Tags: , ,
Old May 26th, 2008, 05:43 PM   #1
robfish1985
Local Time: 07:22 PM
How well built were 56 plate MINI's??
Hi,
I have a bit of a dilemma...I am looking to change my currenty R53 mini for an R56, but am torn between a cooper and cooper s. Basically, if i got a cooper i could afford an almost new one, either a 57 or 08 plate. If i opt for the S though i could probably only afford a 56 plate as i have seen some on MINI cherished for around 15 K.
I am swaying more towards the S but am slightly worried about the build quality and reliability of the early 56 plates. Also, obviously if i went for a cooper it would have the stop/start function as it would be newer but the S wouldnt...would this make a lot of difference when i come to sell it??
Anyway, any advice from 56 plate owners or indeed anyone able to help would be much appreciated.
Rob
Old May 27th, 2008, 08:38 AM   #2 (permalink)
colink24
Stop/Start Button
The 2007 R56S 56 plate cars do have the stop/start button, well mine does anyway. Mine was built Jan 07 and is on a 56 plate.
The build quality however is a different matter. I can that annoying tractor like noise from engine at times, some weird gearbox noise in low revs, some weird noise from the drivers door window. I could go on, luckily mine is going back to the dealer in a year or so (still under warranty) so I am not too bothered. The performance is still there!!
I would recommend doing a VERY thorough test drive before you commit to buying a 56 S
Old May 27th, 2008, 05:12 PM   #3 (permalink)
Bonj
Bonj's Avatar
I think what Robfish means is the start/stop system for improved fuel efficiency.
That came in on all August 07 and after MINIS so if you hold out til August (or even sept when the plate changes) you could pick an S up that's a year old probably a bit cheaper. If you're going for an S the Stop/Start makes a huge difference - lower tax band and great fuel efficiency.
If you're not sure about going for the S, don't even take it for a test drive and just buy a Cooper. If you try out a Cooper S, everything else is going to feel like you're towing a sack of spanners.
Old May 27th, 2008, 06:01 PM   #4 (permalink)
kevkbuk
The general problems with the R56 are not confined to the early build cars. The only thing I'm aware of is that the supplier of the dash and associated trims was changed a couple of months back. Having said that if you have problems with interior rattles then the trims can be replaced under warranty.
I don't think the auto stop/start functionality is worth having. The early S will easily do 40-42 MPG on a long run, and owners with the start/stop report similar figures on here most of the time. The cheaper road tax may be nice, but it's not a huge difference.
Male View kevkbuk's Astro Black & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 27th, 2008, 07:31 PM   #5 (permalink)
caesar
caesar's Avatar
Agree strongly re' auto stop/start.......in my sceptical opinion it's just something else that can go wrong
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 28th, 2008, 06:59 AM   #6 (permalink)
Tommo
24hr
Tommo's Avatar
I have start/stop on both of my Cooper S and use it at least 20 times a day on my daily commute. In 7 thousand miles it's never missed a beat. When on a long run is not when you use it, in heavy traffic it works a treat and keeps the MPG up to a figure cars without it wouldn't be able to match.
United Kingdom Male View Tommo's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 28th, 2008, 06:24 PM   #7 (permalink)
robfish1985
Thanks for all your opinions guys. Yes, the stop/start function i was referring to was indeed the fuel efficiency deriative, not the actual stop start button to start the car. I am definitely going to test drive an S but i will be listening very careful for any rattles etc and i i do buy i will demand that they are sorted out before i take delivery. i guess as long as its under warranty then everything should be ok, its more the hassle of having the car back at the dealers every 2 minutes!!
I take it the cooper compared to the S then is pretty slow?? I have an R53 one now with a bluefin remap. Its reasonably quick over 4000RPM but i would love a bit of mid range shove for motorway trips, which i suspect is a strong point of the new S?
Rob
Old May 28th, 2008, 07:10 PM   #8 (permalink)
iain cooper
I've had my R56 cooper now for nearly 18 months and have done over 18,000 miles
the cooper is fun to drive, nippy and very economical. ( I regularly get 50 mpg )
but it is not a fast car, unlike the cooper s, so if performance is your priority I think you would be dissapointed with a cooper, and you should go for the s.
ps I would add however that the cooper is excellent on the motorway, returning good mpg and being very comfortable and flexible at and above the legal limit.
however I get the feeling from your post that you also need the low down punch from 2000rpm to 4000rpm ? the cooper will not give you this.
hope this helps
Old May 28th, 2008, 08:30 PM   #9 (permalink)
Jon Robson
Dooper Driver!
Jon Robson's Avatar
Send a message via MSN to Jon Robson
If you want the low down punch you need to try a Cooper D...
United Kingdom Male View Jon Robson's Lightning Blue & Black 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
M7 Flywheel, Pressure plate and clutch plate supercoopers For Sale 0 Oct 2nd, 2006 12:04 PM
When was yours built?? Matts Mini Adventure General Discussion 22 Jun 24th, 2006 08:39 PM
MINI's and Mini's don't mix well at MME 2003 Lucas63 General Discussion 56 Feb 25th, 2006 03:47 PM
For Sale: WK5 1 FUN Private Plate. Ideal for Works MINI's Root Ginger For Sale 1 Jan 19th, 2006 03:11 PM
