| MINI2 Regular Join Date: Nov 2006 Local Time: 07:49 AM
Offline | Service Indicator I have covered just over 2000 miles since getting the MINI and the service indicator is showing 20000 to go. So, I make that 22K miles before service - sounds like a lot of miles to me !!! Are your service interval counters decreasing at all? |
| MINI2 Regular Join Date: Nov 2006 Location: Oxfordshire Local Time: 06:49 AM
Offline | My service indicator has also gone up from 19,000 miles to 20,000 miles. Apparently the sensor 'self-adjusts' to reflect how the car is being driven (i.e. if you drive gently, the car will be under less strain and thus require servicing less often). If you have been running the car in, then you probably have been driving gently so it is not surprising the interval has gone up. In any case, I think a first service at around 20,000 miles is ridiculous. For some people this would not happen for 2,3 or more years. Think how dirty things like oil, fluids and filters would have got by then! |
| MINI2 Newbie Join Date: Mar 2004 Local Time: 07:49 AM
Offline | I change my oil every 12 months regardless of mileage (using mobil 1), and i only do about 6,000 miles per year. I'm of the opinion that you can't look after your engine too much ! You work hard to pay for your mini, look after her ! ![]() |
| MINI2 Regular Join Date: Jan 2007 Location: Athens, Greece Local Time: 08:49 AM
Offline | I never went by the service indicator to my previous cars (BMW's)....I change oil and filters every 12 months (as I do about 5-7.000 miles/year) and I follow the service indicator only for the major service. Also, even if the oil can last for 20K miles, it is recommended to change it every 12 months (BMW used to say in the manual that regardless of the Service Indicator you should service the car and change oil every 12 months, even if you have done less miles than the ones required for service). I intend to do the same with the MINI. Change oil & oil filter every 12 months, and the rest whenever the Service Indicator says so. Caedite eos. Novit enim Dominus qui sunt eius. |
| Making it add up Join Date: Apr 2006 Location: Sussex Local Time: 06:49 AM
Offline | Yes, mine started at 19,000 and after about 3,400 miles is now showing 20,000. I begin to think it will never need an oil change on TLC! I shall have the oil changed after 12 months at my own expense anyway. I only do about 6,000 miles a year. |
| | #6 (permalink) |
| MINI2 Master Join Date: May 2002 Location: Edinburgh Local Time: 06:49 AM
Offline | I think the indicator must be reporting the mileage the service will take place at. In my car it is now saying 21k miles even though I have already covered 2.3k. When I collected it with 10 miles on it it said 19k. Red/Black R56 Cooper |
| | #8 (permalink) |
Offline | Yes I know, this has been discussed before on here. Wouldn't it be nice if someone from MINI would come on here and post answers to these anomalies ![]() Red/Black R56 Cooper |
| | #10 (permalink) |
| MCS/JCW Join Date: Feb 2007 Location: London/Nottingham Local Time: 07:49 AM
Offline | I believe the mileage indicator fluctuates according to how hard the car is driven, therefore if driven hard the distance to the next service is reduced accordingly, however if it fluctuating up and down regularly maybe worth having it checked. |
| | #12 (permalink) |
| MINI2 Regular Join Date: Nov 2006 Location: Middlesex Local Time: 07:49 AM
Offline | for low mileage users like myself, I would service the car according to the suggest date which shows 12/2008, rather than follow the suggested service mileage on the OBC. incidently, when i picked up the car, it should 19k, now shows 21k. which perhaps reflects my gentle run-in....i expect this to drop from here on as I plan to 'give her the beans' more often ![]() |
| | #17 (permalink) |
| MINI2 Regular Join Date: Apr 2002 Location: near Chicago, Illino Local Time: 12:49 AM
Offline | Since mid-April when I picked up my '07 S its SI is still reporting 17,000. That's after ten weeks & over US 5,000 miles of 85% hiway motoring. I'd been wondering about asking The Dealer if this is 'normal' but then found this thread. |
| | #18 (permalink) |
Offline | So, your service indicator is coming down as you drive and looks like your service will be at 9 + 13 = 22k miles? I have done 5k miles but the service indicator is sitting at 21k and hasn't moved for a few thousand miles. I was convinced the miles being displayed were the miles AT service, not the miles TO service. Now, I am really confused ![]() Red/Black R56 Cooper |
| | #19 (permalink) |
Offline | Down, not Up. The OBC on my first S (9/2002 build) declined as the miles went under its tires, 'till it passed 0... then the negative numbers started. I'd have to believe BMW hasn't changed their thinking about how the software should work on the R56, unless I read somewhere (like the manual, maybe? ) that it's different from the earlier programming in some meaningful way. |
| Service Indicator Help | burns863 | Faults & Fixes | 2 | Dec 14th, 2006 10:14 AM |
| service indicator | Gr1zzLy | Maintenance & MINI Care | 10 | Jan 12th, 2006 01:23 AM |
| Service Indicator | Cooper86 | Faults & Fixes | 4 | Dec 9th, 2005 02:12 AM |
| newbie question: where is the service indicator and service countdown metre?? | oceanstarBug | Maintenance & MINI Care | 3 | Mar 14th, 2005 09:59 PM |
| First service and service countdown indicator | jpb2001 | MINI Cooper S | 13 | Apr 20th, 2004 01:35 PM |
