Adam's Polishes
Old Dec 15th, 2007, 03:56 PM   #1
Manzi89
Local Time: 05:50 AM
DIY Problems with Bearing on mini one
Alrite, i need some help. my bearing on the front right wheel is out of alignment and its causing big problems for me. 1st theres the irritating noise it makes when traveling at rapid speeds and turning, even gradualy, to the left. Then theres the fact that it is effecting my tracking in a big way, have just had to shell out for a new tire as the one that was on is now bald.
So can anyone tellme how big a job it would be to sort out the bearing myself and details on how to do it to a tight budget.
Any comments would be appreciated.
Manzi89, with a sexy 05 mini one!!!!!
Scotland   Reply With Quote
Old Dec 15th, 2007, 04:17 PM   #2 (permalink)
richg40
Local Time: 06:50 AM
the bearing is bolted to the hub from the rear by 4 13mm bolts. obviously the brake needs to be stripped completely and then these bolts are easily accessible. are you sure that the bearing is the cause of yor wheel misalignment? sound unlikely to me, more likely a knackered track rod end. try jacking the front wheel up individually and shake the wheels by hand and check for movement in the ball joint.
Everyone else is lying to you. stop giving out duff advice people!
Old Dec 16th, 2007, 04:07 PM   #3 (permalink)
adam_Randell
07' Cooper
adam_Randell's Avatar
Send a message via MSN to adam_Randell
I knocked my tracking out, and asked MINI how much it would be to get it tracked expecting £50/£60...ow wrong i was to get your tracking back in line you will have to shed out £150! And apparently, the way the car is constucted you can only get it done at a MINI dealership and can only have all 4 done, not jsut the front/back.
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Dec 16th, 2007, 04:11 PM   #4 (permalink)
richg40
you can get your tracking done anywhere really, but full 4 wheel alignment is definately best.
wheel bearing penny taylor Faults & Fixes 3 Jun 10th, 2008 10:28 AM
Throw out bearing going ???? Minipnut Engine & Drivetrain Tuning 4 Dec 5th, 2007 08:33 PM
Help please - clutch bearing Tombles Faults & Fixes 14 Jul 4th, 2007 02:23 AM
Wheel Bearing... Nick01329 Faults & Fixes 5 Aug 22nd, 2006 03:29 PM
New throw-out bearing DeniseK Faults & Fixes 9 Dec 21st, 2004 08:36 PM
