![]() AprilWhine's Fuzzy One Join Date: Mar 2002 Location: Where the wind blows Local Time: 11:59 AM
Offline | MCSa shift points Sorry Jim, for posting your question in open, you have your PM's turned off so I can not reply via that method. You had a good question, so I am going to answer you with a public reply. Hi Jim. It sounds as if you are a gentle driver. I have had that happen to me as well. If I use slightly more throttle from a dead stop, it will hold in the gears longer prior to shifting. The software tries to predict what you want to do next. It makes little difference to fuel economy if it shifts sooner or later. Mine has adapted to my driving style by not shifting until the change results in about a 2500 to 3000 rpm after the shift. If yours stays lower, it might be worth seeing if there is a later software update that you need. If you don't let your service manager know that you are not happy with the shift charactoristics, they won't call you in for an upgrade. Try driving it for a little while in sport mode, i.e., bump the shift lever to the right, and it will up the shift points about 500 RPM. Don't paddle shift or manually shift when in SD, or it will approach redline prior to shifting. It will not over rev, the tranny and computer will always shift prior too high or low RPM. It is virtually impossible to damage engine or transmission in these cars equipped with an automatic. You can't even rev the engine in neutral and drop it in gear, the software will not allow it. I was so confident of that I bought mine as an ex demonstrator. Incidentally, the MCSa is a real value holder. I sold my car on eBay, and the automatic S is so scarce that with 12000 miles and 9 months of use, I received $400 more for mine than I paid for it. Still have the wife's Cabrio automatic, and enjoy it every time I get to drive it. Take care. Jim ![]() Last edited by AprilWhine : Sep 5th, 2006 at 10:59 PM. Reason: fixed tags |
| shift points | agoodspellr | 2nd Gen MINI Cooper | 3 | Jul 10th, 2007 12:11 PM |
| Shift points? | Eastereggmini | MINI Cooper S | 11 | Oct 3rd, 2006 11:12 AM |
| Optimal shift points | ghal | General Discussion | 7 | Jun 26th, 2006 10:12 AM |
| Shift points for a stock Cooper S? | fprintf | MINI in Motorsport | 2 | Aug 3rd, 2004 07:29 PM |
| What are the optimal shift points for the S | bernsco | MINI Cooper S | 2 | Oct 7th, 2003 10:51 PM |
