Mini Pirate
View Poll Results: Which mode do you autocross in?
I autocross in SD 0 0%
I autocross in Steptronic 2 25.00%
I think SD would be best 3 37.50%
I think Steptronic would be best 3 37.50%
Voters: 8. You may not vote on this poll
Old Nov 21st, 2003, 07:19 PM   #1
Electrc109
DRIVER
Electrc109's Avatar
Local Time: 11:31 AM
Send a message via AIM to Electrc109
CVT Autocrossing
I will be autocrossing on Sunday, and can't figure if I should use SD mode or the steptronic mode. Which have you found to (or would think) work better?
Old Nov 21st, 2003, 09:21 PM   #2 (permalink)
Sejanus
MINI2 Global Moderator
Sejanus's Avatar
Local Time: 07:31 AM
Why do you have to choose? Shouldn't it depend on what you're trying to do with the car at any specific moment?
United States Male View Sejanus's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Nov 21st, 2003, 09:42 PM   #3 (permalink)
nonsequitur
I think Steptronic gives the most throttle-steering control which is important to rotate the car at corners, but SD allows hands-on-the-wheel concentration that may be a bigger time gain.
I've had trouble in the slalom segments where it is too-tempting to jump on/off the throttle (my poor technique!) at each cone. In SD, the computer tried to follow my demands, getting all messed up. A single Steptronic selection calms this down.
But last time out I used SD and careful right-foot to set and hold rpm, with left-foot braking to control speed and balance. It worked, with respectable times and interest from those gathered around.
I am very interested in what you try, what you like, and what seems to work best!
Simple, with the right line, is almost always better.
'02 MINI Cooper CVT(6/12/02; Indi Blue/Black, R-81 7-hole 15x5.5" or NZO 16x6.5")
'67 Austin Cooper S (6/26/67; Tartan Red/Black, 10x4.5")
United States View nonsequitur's Indi Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Nov 21st, 2003, 09:46 PM   #4 (permalink)
punkeyfunky
UberGeek
punkeyfunky's Avatar
Local Time: 03:31 PM
Send a message via AIM to punkeyfunky
Not if you've got paddles on the steering wheel like me... better control and hands on the wheel at all times...
Lee
Old Nov 21st, 2003, 11:37 PM   #5 (permalink)
nonsequitur
Oops! You're right!
Now that introduces a whole new thread ... driving technique with the paddle shifters. Actually, the paddles may change how one should approach these situations; your hands are on the wheel all the time but there may be positions (like hard over in a tight turn) where it's difficult to execute, etc.
Old Nov 21st, 2003, 11:39 PM   #6 (permalink)
Electrc109
DRIVER
Electrc109's Avatar
I think I might be doing a combination of both modes.
In SD mode, I presume there could be a problem with getting the revs back up after a hairpin turn. Using engine braking with Steptronic, I guess I could remain in steptronic when I begin to accelerate, then shift back into SD mode.
This could get complicated. If I have enough runs, I'll try a little bit of everything.
My plan as of right now:
1st run: SD mode the entire time at 70% aggressiveness
2nd run: Steptronic mode the entire time at 90% aggressiveness
3rd run: SD and Steptronic at 90% aggressiveness
4th run: SD and/or Steptronic mode (whichever was most effective) with fully aggressive driving (note this inlcudes left foot braking and using the e-brake)
5th run: fully aggressive with SD and/or Steptronic
I wish I had a video camera.....
Old Nov 21st, 2003, 11:56 PM   #7 (permalink)
nonsequitur
Can't argue with your plan except to note that the biggest improvements typically occur with the driver's experience and skill, not the car. I've seen good drivers take an embarrassing car through at times quicker than a tricked-out whatever.
Keeping the run plan simple will allow you to see what happens, for you, and for the car.
A big variable is the course. My last one (with the MINI) was "open" corners, call it a slow road course -- everything flowed easily. The MINI "worked" so well. The event before that was "tight" with two slow sections of coned slalom that didn't flow smoothly, taxed my patience, and thus hurt my times (shame on me because this is a controllable attitude).
Have fun, and good luck!
Old Nov 22nd, 2003, 12:05 AM   #8 (permalink)
Electrc109
DRIVER
Electrc109's Avatar
this track is a tight course (autocross set up on an airport runway). max speed will be maybe 40 mph. I will draw out the track beforehand to study it, and will probably only take one run to fully memorize the course.
Old Nov 22nd, 2003, 01:16 AM   #9 (permalink)
nonsequitur
Advice to me from a guy who was wickedly fast in a Volkswagen Golf, and his buddy who drove a Z-06 to fastest time in that class, was "Walk The Course Early" with someone who knows or set it up, then walk the line (positioned where your eyes will be in the car) again, and then maybe do again! I'll be interested in your report. The MINI turns so well, and it looks good on-course.
Old Nov 22nd, 2003, 01:23 AM   #10 (permalink)
Electrc109
DRIVER
Electrc109's Avatar
Oops! You're right!
With your hands exacly at 9 and 3, there is enough steering available for most turns in asphalt racing without letting go of the wheel.
Old Nov 22nd, 2003, 08:58 AM   #11 (permalink)
punkeyfunky
UberGeek
Oops! You're right!
Well, with one hand (other arm is paralysed) I can manage in almost all road situations and regularly use the paddles/manual mode for playing; so those with two hands should be able to manage everything, right?
Lee
Best set up for autocrossing? Chilipeppa03 Wheels, Tyres & Brakes 5 Apr 5th, 2005 12:10 AM
Autocrossing in SJ Johnny225 Northern California Region 3 Jul 9th, 2004 05:57 AM
first autocrossing attempt...videos. districtofc MINI in Motorsport 28 Feb 29th, 2004 04:19 AM
Autocrossing @ Orchard Beach vdubdoug MINI in Motorsport 5 Dec 9th, 2003 09:58 PM
What class will you be autocrossing in in 2003? gowest MINI in Motorsport 14 Apr 12th, 2003 01:59 AM
