Old Apr 29th, 2007, 08:35 PM   #1
mhed58
Local Time: 02:51 AM
United-States When to shift gears?
is it OK to drive around 4,000 rpm? And is it harmful to downshift to slow down?
thanks in advance Art
Old Apr 29th, 2007, 08:42 PM   #2 (permalink)
drumzz
drumzz's Avatar
Local Time: 06:51 AM
no of course, slowing down using gears is sometimes referred to as using engine braking..and to get the most out of your mini you will definitely have to push it harder than 4k rpm, the limiter on the stock r50/r53 is at 6800rpm i believe, so you have no problem!
Old Apr 29th, 2007, 08:44 PM   #3 (permalink)
Restyle
Damned
Restyle's Avatar
I always use engine braking to slow down, & usually change gear anywhere between 5000 - 6500 revs
{when feeling slightly naughty}
In da Wud
Old Apr 29th, 2007, 08:54 PM   #4 (permalink)
mhed58
Infast acceleration I try to shift between 5-65,000 .
but what about cruising in second or third gear.
Is it criminal not to shiuft to first if you don't come to a complete stop?
Old Apr 29th, 2007, 09:03 PM   #5 (permalink)
Restyle
Damned
Restyle's Avatar
Seeing as you`ve got a Supercharger - Its criminal Not to listen to the Whine at those revs
The only downside is the fuel economy - and seeing as youy pay around Half what we in the UK do then enjoy what you can afford
Its normal to take off in second without reverting to 1st if you`re still going at between 5-10mph
In da Wud
Old Apr 30th, 2007, 04:20 PM   #6 (permalink)
pimbeche
pimbeche's Avatar
take off means , like starting from standstill, , how would you go 5-10 mph when you are not moving?
Old Apr 30th, 2007, 05:57 PM   #7 (permalink)
Restyle
Damned
Restyle's Avatar
Not really - I could be slowing down for a light that then changes to green & I floor it & Take off
In da Wud
Old Apr 30th, 2007, 06:10 PM   #8 (permalink)
James
James's Avatar
You are lame!
Old May 1st, 2007, 04:14 AM   #9 (permalink)
mhed58
Well, sometimes I get lazy and if I'm still rolling, I don't go into first, and the clutch feels fine, as in no extra reving needed.
I'm more intrerested in 3rd gear cruising rpm, I love the feel of high reving engine, but don't want to prematurely wear out the clutch?
Old May 1st, 2007, 06:55 AM   #10 (permalink)
steeve
Steeve
Local Time: 07:51 AM
No sense in always going to 1st if you donr stop, so long as the engine doesnt lug down to much, it should always feel responsive and acelerate away easily. Dont cruise in a low gear if you dont have to, you will reduce the life of the engine, reduce service intervals and increase fuel consumption. Perhaps you should thing about getting the automatic?
Old May 1st, 2007, 07:38 PM   #11 (permalink)
James
James's Avatar
I think I understand what you mean now, its ok to cruise around under 4000 revs but above that I wouldn't for more than a few minutes. I don't think its bad for the clutch but it does put unecessary strain on the engine. Having said that I do stay in 3rd 90% of the time
Old May 2nd, 2007, 12:04 AM   #12 (permalink)
mhed58
thanks guys
I couldn't afford the automatic. Anyway I bought the Mini for fun, If it was an automatic, my wife and daugher would take it all the time. I love being in this fast go kart. I realize now that I should shift more often to save the engine,
MC to have Six Gears.. Mini Me GB 2nd Gen MINI Cooper 7 Feb 26th, 2006 05:37 AM
Getting the most out of my gears ramie400 General Discussion 14 May 6th, 2005 03:36 PM
Gears Stone Rose Faults & Fixes 3 Oct 6th, 2004 12:26 PM
Overall, Best Short Shift/Shift Knob VWY Interior & Ice 32 Jul 31st, 2004 05:01 PM
How do you replace shift boot and shift knob? Miniphobea Teen General Discussion 2 May 19th, 2003 06:15 PM
