, 2007 07:42 PM |
| newby Q's | lucifuge | General Discussion | 4 | May 1st, 2007 04:19 PM |
| many q's re: MINI | ProV1 | MINI Cooper | 8 | Dec 22nd, 2003 04:33 AM |
| Hello! & Q's | Also Rich G | Engine & Drivetrain Tuning | 9 | Dec 6th, 2002 01:56 PM |
| Hi from a new member and Q's | Matblack | General Discussion | 2 | Oct 31st, 2002 08:27 AM |
