| Tags: airscoop, coopers, mistery |
| MINI2 Newbie | Air Scoop mistery Have you already noticed that the last Cooper Ses sold have got a real air scoop over the bonnet? I have discovered that the air scoop is no more a fake... Mine is a fake but others are real... Obviously I've asked for the replacement of the grill with a new one and I'm waiting for the delivery... But the question is ... WHY? ![]() Last edited by MINIAC : Mar 18th, 2007 at 07:47 PM. Reason: shouting |
| MINI2 Regular Join Date: Mar 2007 Local Time: 02:12 AM
Offline | I believe All of them are closed, but if you want to open them up then you can. When I was looking at one, it was closed by a piece of fabric, but that can be easily taken off. All new R56 Cooper S don't use that air intake. The new turbo engine has its air intake from another part. They kept the air scoop just for cosmetic reasons. |
| | #7 (permalink) |
Offline | Yes, there is a grill in the scoop but if you open up the bonnet then there is a thick layer of felt/material that is attached to the inside of the scoop. I guess you can take this off, or take the grill off, but that is how it comes standard here in the US. Turbo engine doesn't use this scoop for air intake. |
| | #8 (permalink) |
| An idiot breaking his car Join Date: Nov 2004 Location: Euphoria Local Time: 02:12 AM
Offline | The plastic mesh grill is only held in place by a few plastic screws (i think; didnt really get a great view at the dealership). Easily removable. It has no true function. However, even though it won't aid in cooling the engine all that much, I'll be taking mine off when I get it. Every little bit helps. ![]() |
| | #9 (permalink) |
| I'm Back! Join Date: May 2004 Location: Kernow, near England Local Time: 07:12 AM
Offline | Why open up a high pressure rain inlet just above the HT leads and associated electricals? Engine cooling really isn't such a hit and miss affair. Opening up random holes in the bonnet is just a likely to hinder as help with cooling. One of the problems with radiators is allowing sufficient warm air to escape from the rear of the radiator to allow more cooling air to take its place from the front. Adding additional air pressure behind the radiator isn't going to help, its more likely to allow a way for a small proportion of the cooling air to bypass the radiator altogether. Tigger. ![]() Unintimated and I'm back!! ![]() For sunshine, fun and Cornish Pasties: New MINI Kernow Cornish Oggy Run 2009! |
| | #11 (permalink) |
| MINI2 Senior Join Date: Aug 2006 Location: Pacific NW Local Time: 12:12 AM
Offline | Yep. Some of the most recently delivered cars have sections of the honeycomb insert that are not blocked off whatsoever. I've seen three or four that way as well as some pics on NAM. ![]() Founding member of R56 Anonymous: "Hello. My name is Mike. I'm a driving enthusiast... and I still like the R56" |
| | #12 (permalink) |
| MINI2 Regular Join Date: Nov 2006 Location: Middlesex Local Time: 08:12 AM
Offline | i would urge new MCS owners not to mess around with the scoop grill. Removing the grill would not only allow rain/water to enter the engine bay, as an earlier post has already pointed out, potentially causing harm to the electric, increasing corrosion etc. but also make it susceptable for unscrupulous, adolescent characters to insert all sorts of crap into the engine bay via the scoop hole - imagined what a few crushed tin cans loose in the engine bay would do!! Plus, for those who cannot fathom why BMW put a non-functional scoop in the new MCS, it is basic marketing and there simply as one product feature to differentiate the model from the range. If there are owners out there who cannot accept a cosmetic-only scoop on their MCS, then they can always retro fit a cooper bonnet!! ![]() |
| | #13 (permalink) |
| MINI2 Newbie Join Date: Jan 2007 Location: Cheshire Local Time: 08:12 AM
Offline | I took delivery of my new MCS yesterday evening (WOW what a car, spent all night driving it, lol) I can confirm that the scoop on mine does have parts where it lets air in, its not completely blanked off. the black honeycombe is still in there but it has sections that are open. I have not removed anything or tampered with it, this is how it came from MINI. Will |
| | #15 (permalink) |
| MINI2 Regular Join Date: Nov 2006 Location: Essex Local Time: 07:12 AM
Offline | Its not messing with it since my new MCS has a patially open scoop also! So I dont think its going to let any "killer rain" in, dont for get theres a massive hole beneat the engine so its not exactly watertight to start with ![]() |
| | #16 (permalink) |
Offline | that's the point, it's partially open, only. The holes are not big enough to allow bits of junk to be inserted into the bonnet bay should someone want to. Other forum users are talking about removing the whole black grill inside the scoop -that is a different matter to what you have. The underside of your car has a protective undertray to protect all the components and deflect water away from the engine and electronics -so were not saying the engine compartment is water-tight, but designed to work in moisture free, dry conditions. You try pouring a glass of water over your spark plugs- see what thay does to your engines performance! |
| GP Scoop/Air Intake??............Or not...... | mGP | John Cooper Works & GP | 5 | Sep 26th, 2006 01:56 PM |
| Union Jack Air Scoop | poppet | Exterior | 5 | Apr 18th, 2006 06:19 PM |
| BBR venturi scoop, M7 Scoop air divertor | speedman | Engine & Drivetrain Tuning | 16 | Jul 8th, 2005 09:32 AM |
| Official: Carbon Air Scoop | Minty | Exterior | 14 | May 22nd, 2005 10:58 AM |
| Aftermarket bonnet air scoop | lusomini | Exterior | 2 | Oct 28th, 2003 05:22 AM |
