| MINI2 Senior | CVT Neutral Drop G'day, I was just wondering what would happen if you did a neutral drop in an auto with the CVT? I know it's chronic for the transmission in a standard auto, but does anyone know what happens when you do it with CVT? Cheers, Jug |
| MINI2 Regular Join Date: Mar 2002 Location: The Big N, CT Local Time: 01:04 PM
Offline | I know neutral drops are fun but as a rule of thumb retain that practice for rental cars. Why don't you try to stand on the brakes instead. That seems to be the lessor of two evils methinks. |
| | #12 (permalink) |
| MINI2 Senior Join Date: Sep 2001 Location: us Local Time: 10:04 AM
Offline | My guess is that with the CVT, it simply wouldn't go into gear. Of course I could be wrong, and I'm definitely not going to volunteer to be the guinea pig and find out! ![]() PigLick |
| | #14 (permalink) |
| Moderator Join Date: Nov 2002 Location: Seattle area, WA Local Time: 11:04 AM
Offline | Thanks for detailing what this means, and now I can say that I've seen it done ... with the most amazing scattered parts on an older GM unit. I wouldn't want to see the effect on our CVT, although it should be programmed to just wait until the revs come down. I wonder if the programming wouldn't protect the equipment (as I'm told the BMW SMG unit is supposedly proofed against this "mistake"). |
| | #15 (permalink) |
Offline | The Owner's Manual (p.46, top right column) states that the CVT transmission "is blocked" from being engaged if engine rpm is too high "to protect the transmission." This tells me that this Neutral Drop idea would not work. Who is going to try it?(!!!) '02 MINI Cooper CVT (prod. date: 6/12/2002; Indi Blue/Black roof, R-81 7-hole 15x5.5" or NZO 16x6.5") '67 Austin Cooper S 1275 Mk1 (build date: 6/26/1967; Tartan Red/Black Roof, Minilite 10x4.5" or 10x6.0") Last edited by nonsequitur : Jun 2nd, 2004 at 02:17 AM. Reason: Corrected spelling |
| | #16 (permalink) |
| MINI2 Newbie Join Date: Oct 2003 Local Time: 02:04 PM
Offline | I was thinking about this myself tonight... as well could you define "too high" is there like a 3000rpm or higher limit? cause I still think this would add significant kick - but I dont wanna kill my CVT in the process... |
| | #17 (permalink) |
Offline | The motor is rpm-limited to 4000rpm in P, N, and R. Just rev it up and the limiter will show you very clearly how it works ... 4000rpm exactly. '02 MINI Cooper CVT (prod. date: 6/12/2002; Indi Blue/Black roof, R-81 7-hole 15x5.5" or NZO 16x6.5") '67 Austin Cooper S 1275 Mk1 (build date: 6/26/1967; Tartan Red/Black Roof, Minilite 10x4.5" or 10x6.0") |
| Gearbox/lever in neutral | jason74 | Faults & Fixes | 0 | Jul 18th, 2007 05:19 PM |
| I've just joined Target Neutral | Goonery | General Discussion | 15 | Nov 1st, 2006 09:57 PM |
| CVT in Neutral... | ururk | CVT & Automatic | 6 | Sep 5th, 2005 12:57 AM |
| choking on neutral | WissCooperS | Faults & Fixes | 5 | Mar 13th, 2005 04:59 PM |
| Chattering Mini Cooper S in neutral | rijko | Faults & Fixes | 11 | Jan 18th, 2004 08:23 AM |
