Carccessory.com
Tags: ,
Old Feb 27th, 2007, 10:43 AM   #1
kcollins
Kaptain Krutaroo
Local Time: 05:23 AM
Send a message via AIM to kcollins Send a message via Yahoo to kcollins
United-States Krut's R56 - DYNO'd
Hey all, my mates at Helix in Philadelphia wanted some baseline results with an R56 - so I volunteered to drive from DC to Philly (got 41.3 mpg in the process) and we threw my R56 on the dyno.
The results are pretty good and it looks like BMW under-reported the HP numbers. Take the figures for what it's worth. Results posted on NAM. - complete with a Youtube video!
Kaptain Krutaroo - Kurt Collins - Washington, DC
#8 2009 MINI JCW CR/B
United States Male View kcollins's Chili Red & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Feb 27th, 2007, 12:18 PM   #2 (permalink)
Olly.
Overboosting.....
Olly.'s Avatar
Local Time: 10:23 AM
Excellent thanks for postting them up, seems to be the first dyno we've seen of a stock car.
Excuse my complete ignorance here as I know nothing about dyno's or how they report there stats but that seems to suggest 160bhp which is less than the 175 quoted by MINI?
Or am I missing something?
Old Feb 27th, 2007, 12:27 PM   #3 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 02:23 AM
The dyno figures are for horsepower at the wheels not the crank
Old Feb 27th, 2007, 12:36 PM   #4 (permalink)
jay_tuck
jay_tuck's Avatar
Local Time: 04:23 AM
Yeah, with a modest 12% drivetrain loss I came up with 180.5 Hp. Very nice!
Currently: 2002 VW GTI.
Old Feb 27th, 2007, 12:38 PM   #5 (permalink)
Olly.
Overboosting.....
Olly.'s Avatar
Ah I see that would explain it, thanks MINIAC
Old Feb 27th, 2007, 12:49 PM   #6 (permalink)
Paul
Trained Monkey
Paul's Avatar
Now those are sexy curves.
In car terms, of course...
I love the torque curve on the new S..... Up, up, and awaaaaaaaaaaaaaaaaay!
Old Feb 27th, 2007, 02:49 PM   #7 (permalink)
Tonyt3
Track addict
Tonyt3's Avatar
Would be interested to see the results with the 'sport button' pressed.....
Old Feb 27th, 2007, 02:55 PM   #8 (permalink)
Tonyt3
Track addict
Tonyt3's Avatar
So, bit confused. Is this a good graph or not? I thought that the bhp line should be straighter, and would peak higher than 6k rpm, and the torque 'curve' has a rather ugly roller coaster ride - meaning the car only truley performs well at around 4500 rpm.... and then drops quite markedly from 5200 rpm upwards.....
Is this normal with turbo engines> ? The lines on my supercharged engines' dyno plot were a lot more 'constant' in terms of availabe torque and progrssive power delivery....
Old Feb 27th, 2007, 02:56 PM   #9 (permalink)
Paul
Trained Monkey
Paul's Avatar
The sport button would make very litle difference really as all it does is adjust acceleration in relation to the peddle, it doesn't change the performance so to speak. It changes the revs of the engine in relation to the pedal position, not the power of the engine in relation the revs.
Old Feb 27th, 2007, 03:17 PM   #10 (permalink)
jay_tuck
jay_tuck's Avatar
I have limited experience with dyno's (I've only done my car three times) but that is a good chart. Turbo engines (small displacement ones anyway) seem to deliver peak torque sooner and for longer then a N/A or a SC engine which build to a peak. So this is pretty typical.
What's really good about this chart is that peak torque, most likely more the Mini claims apparently, is delivered in full from ~1900 RMP through ~5200 RPM. My experience with my GTI is that it's torque was delivered in more of a curve, which is less exciting. Yes, there is a little wavering, but it's not that signifigant. Large waves would indicate a bad air / fuel ratio.
It would be interesting to see the A/F. I wonder how rich the R56 runs?
Old Feb 27th, 2007, 03:20 PM   #11 (permalink)
Ryephile
Deals Gap Junkie
Ryephile's Avatar
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
Take a look at MINI's published crank HP and lb-ft figures. Krut's dyno pull shows the torque curve is very close to advertised considering the measurements are not SAE corrected to the environmental conditions. The roller coaster ride, as you put it, it hardly dramatic, but what it means is the car has way more torque at lower RPM than the R53. It also means the boost controller of the stock R56 isn't as damped as it could be, but as you can see above 5,000 RPM, the boost is controlled very well and consistently.
Also, like Paul said, the Sport button DOES NOT impact actual power output, only the steering boost level and the throttle pedal actuation curve & sensitivity. The throttle end points are the same, meaning that if you floor it, the engine is floored; it doesn't matter if the sport button is pushed or not. Roland of GTT already proved the sport button makes no impact on acceleration times.
United States View Ryephile's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 27th, 2007, 03:52 PM   #12 (permalink)
wow
Local Time: 11:23 AM
I v=cannot find the results or graph. Please post it on this forum
MINI, it is a way of life.
South Africa   Reply With Quote
Has anyone had their GTT210/220 Dyno'd? Cooooooperslad Engine & Drivetrain Tuning 26 Sep 6th, 2007 04:41 PM
Krut's LB/B R56 - Delivered! Finally! kcollins 2nd Gen MINI Cooper S 12 Feb 26th, 2007 08:45 PM
where to go to get dyno'd? nell Engine & Drivetrain Tuning 6 Nov 4th, 2005 06:58 AM
Superchipped and Dyno'd matt21 Engine & Drivetrain Tuning 15 Jul 1st, 2005 10:42 PM
Has Anyone Dyno'd a K & N Typhoon on and MCS? MINI-MA Engine & Drivetrain Tuning 3 Mar 27th, 2004 10:36 AM
