| Tags: handbrake, mcs |
| MINI2 Newbie Join Date: Mar 2007 Local Time: 06:36 AM
Offline | Handbrake i parked my mcs on my girlfriends drive last night and after about 5 mins i heard a car alarm which sounded very similar to mine, when i looked out the window, my car had rolled into my girlfriends garage! Has anybody else had any problems with their handbrakes failing? and yes, i know, i should leave it in gear! |
| MINI2 Master Join Date: May 2002 Location: Edinburgh Local Time: 06:36 AM
Offline | As the brakes cool they contract, this reduces the amount of grip the pads have on the discs. This has been reported on earlier version MINIs as well as many other cars. This is why it tells you to leave it in gear in the manual ![]() ![]() Red/Black R56 Cooper |
| MINI2 Senior Join Date: Dec 2006 Location: Wales Local Time: 06:36 AM
Offline | Some useful points regarding the Handbrake The following precautions apply to all cars that have rear disk brakes: - a) Always leave the car in gear b) When applying the handbrake first press the foot brake hard then apply the handbrake c) By doing the above you will avoid stretching the handbrake cable d) This is especially important if the brakes are hot, when they cool the brake pads will have less grip on the disk, and car could move. |
| | #6 (permalink) |
| May '08: Bye bye Mini2... Join Date: May 2004 Location: Kernow, near England Local Time: 06:36 AM
Online | caesar, You can add to the list; on a steep hill, it's worth turning the steering into the curb before locking the steering. Incidentally, I first had this problem on a Citroen XM. Its handbrake worked on the front discs (that's Citroen for you ) and the problem was even worse as the front discs can get much hotter than the back ones and have an even greater potential for contracting as they cool ![]() Tigger. |
| | #8 (permalink) |
| MINI2 Newbie Join Date: Jan 2008 Local Time: 05:36 AM
Offline | Handbrake Failure, Mini One, New April 2007 I have the new model Mini One, bought in April 2007. On 28th December I parked it in a car park, which was on a bit of a slope. When I returned to the car, firstly I thought it had been stolen and then saw it planted in a wall at the back of the car park, approx. 1 foot from a new Porsche!!!! I have 2 witnesses who will vouch for me that the handbrake was on. I took it back to Stratstone Mini in Harrogate, who didn't question me, they just took it away. They told me they had checked the handbrake and there is nothing wrong with it, but they had squared up the belly plate. They said they needed to do the body work and replace the rear bumper. I have asked for a quote, but feel that it is their problem. I have done nothing wrong. Has anyone else had the same problem? Did the dealership cover the cost of the body repair work? ![]() Kim |
| | #9 (permalink) |
| Mini Design Philosopher Join Date: May 2004 Location: Berkshire, UK Local Time: 06:36 AM
Offline | I don't think you have any come back on a manufacturer if you haven't left a car in gear. Sorry to sound harsh. ![]() Handbrakes shouldn't be 100% relied on as components can and do fail - and a rolling car is dangerous. If pointing up a hill, leave the car in a forward gear such as 1st, and if pointing down hill leave it in reverse. As Tigger says if its really steep turn the wheels in towards a kerb. Good luck with repairs though. ![]() ![]() |
| | #10 (permalink) |
| I miss my MINI | These are the first instances of this happening to the new models that I have seen. Yes, you should have left it in gear (no need to preach) and as others have pointed out, you are going to have a small battle to get MINI to cover it as it really isn't their fault. That being said, I wouldn't get angry with them. Work with them and see if they might be a little generous and help you out on the cost. Otherwise, it might be worth going to a independent to get it repaired. Dealers charge way to much for body work.... Global Moderator ![]() |
| | #12 (permalink) |
| MINI2 Regular Join Date: Sep 2007 Location: Melbourne Local Time: 03:36 PM
