Old Jun 2nd, 2004, 10:06 PM   #1
sleslie
Local Time: 07:10 PM
New chick CVT owner...
I have about 1100 miles on my 2004 MC-CVT. I am afraid to use the anything other that the basic "Drive" position. Can I screw the transmission up whilst learning the other positions?
I will need to print the step by step instructions from other drivers because I have no understanding of engines and RPM's and how it all works. It probably seems easy to most of you. I am visual and I'd learn better by watching someone shift, but I have no one around with a car like mine. I am 100 miles from my dealer, also.
I have visions of jamming up the transmission.
Old Jun 2nd, 2004, 10:46 PM   #2 (permalink)
mignon
mignon's Avatar
Local Time: 05:10 AM
Send a message via Skype™ to mignon
Apple Cooper
hi sleslie,
i am a 'chick cvt owner' and like you was nervous about using anything but the drive selection. i checked out the instruction manual (told you i am a shiela) and have been happily shifting from drive to manual selection. you can start off in manual mode or can shift from drive across as you are driving along. the gears won't change to an inappropriate selection even if you do happen to choose the wrong one. it is extremely user-friendly. am sure that others will give you more advice regarding performance driving techniques and the cvt.
enjoy!
Australia Female View mignon's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 3rd, 2004, 02:02 AM   #3 (permalink)
Paul!
Ride The Dragon!
Paul!'s Avatar
Local Time: 03:10 PM
Send a message via AIM to Paul!
As soon as you get past the break-in (1250 mi.), just put it into SD and steptronic modes and have fun. The computer is programmed to not let you do anything too horrible to the car (and believe me, I find this out about every day! ). The computer will just put you into a sensible gear, or won't let you shift in the first place.
And don't be afraid to let the revs go up to around 5500 - 5900. That's when things start getting fun! To start out, my suggestion is to find a big, empty parking lot and to start playing and 'see what in can do'. After a bit, you'll get the feel for the car. Once you have that, start on some back roads with a few light twists and turns, and go from there.
Have fun!
-Paul!
United States Male View Paul!'s British Racing Green & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 3rd, 2004, 11:23 AM   #4 (permalink)
punkeyfunky
UberGeek
punkeyfunky's Avatar
Send a message via AIM to punkeyfunky
Hello...
First things first - get the break in period done with (1250 miles).
Next - one of the truly great things about the CVT is that its computer controlled, and even if you try to break it, the computer won't let you.
Flick the stick across and play with SD mode. It works the same way as D, that is, ratios are selected for you, but it's rather more aggressive - you can rev the engine harder, and the car will certainly move more quickly! You'll notice that SD will rev the engine harder, and thats 'cos most of the power is above 4000rpm.
Then have a go with 'manual' or 'tiptronic' mode. Get into SD first, and then push the stick forwards or backwards. That'll change the ratio's between the 6 pseudo gears (look at the speedo display to see which one you are in). Because the CVT is computer controlled, it won't let you select a gear that won't work. So, when stationary, you can only choose 1 or 2. On the flipside, if you are in 6, on the freeway, and try to change down to 1, it won't let you (it'll only go as far as it knows the engine can take). The tiptronic mode is great when you want to select a particular ratio, and be in the power (e.g. for overtaking)
when you are finished in SD or tiptronic, push back across to D, and cruise home
There's not really much more to it than that - go play, and discover the funzone at 4000+ rpm
-Lee
Old Jun 7th, 2004, 06:22 PM   #5 (permalink)
valnmike
valnmike's Avatar
sleslie, Welcome to the ranks of the MC CVT owners. When you do get 'round to "shifting" the CVT, you do not have to lift off the gas pedal "between gears" like you would with a regular stick-shift. Just keep your foot on the gas and flick the shift lever back to up-shift. Nothing to it once you've had a go at it. There is a whole bunch of information in the thread "Cooper CVT driving technique" which is usually the second thread from the top in the CVT Forum here on MINI2. Best wishes and happy motoring.
-=Mike=- laissez les bons temps rouler
United States Male View valnmike's Chili Red & Black 1st Gen MINI Cooper Profile   Reply With Quote
New Cooper CVT owner Drewuk CVT & Automatic 4 May 24th, 2007 02:29 AM
New Cooper CVT owner Drewuk MINI Cooper 2 May 22nd, 2007 02:06 PM
Another US CVT MINI Owner tsipple CVT & Automatic 20 Oct 17th, 2005 02:04 AM
Any Mini Cooper CVT owner here? mcse2k_i Rest of the World 8 Nov 25th, 2004 03:33 AM
Is there any MINI2 member (CVT owner) who live in Atlanta, GA ? tog255 South-East Region 6 Sep 10th, 2004 04:44 PM
