Visit Lohen!
Old Oct 10th, 2003, 01:43 AM   #1
shputz
Loves Kim & Ian
shputz's Avatar
Local Time: 03:12 AM
CVT Engine Braking
I've always downshifted to lower gears when descending a steep hill, to allow the engine to slow the car instead of riding the brakes. Since the CVT tries to maintain a steady RPM, should I just leave it in D or SD? Or should I go to manual and then downshift as much as the program will allow me to. Thoughts?
Jim
- QUICKER - 2003 MC, CVT, CR/W, white bonnet stripes w/ black pinstripes and John Cooper sig, premium/cold weather package, sport seats, gauges, aux audio input
United States View shputz's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 10th, 2003, 03:11 AM   #2 (permalink)
cjay
"No Works for me!"
Local Time: 05:12 PM
If you leave it in D or SD it will change down by itself
Australia View cjay's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 10th, 2003, 03:47 AM   #3 (permalink)
nonsequitur
Moderator
Local Time: 12:12 AM
This technique you used with a manual also works in the MINI Cooper CVT. The directly comparable way is in Steptronic, selecting the "gear" that gives you the right amount of engine braking to slow behind another vehicle or free-running to stay at the right speed. Need more? -- downshift (forward flick).
Since it's so easy to change gears, you can practice a fairly sophisticated dance to sliiiiiip into the right cadence. You're right that brakes can be avoided completely for most situations.
Both D and SD give you significant engine braking, unlike most automatics, so these modes can also be used, especially around town.
I've found Cruise Control works very effectively with D or SD to tightly manage speed, even low speeds like 30mph on sidestreets.
It is possible to confuse the computer in D or SD on a downslope. If you get this right(actually wrong), the engine rpm will come up to redline as the computer chases the vehicle speed down the hill. This is weird if it happens to you.
'02 MINI Cooper CVT (prod. date: 6/12/2002; Indi Blue/Black roof, R-81 7-hole 15x5.5" or NZO 16x6.5")
'67 Austin Cooper S 1275 Mk1 (build date: 6/26/1967; Tartan Red/Black Roof, Minilite 10x4.5" or 10x6.0")
United States View nonsequitur's Indi Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 10th, 2003, 04:38 AM   #4 (permalink)
nfo
Local Time: 02:12 AM
downshifting the cvt was so nice.
i used to take this serious twisty here without brakes when all the other cars were braking for a while. i sure can't do that in my automatic pontiac rental car! heheheh
Driving Technique's - Engine Braking ? caesar 2nd Gen MINI Cooper S 33 Jan 3rd, 2007 02:59 PM
2005 CVT - RPM dip on braking to standstill MediocreFred CVT & Automatic 16 Mar 3rd, 2006 03:19 PM
Engine Braking - good or bad? yadda CVT & Automatic 44 Apr 17th, 2005 10:53 PM
Steering/braking/throttle/engine management and the ECU PigLick Faults & Fixes 2 Feb 1st, 2005 08:42 PM
Engine braking, why bother? ches MINI Cooper S 7 Jul 3rd, 2002 10:02 PM
