| MINI2 Regular Join Date: Mar 2004 Local Time: 08:20 AM
Offline | CVT Oil Drain Procedure Question Based on the description of the CVT Oil Drain and Refill procedure in the zf_vt1f_gearbox_description.pdf document ("A refill of the transmission oil is necessary every 45,000 km. For this purpose, the gearbox is equipped with an oil drain plug and a top filler plug."), is the process of refilling the CVT Oil as simple as draining and then refilling? Or conversely, is there no need to replace the transmission oil using a special pumping unit such as is done with traditional automatic transmissions? |
| oil cooler-Does it drain when when having oil change? | yorobby | MINI Cooper S | 4 | Sep 29th, 2004 12:00 AM |
| oil drain plug size | sheaa | Engine & Drivetrain Tuning | 2 | May 12th, 2004 02:02 PM |
| Oil drain valve | zgokart | Maintenance & MINI Care | 12 | Jul 30th, 2003 05:05 AM |
| Oil Drain Plug | Tremoral | Maintenance & MINI Care | 0 | Mar 11th, 2003 02:37 AM |
| First oil change> Do I have to drain oil cooler ? | yorobby | Maintenance & MINI Care | 3 | Sep 26th, 2002 07:44 PM |
