Adam's Polishes
View Poll Results: Did you encounter any problem with your CVT transmission?
Yes 4 28.57%
No 10 71.43%
Voters: 14. You may not vote on this poll
Old Sep 25th, 2003, 04:09 PM   #1
minimao
minimao's Avatar
Local Time: 02:29 PM
Send a message via ICQ to minimao
Exclamation CVT Transmission noise
Just got my mini back from the dealership that they replaced the CVT transmission. Two weeks ago, I heard some weired rotational noise came from my car and the sound was really annoying. The noise was getting louder while the rmp was higher. First, I thought that it was from the engine but after I drove it to the dealership for the inspection and they figure out that the noise was from the CVT transmission. Since my car is under warranty (only 7 month-old), they went ahead to replace the transmission with no charge. Now, they would send back the broken transmission part to the miniusa for further the inspection and research. I am wondering that how many of mini CVT owners have the same problem!?
minimao
United States View minimao's Pure Silver & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 25th, 2003, 09:23 PM   #2 (permalink)
CooperS4us
CooperS4us's Avatar
Local Time: 06:29 PM
What is the build date and mileage of your Cooper CVT?
Old Sep 25th, 2003, 09:25 PM   #3 (permalink)
CooperS4us
CooperS4us's Avatar
'02 Cooper CVT, 14K+ miles and no transmission related problems at all.
My car is an early August 2002 build (It was not affected by the infamous CVT recall that covered most early build 2003 Cooper CVTs build between September and October 2002).
Was your car part of that "wrong CVT oil" recall, by any chance?
Old Sep 25th, 2003, 11:59 PM   #4 (permalink)
blueskylee
Local Time: 10:29 PM
Unhappy
I seem to have the same problem as you have stated. Actually I've been hearing a kind of rotational, rolling sound from the exhaust area that varies with car speed (not rpm), and recently I noticed the sound is accompanied by a kind of metal rubbing noise from under the car. Interesting enough the sound is not noticeable every morning when I drive to work until about 10 minutes on the highway. After the engine heats up it is often noticable, but sometimes the noise is small.
I have scheduled an appointment with the dealer next week. I'll print this article out to them and hope that they can diagnose the problem.
I have a August 2002 build (CVT). Haven't received any recall from MINI.
United States View blueskylee's Liquid Yellow & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 26th, 2003, 01:49 AM   #5 (permalink)
minimao
minimao's Avatar
Mine was Jan 2003 production and I put almost 9000 miles in 7 months.
The noise could be heard during driving from 1 mph to 85 mph. (I usually don't drive above 85mph.) The noise was off when the engine was idle (0 mph).
minimao
Old Nov 30th, 2003, 04:40 PM   #6 (permalink)
UNeeUn_Jack
Local Time: 05:29 PM
I just sent my CVT cooper in for a service and found out I need a new transmission too!
I was having some minor issues, car stuttering at low speeds, a couple of random stalls etc, but figured it probably just needed the latest software update. Then on the way to the dealer the engine started sticking - first at 1,600 rpm and then at 2,000 rpm. The only way I could push above this was to switch to manual shifting (even the sport mode wasn't helping).
So to cut a long story short, out goes the old transmission and in goes a new one. But this has me concerned - is there an issue with the CVT generally that I should be wary of in the future??
(2003 build Mini, delivered in August, 8500km on the clock, no crazy driving!)
Canada   Reply With Quote
Old Dec 1st, 2003, 03:16 AM   #7 (permalink)
nonsequitur
Moderator
Local Time: 03:29 PM
Ours had been "bulletproof". We're now at 17mo and 14600mi.
'02 MINI Cooper CVT (prod. date: 6/12/2002; Indi Blue/Black roof, R-81 7-hole 15x5.5" or NZO 16x6.5")
'67 Austin Cooper S 1275 Mk1 (build date: 6/26/1967; Tartan Red/Black Roof, Minilite 10x4.5" or 10x6.0")
United States View nonsequitur's Indi Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 1st, 2003, 07:11 AM   #8 (permalink)
punkeyfunky
UberGeek
punkeyfunky's Avatar
Send a message via AIM to punkeyfunky
I've got a Mar 03 MC. I have a noise that increases with RPM, particularly 4000-6000rpm.
To me, it sounds like it's coming from the steering column, but after having the column, rack and PAS pump replaced, it's still there.
I wonder if it's my CVT?
Car's going into on Wednesday (again, 9th time) for that and to have other work that they did on Friday straightened out.
Lee
Old Dec 1st, 2003, 10:12 AM   #9 (permalink)
valnmike
valnmike's Avatar
Ours is a 2/14/03 build CVT. We have had the lurching while stopped in traffic, but otherwise no discernable trouble I would say was related to the CVT. We now have 9,800 miles on it.
-=Mike=- laissez les bons temps rouler
United States Male View valnmike's Chili Red & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 7th, 2003, 04:34 PM   #10 (permalink)
LordWinslow
Back...
LordWinslow's Avatar
Send a message via Yahoo to LordWinslow
Mine was doing something simular, but I was dropping gears. Like if I was in Manual mode I would be driving in 6, the engine would get loud and then drop to 5th or even 4th.
If I was in drive or sport drive modes it would get loud, shudder and then buck bad.
Took it too the dealer and they found a hole in the top of the CVT where fluid would be leaked out. It would only leak when running as the presure was there to force the fluid out. So they dropped the transmission and put in a new one for me. No problem since. That was at 17K I am now at 30K. No more problems since. My car is a late '02 build (but a '03 Model).
Winslow
This space for Rent
Old Dec 7th, 2003, 09:57 PM   #11 (permalink)
rainbowdreamer
rainbowdreamer's Avatar
Local Time: 11:29 PM
May 03 build MINI ONE CVT with no problems - but then I am only at 2600miles
Rainbow Dreamer
2005 Cooper S Convertible
United Kingdom View rainbowdreamer's Dark Silver & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Dec 8th, 2003, 05:02 PM   #12 (permalink)
nonsequitur
Moderator
Have those owners who are experiencing problems made ANY modifications to increase power/torque from the motor? And, what software version are you running?
There must be a baseline to draw reasonable conclusions.
Old Dec 11th, 2003, 01:28 AM   #13 (permalink)
LordWinslow
Back...
My problems occured before I put in the Intake. No problems since.
Winslow
This space for Rent
CVT transmission is dead chrissalazar95 CVT & Automatic 16 Aug 1st, 2006 02:03 AM
2004 CVT "WHINE NOISE" -- NEW TRANSMISSION? HELP. bob_dylan CVT & Automatic 1 Oct 17th, 2004 02:49 PM
CVT Transmission failure davidma CVT & Automatic 2 Apr 24th, 2004 04:33 PM
CVT Transmission drgrey CVT & Automatic 56 Sep 24th, 2003 10:10 PM
CVT vs 5 speed transmission Fred Seiss General Discussion 17 Jul 27th, 2003 07:15 PM
