Old May 5th, 2007, 11:46 PM   #1
picard
JCW Driver
picard's Avatar
Local Time: 05:43 AM
Whirring / Hissing noise after i park car
when i get in from work late and put the mcs away in the garage to sleep and lock it up there is a whirring type of noise from the engine area, i am not sure how long it last has i have never timed it but its less than 20mins cause i went back and checked and it was silent. is this normal does yours do it. is it the turbo winding down or cooling down.
thanks
England Male View picard's Pepper White & Black 2nd Gen MINI Cooper Works Profile View picard's MINI Profile Images   Reply With Quote
Old May 5th, 2007, 11:47 PM   #2 (permalink)
118
growl like a tiger.....
118's Avatar
Send a message via MSN to 118
mine does the same - I guess it's something to do with the turbo, as the TT I had did a similar thing
United Kingdom Male View 118's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 6th, 2007, 12:02 AM   #3 (permalink)
Den W
Now Aero Kitted!
Den W's Avatar
we've got 2 R56 S's and they both do it i think it's the turbo de-pressurising
United Kingdom Male View Den W's Lightning Blue & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 6th, 2007, 12:05 AM   #4 (permalink)
picard
JCW Driver
picard's Avatar
cool so its normal then you would think it would mention it in the manual because its quite disconcerting when you first hear it.
Old May 6th, 2007, 12:15 AM   #5 (permalink)
Westerley
What's the speed of dark?
Westerley's Avatar
Local Time: 06:43 AM
I've read about this in other posts and, whilst mine does the same, it only does it for about 5 seconds max after I've turned the engine off (long and short journeys, taking it easy or not taking it so easy ). Everyone elses seems to go on for a lot longer than this
United Kingdom Female View Westerley's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 6th, 2007, 12:16 AM   #6 (permalink)
jamesbeaumont
Addicted to MINI...
jamesbeaumont's Avatar
Send a message via MSN to jamesbeaumont
Hate to burst your bubble but my R56 cooper does it too Its not the turbo, just the engine cooling down. Normally happens after slow speed runs, ie around town, where the air flow into the engine is not high enough to keep the engine cool. As far as I understand anyway...there was another post on this a while back...
Scotland Male View jamesbeaumont's Chili Red & White 2nd Gen MINI Cooper Profile   Reply With Quote
Old May 6th, 2007, 12:18 AM   #7 (permalink)
jamesbeaumont
Addicted to MINI...
Althought the hissing could indeed be the turbo, maybe does this at the same time, under the same conditions?
Old May 6th, 2007, 12:42 AM   #8 (permalink)
picard
JCW Driver
picard's Avatar
ive had a r56 cooper before this S and that never did it, unless the S runs hotter and needs cooling down after its turned off, thing is it does not sound like the engine fan, more like a very high rpm motor
plot thickens
Old May 6th, 2007, 12:50 AM   #9 (permalink)
burack
burack's Avatar
Local Time: 07:43 AM
guys, the first 5-10 seconds is the turbocharger turbine slowing down and emptying the air through the blow-off valve.
the other sound (lasting 3min plus) is the fan cooling the engine. as the car stops and no longer gets cool air from the front, it has to cool down itself and there's a dedicated fan for doing it. this system exists in nearly all cars, but starts when the air is hot and 5 minutes or so after the engine stops. so usually you dont notice that. its perfectly normal and healthy. cooper users mustnt hear the first sound (as the cooper doesnt have a turbocharger) but second one is common among all of us, coopa drivers.
Turkey Male   Reply With Quote
Old May 6th, 2007, 12:55 AM   #10 (permalink)
Westerley
Westerley's Avatar
Will have to keep an ear out for the fan then as I don't recall having heard anything other than the initial few seconds of turbo wind down. Then again I don't normally hang around long enough to listen. Cheers for this
Old May 6th, 2007, 01:06 AM   #11 (permalink)
minimike7
Minitastic
minimike7's Avatar
Send a message via MSN to minimike7
its seems to be a 2nd gen mini thing as we one 1st gen cooper s and one second gen cooper, never hear a peep from the cooper s other than the superchager (or engine) wind down for a couple of seconds but the 2nd gen cooper is always running that fan when its turned off, I agree can be quite daunting at first. Glad its normal.
Old May 6th, 2007, 01:20 AM   #12 (permalink)
Cape Cod MINI
Exposing the Beast
Cape Cod MINI's Avatar
Local Time: 01:43 AM
Actually, it's a recirculating motor to cool the turbo and keep the coolant moving. It sounds like an air leak and can be a bit disconcerting if you don't know what it is. Old skool turbos, and with my now history twin-charged MINI, you let the car idle for a couple of minutes to cool the beast down. Now the little recirculating pump does the job for you.
Missing my buddies Dan and Ed but glad I have two angel buddies, And on a quest to Right Secco's Wrongs
Old May 6th, 2007, 01:33 AM   #13 (permalink)
Jamesr022
Jamesr022's Avatar
My R53 Cooper S does this quite alot, normally after i have been driving it fairly hard, it also does it when i have been stationary in traffic for long periods of time! the fan normally keeps going for about 90 seconds after i have switched the engine off!
2002 COOPER / 2003 ONE D / 2003 COOPER S
United Kingdom Male View Jamesr022's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 6th, 2007, 02:18 AM   #14 (permalink)
Richard Korby
Local Time: 10:43 PM
Along with all those sounds I get a little popping out the tail pipe .
United States View Richard Korby's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 6th, 2007, 02:23 AM   #15 (permalink)
picard
JCW Driver
picard's Avatar
yip i get that especially if i rev it and lift off in neutral it sounds great
Old May 6th, 2007, 07:21 AM   #16 (permalink)
burack
burack's Avatar
picard, that sound is the sound of blow-off valve (BOV). I have a post about it under tuning section, you can check it out. That chuffing noise is great imo! Not all turbo cars are equipped with that, BOV's use is to empty the air within turbocharger when you lift your foot off the throttle pedal to increase the life of the turbine. Because whenever you hit the throttle, turbocharger fills with air and starts spinning, and its a bad thing to try to fill it with air when its already full! Thats the use of BOVs. Some users -like me- like to add or change the bov on their cars I strongly suggest that. you can youtube "hks ssq bov" and understand what i mean
Old May 6th, 2007, 05:30 PM   #17 (permalink)
rec
Not a happy bunny.
rec's Avatar
Send a message via MSN to rec
my cooper hisses when i unlock it, and when i stop the engine.
weird :P
England Male View rec's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Hissing noise.... sometimes?! devaisl 2nd Gen Engine & Drivetrain Tuning 9 Feb 2nd, 2007 08:44 PM
Whirring noise in back of car IH1 Faults & Fixes 18 Aug 1st, 2006 08:43 PM
Brief whirring noise when opening door McQz Interior & Ice 5 Apr 17th, 2006 03:28 PM
Whirring noise when clutch is out Shpongled Faults & Fixes 9 Feb 18th, 2005 02:47 PM
Strange whirring noise thrud Faults & Fixes 2 Dec 17th, 2004 04:27 PM
