| Tags: cooper, coopers, turbo |
| MINI2 Regular | Not Run In Properly I was just wondering what the effects of not running in a car properly are???? Anyone got any ideas?? |
| | #6 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 07:04 PM
Offline | Basically you'll find that its possible the car won't last as long...but your talking about the difference between the car needing significant engine/ancilleries work at 100,000 or 200,000 miles ... You'll still get good miles out of it before it played up (or you should but from what i've heard of the R56 running in etc might not make a difference ) You'll be fine....and like above if you run it hard from factory then in faxct th engine often performs better, but won't last as long (race engines are prepped like that as they are stripped so regular) |
| | #12 (permalink) |
| MINI2 Senior Join Date: Dec 2006 Location: Wales Local Time: 07:04 PM
Offline | If you truly appreciate your car, then you will run it in according to the manufactures instructions. In the case of the Mini the you should not exceed 4500 revs for the 1st 1500 miles, which is not too much to ask. Remember there are countless other new moving parts that need to bed-in, including brakes, gearbox, transmission and tyres. |
| Now youve seen the R56 properly | supa-dupa-cooper | General Discussion | 292 | Feb 24th, 2007 04:03 PM |
| Alloy Not Fiited Properly | rossko | Wheels, Tyres & Brakes | 6 | Mar 9th, 2006 06:53 PM |
| Does anyone know how to do this properly? | Francesco | Suspension | 4 | May 30th, 2005 05:34 PM |
| hatch not shutting properly? | JBean | Faults & Fixes | 6 | Dec 3rd, 2002 05:50 PM |
