Tags: ,
Old Aug 27th, 2007, 07:41 PM   #1
Gracie Wacie
Local Time: 04:16 PM
How do I open my bonnet????
On Saturday, I needed to open the bonnet on my R56 S and couldn't do it. I looked in the manual and it showed a sort of lever in the centre of the bonnet but I'm sure that's what it looked like on my R50. I think the manual may be for the earlier build. Can someone please explain how the bonnet opens, once the release lever is pulled. I'm baffled.
PS. I am blonde and thought that maybe explained the difficulty, but hubby couldn't work out how to do it either and he's usually good with things like that.
Old Aug 27th, 2007, 07:47 PM   #2 (permalink)
Jordan210
Cyber Police
Jordan210's Avatar
Local Time: 05:16 PM
Send a message via MSN to Jordan210
It is where the manual shows around about the center, just you need to get your hand quite far under the bonnet to find the catch as it is set back a bit, Does take a bit of time to find on the R56's
Unless its changed since i lased looked at an R56 !
MINI2's Resident Dyslexic
Suriname Visit my Blog at the Motorcade Male   Reply With Quote
Old Aug 27th, 2007, 08:09 PM   #3 (permalink)
minicabrio
Back in a MINI
minicabrio's Avatar
It is a tricky lever to find
Three quarters of the way along the grille, so about 5-6 inches to the right of the badge. Put you hand up inside the bonnet, there's no 'lever' as such so have a poke around with your fingers till you find the bit that moves
Old Aug 28th, 2007, 06:24 AM   #4 (permalink)
Simz
the flap is directly lined above the 2nd to last letter of your registration plate.
put your finger under the chrome grill trim (top portion, and you may have to gently lift it a little as it may stick in the down position) in the above described postion and you will feel a plastic flap, push this up and the bonnet should release- it's spring loaded so you will feel it move upwards.
hope that helps
United Kingdom Male View Simz's Dark Silver & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Aug 28th, 2007, 08:29 AM   #5 (permalink)
valk009
Local Time: 12:16 AM
The safety lever under the bonnet is situated a little right form the center. You need to go fairly far in to feel it.
Take Note: The engine can get quite hot after running it for a while, so try and open the bonnet when it is cold!
Hong Kong Male   Reply With Quote
Can't Open My Bonnet :-) R60 Mike 2nd Gen Faults & Fixes 13 Nov 11th, 2007 03:15 AM
boot/bonnet open light Sken Faults & Fixes 0 Sep 16th, 2006 12:58 PM
2007 car with bonnet open Hat Future Variants 42 Mar 27th, 2006 05:34 AM
Boot/Hood open light open all the time aphix Faults & Fixes 2 Jun 25th, 2005 10:01 PM
