Tags: ,
Old Sep 24th, 2006, 08:02 PM   #1
lynall
Local Time: 09:15 PM
Reverse to Drive jolt
My wifes new to her Mini One goes from reverse to drive with a jolt its almost as if the engine is running to fast.
Engine was surging whilst in drive at stop i have removed and cleaned the throttle assembly and this has cured that.
Any ideas on the jolt?
It will be getting a full service next week incl new trans oil.
Lynall
Old Sep 27th, 2006, 02:52 AM   #2 (permalink)
Paul!
Ride The Dragon!
Paul!'s Avatar
Local Time: 05:15 PM
Send a message via AIM to Paul!
I would experience a jolt if I went from reverse to drive too quickly. I noticed it especially if the enging was cold.
My solution is once I'm in reverse, I apply the brake, wait a second, then shift into drive.
-Paul!
United States Male View Paul!'s British Racing Green & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 27th, 2006, 09:39 PM   #3 (permalink)
lynall
Paul thanks for teh reply i will get her to try that.
Lynall
Old Sep 28th, 2006, 12:56 AM   #4 (permalink)
Paul!
Ride The Dragon!
Paul!'s Avatar
Actually, I have to revise the order a bit after testing. (I just went outside to consciously check what I do!)
Once you're in reverse, shift to foward, then wait a second (you don't even really have to apply the brake if you're moving a little bit), then apply the gas.
It seems if you apply the gas too soon, you're forcing the CVT to shift a bit to quickly for its own good.
-Paul!
Old Sep 29th, 2006, 08:02 AM   #5 (permalink)
lynall
Lisa just tried both methods and it stills jolts, this is her third auto the other two were Mercs with slush boxs as opposed to cvt, i have noticed it seems to drag a bit a tickover as well.
Lynall
Old Oct 7th, 2006, 06:18 AM   #6 (permalink)
mini_macky
JL Mini Boombox
mini_macky's Avatar
Local Time: 05:15 AM
Send a message via Yahoo to mini_macky
what i do is (when the engine is cold), i leave my Mini to warm-up to half of the temp gauge, and when i shift from P to D, there's still a slight jolt but not as violent as when the engine is cold
Philippines   Reply With Quote
Reverse Jnr_Seahorse Faults & Fixes 24 Jul 12th, 2004 06:17 AM
PT throttle stutter/jolt..... SOLVED Liam"S" Engine & Drivetrain Tuning 4 Oct 7th, 2003 10:24 PM
Just don't go into reverse.... Paul MINI Cooper S 1 Mar 25th, 2002 09:27 PM