Offline | Definitely leave em in gear. I just parked up today, nose pointing downhill, with nothing but a flimsy looking wooden barrier between my car and a very steep drop, and applied the handbrake. Luckily I also left it in gear, as when I returned to the car 1/2 hour later and got in and pressed the clutch to start it (handbrake still applied), it began to roll forward. Had I not left it in gear, I suspect it may have returned to find it at the bottom of a rather steep hill ![]() I will ALWAYS leave in gear from now on. Life's fun in black and white |
| | #14 (permalink) |
| MINI2 Newbie Join Date: May 2007 Location: Arizona Local Time: 10:36 PM
Offline | Kim: You mean you authorized bodywork by the dealer and didn't happen to ask them who's going to pay for it? Assuming they will pay for what amounts to an unwitnessed parking lot collision is probably assuming a lot IMO. I'd guess they would tell you to file an insurance claim. |
| | #15 (permalink) |
Offline | No, I still haven't had it repaired. I have had an independent brake check carried out at the request of the Mini garage. Didn't expect it to show anything, as it took 6 months for this one failure to happen. The brakes are fine according to the test. Stratstone Mini have had the car in again last week to carry out more handbrake tests and said everything is working efficiently. As you say, I should have left it in gear, although I was taught by BSM, a large driving instructing company in the UK, to leave the car in neutral when parked. (I passed my driving test in November 2007.) Obviously, I have now learnt my lesson and will always park in gear with wheels into the curb and have instructed my friends who have the new Mini. I will now give in and go and get it repaired. I don't want to claim through insurance, as it is my first year and the premium was £2500 without ever having had a claim!!!!! |
| | #17 (permalink) |
Offline | Handbrake Any vehicle that has rear disk brakes including the Mini has to be careful. If the handbrake is applied when the disk's are warm/hot and they cool down, then the disks contract and the brake will partially release. To overcome this potential problem you should do the following: - a) Before applying the handbrake press the footbrake hard down, then with your foot still on the pedal apply the handbrake. b) Engage 1st gear or reverse depending on which way the car is facing. c) Turn the steering wheel angle so that the front wheels will touch the curb if it rolls back or forward. |
| | #18 (permalink) |
| MINI2 Regular Join Date: Jun 2007 Local Time: 01:36 AM
Offline | That's driving schools for you, you never know who you might get. This was in the papers a couple weeks ago: they did some statistics in Ontario and found that accident rates among new drivers were actually higher for those that took drivers ed.! ![]() |
| | #19 (permalink) |
| MINI2 Regular Join Date: Sep 2007 Local Time: 06:36 AM
Offline | Kim keep pressing on with your claim, I had the same problem with a MINI rolling backwards down a small slope and damaging a door. A rude BMW engineer looked over it and said the same nothing wrong with hand brake and I should have left car in gear. Anyway I rang MINI UK and sent a letter stating the ramifications of a child being behind the car or any other person for that matter. 2 weeks later my claim had been escalated the a priority and MINI agreed to perform all the work as a "gesture of godwill" and "brand loyalty". So a little perseverance may pay off. |
| | #20 (permalink) |
| MINI2 Regular | I've noticed the handbrake on my cooper s can be quite weak if parked on a hill. For instance i'll apply it normally and the car will still be rolling slightly. Not good. Took the car in for some warranty work today and asked them to take a look at it, but because it's an alteration and not covered under warranty, I would be charged for it. I politely told them that I would by no means be handing over any monies for something that should most certainly be working fine on a one year old car. |
| Handbrake help | ringo | Australia | 12 | Jan 19th, 2005 07:28 PM |
| Handbrake Gaitor | Darren Metcalfe | Interior & Ice | 11 | Jun 9th, 2004 06:36 AM |
| handbrake | dundun | Interior & Ice | 2 | Dec 10th, 2003 05:28 PM |
| handbrake | m1les | Faults & Fixes | 17 | Jun 19th, 2003 05:38 PM |
| Handbrake | LANER | Interior & Ice | 0 | Aug 22nd, 2002 11:35 AM |
