Visit Lohen!
Old May 15th, 2007, 06:06 PM   #21
BMWF1
Zoom Zoom
BMWF1's Avatar
Local Time: 10:28 PM
If the sport suspension includes firmer sway bars and stiffer springs and/or shocks then what they are charging (at least here in the US) is very fair. But if it is only thicker sways then I can get it done much cheaper (and with thicker bars) than what MINI charges. It would be very interesting to know the exact spec differences if anyone knows them.
Very Proud Owner of a 2006 Mazda MX-5 GT 6-Speed Manual
Mods: RoadsterSport exhaust, MAZDASPEED intake and springs, Aluminum dash and pedals, Voodoo
United States View BMWF1's Pepper White & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 15th, 2007, 10:41 PM   #22 (permalink)
cristo
BLIKSEM (my brg/brg mc)
cristo's Avatar
Local Time: 12:28 AM
Quote: Originally Posted by BMWF1 (original)
Do you have any confirmation of this? If so, what are the spec differences?
as per post 16 on this thread
copying from a previous thread (post#63):
http://www.mini2.com/forum/2nd-gen-w...ml#post2898293
According to the realoem site, ( RealOEM.com Online BMW Parts Catalog )
the Cooper R56 has
a 23.5 mm front bar and 18 mm rear bar for Sport Suspension, and
a 21.5 mm front bar and 16 mm rear (same part number here as the 1st Gen SS bar)
for regular (non-Sport).
The Cooper S R56 has a
a 23.5 mm front and 18 mm rear bar for Sport suspension, and
a 22.5 mm front and 17 mm rear bar for regular (non-Sport)
They also list different strut part numbers for the regular vs. sport suspensions.
realoem doesn't list spring applications, but I'd be willing to bet they're different
for the Sport vs. the regular for the R56.
They're different for the R53 MC vs MCS vs One as per my BMW/MINI ETK cd-rom.
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile   Reply With Quote
Old May 16th, 2007, 12:37 AM   #23 (permalink)
BMWF1
Zoom Zoom
BMWF1's Avatar
Thank you for the information, however, I am looking specifically for the spec differences between the claimed firmer shocks and springs rather than the spec differences between the anti-roll bars.
Old May 16th, 2007, 01:51 AM   #24 (permalink)
Bhatch
Hi,
I just wanted to let you all know that 1mm on the outer diameter does alot for stiffness of the suspension.
twist = (2 x torque x length)/(p x diam4 x material modulus)
if we assume the same material is the same, we can basically say that the torsional rigidity is a function of the diameter to the 4th power..
So on the sports suspension on a MCS;
22.5^4 / 23.5^4mm = 84% stiffer.
and for the rear
17^4/18^4 = 79% stiffer.
Which i am sure they put alot of engineering into knowing that this is the correct amount of sway bar for the car. From my experience As a person who used to SOLO2 (autocross) short wheel base civics i think that 19mm is the most you should go anyway on that wheel base.
Anyway when i order my MCS at the end of the year i will get the sport package and put Koni Yellows on it.
Canada Male   Reply With Quote
Old May 16th, 2007, 02:43 AM   #25 (permalink)
cristo
cristo's Avatar
Actually,
23.5^4 / 22.t^4 = 1.19 or 19% stiffer
18^4 / 17^4 = 1.26 or 26% stiffer
Regarding data on shock performance, I have seen a bunch of shock dyno curves
on vwvortex.com (mostly about aftermarket shocks, but some stock curves),
but never on a MINI site.
Spring rate data on MINI stock and aftermarket springs is also quite sparse.
Whiteline anti roll bars Pobsey Suspension 5 Jun 15th, 2007 02:03 AM
Whiteline anti-roll bars? jobg Suspension 1 Feb 23rd, 2006 08:44 PM
Roll Bars, are they really outside? barbaloot MINI Convertible 16 Jul 8th, 2005 09:10 PM
Chrome Roll-over bars Kinster MINI Convertible 15 Aug 24th, 2004 09:39 AM
