| MINI2 Senior Join Date: Apr 2003 Local Time: 08:29 AM
Offline | Torque Steer Concern and questions Hi MINIers, i have had my R56 S for 3 weeks now and i have put 3500kms on it. Now that i am pushing the car all the way up the REV range i am noticing alot of torque steer that results in me struggling to keep the car straight when accelerating from standstill or in corners. 1) Can someone tell me how to handle a car in this situation? 2) Would the Limited Slip Dif eliminate the torque steer? 3) The R56 S is boarderline maniac in terms of torque steer what will it be like with the JCW performance kit on? 4) i do not have the sport button but if i did would it help? 5) Am i the only one noticing it? Thanks all MINI, it is a way of life. |
![]() JCW Driver | i found this on the test drive i had i think you have to be gentler on the accelerator or gradually increase the power and not stamp on the pedal. mind you im no expert hopefully some one will have a better answer Torque steering - Wikipedia, the free encyclopedia bit of info there |
| Malcolm | Surprising as the old S was excellent re torque steer. I have an 04 with GTT conversion and there is absolutely no torque steer whatsoever, unlike my SAAB which has only 195BHP but if you floor it th ewheels try to go allover the place. Does the R56 have that much more torque than the old S. |
| | #6 (permalink) |
| MINI2 on order! | i read a review of the cooper s against the new clio 192 on msn cars and they commented on how much torque steer there was on the cooper s First Drives | Reviews | MSN Cars UK - Mini Cooper S test |
| | #8 (permalink) |
| MINI2 Regular | I have an R53 with quite a few mods and push it very hard. I have never found torque steer to be a problem. I did however meet an old friend who is a mini salesman when I was in Cooper Croydon (havent seen the lad for years). He whispered that he found this to be one of the worsat problems with the R56. ![]() |
| | #9 (permalink) |
| MINI2 Regular Join Date: Nov 2006 Location: Middlesex Local Time: 07:29 AM
Offline | Sport button makes the steering heavier, so can afford more stability when you are putting down the power. It won't eliminate the torque steer completely, however. I understand the SA versions make not have this feature as standard. This issue does demonstrate how much torque the new R56 MCS has for such a small car - that's what makes it lairy, and a bit hairy-chested as a hot-hatch, at times. What I would recommend is to respect this power and try put the power down progressively - if you turn ASC&T off the front wheels will spin and smoke at will (I've even experienced wheel spin at 30-40mph). It's a matter of respecting (and accepting) the laws of physics. You have a small, light car with a lot of power, driven through the front wheels. If you try apply too much power too soon, you will reach the grip limits before you know it. You could try putting wider tyres on the car (for more grip) but you will affect the handling and feedback - it won't feel as direct and nimble. My last words: respect the power ,and accept the issue of torque steer as a small price to pay for such a nimble and fast front wheel drive car. ![]() |
| | #10 (permalink) |
| MINI2 Regular Join Date: May 2004 Location: Winsford,Cheshire Local Time: 06:29 AM
Offline | I've only had my Cooper S for 2 days and i already think it has more torque steer than my last 3 cars which were a Focus ST, Golf GTI and Works S, but i always thought the steering on these cars was massively over assisted and the steering felt wooly and provided very little feedback to the driver. The new S Steering feels very positive and has great turn in and offers lots of feedback especially when the sport button is pressed. Steering on a powerful FWD car is always going to be a bit of a compromise, but i think the new is just about spot on. |
| | #11 (permalink) |
| The Stig's Dad Join Date: Mar 2007 Location: North West UK Local Time: 07:29 AM
Offline | As those above have commented, torque steer is always evident to some extent in 'pocket rockets' and, even though it can seem quite alarming to some, it's always going to be there to some degree. The Sport button livens-up the steering and throttle response - you may find it more to your style to leave it off and use the (comparitive) damping effect the 'off' position gives. If it really bothers you, you might ask a local wheel/tyre/accessory company to check your suspension geometry - it is possible that even small changes to castor and camber can have a disastrous effect if not set up properly - likewise I'm sure the guys at Lohen and other trusted tuners can offer advice on how to cut it down. Other contributing stuff: Are your tyre pressures even on both sides? What about tyre wear - if that's uneven or low you'll find this can effect it too. I would have thought an LSD would help, but I'm pretty sure stiffer or/and lower suspension would help too (if you're that desperate!) - the less suspension travel, the smaller the angle the driveshafts and steering arms go through....... In the meantime you could try: Lighter shoes Faster arms Quicker reactions Only kidding Why not try a track day to really get the feel for it? Once you've gained confidence, most of the 'squirming' under acceleration becomes normal every day stuff. Sorry. Just read through that and realised it was quite a waffle ![]() ![]() "He fell for her like his heart was a mob informant, and she was the East River." |
| | #12 (permalink) |
| MINI2 Master Join Date: Dec 2006 Location: Wales Local Time: 06:29 AM
Offline | Torque steer is quite normal in FWD cars. It tends to manifest itself in vehicles with engines which have high torque/bhp i.e. the R56 'S'. It has been said that FWD car engines should not exceed 200BHP otherwise the car becomes unstable! If you experience torque steer then it's just a matter of easing off the throttle. It is most likely to appear when accelerating hard when turning. The other cause can be due to incorrect tyre pressures and/or wheel tracking. |
| | #13 (permalink) |
![]() 6X therapist | Equal length drive shafts = No Torque steer unless grip is comprimised on one wheel in which case the traction control will kick in. Unequal length Drive shafts = Torque steer + the grip issues R50,2,3 have equal length drive shafts, so its the tyres and traction control you can feel R56 has unequal length drive shafts , so no matter what the electronics are doing the shaft length is important as to what you feel ![]() |
| | #16 (permalink) |
| MINI2 Newbie Join Date: Oct 2006 Local Time: 06:29 AM
Offline | Hold the steering wheel... lol. I dont think the torque steer is bad at all in the R56 S all the ones iv driven, if it pulls at all is very slight, and like I said, just hold the wheel. Dont expect to be able to floor it hands free... thats not going to happen. |
| | #17 (permalink) |
| MINI2 Regular Join Date: Dec 2006 Local Time: 06:29 AM
Offline | torque steer hello fellows , just test drove the cooper S mini, but damn too much torque steer, why? especially from 1 to 2 ... any expert? the older one felt just stiffer and sportier , maybe I have to get used to it , but at the end its a great car. ![]() |
| | #18 (permalink) |
| The Power Cube | Torque Steer I think there are a number of reasons... different length drive shafts different traction for the left and right tyres suspension quality i believe that to alleviate yourself of excessive torque steer then you need to start with a car that has centralised power drive, quaife diff / good tyres, sporting suspension. of course, i may be completely wrong Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
| torque steer? | minigt3 | 2nd Gen MINI Cooper S | 12 | Feb 20th, 2007 05:07 AM |
| Torque Steer? | darster | MINI Cooper S | 11 | Sep 15th, 2006 04:51 PM |
| Torque Steer...Remedies? maybe not LSD... | TonyB | Engine & Drivetrain Tuning | 41 | Jan 24th, 2004 04:18 PM |
| Torque Steer Test and Comments, please. | Cape Cod MINI | MINI Cooper S | 14 | Mar 20th, 2003 12:03 PM |
| torque steer in Cooper S? | TonyC | MINI Cooper S | 5 | Jan 16th, 2002 09:06 PM |
