Old Oct 6th, 2005, 02:58 PM   #1
GTT 280
The Power Cube
GTT 280's Avatar
Local Time: 09:23 PM
United-Kingdom Torque / BHP / Performance
Hi all.
I have an issue here.
I have a JCW with flow manifold etc.coming in at 220bhp (approx).
My mate has a Seat Ibiza 1.8T chipped, coming in at about 215 bhp.
His toque is 242lb, mine is 188lbs.
We are both as fast on the road. but he says that's coz his is 'broken' and when it is fixed will be noticeably faster.
So, what's the crack - do i need to get the 270bhp mod from GTT (what is the torque for that by the way) - or do i need to get a new car ???
all advice required !!! I am fighting the corner of the MINI here...
Old Oct 6th, 2005, 03:22 PM   #2 (permalink)
brady
that vag 1.8t engine has always been known to produce a lot of torque, particularly when they have been tuned, would be very difficult to match in terms of torque, but id have thought your mini would still be quicker ?? not sure about the torque figures for gtt 270 mini but im pretty sure it would blow the ibiza off the road
Ireland View brady's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 6th, 2005, 03:42 PM   #3 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Thanks.
that makes me feel better.
:-D
Old Oct 6th, 2005, 06:00 PM   #4 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
Local Time: 10:23 PM
Quote: Originally Posted by Cooper S Works
Hi all.
just wait for the bends
in all fairness tho I would expect the two to be quite close
Japan Male   Reply With Quote
Old Oct 7th, 2005, 12:49 AM   #5 (permalink)
Paul Webster
Paul Webster's Avatar
torque is what accelerates a vehicle, you will have better acceleration from 1000rpm and up because of supercharger not having any lag.
Though on and out and out drag race you would probably using from 5000 to 7000 so who ever is producing the most torque there and has the better power to weight ratio will win.
It's not how much you spend but how well you spend it
Old Oct 7th, 2005, 06:52 AM   #6 (permalink)
pocketrocketowner
Best Personal Regards
Local Time: 11:23 PM
One needs to remember that the ONLY thing you can measure in an engine is TORQUE. Horsepower is a mathematical calculation based on the torque at a given RPM.
Old gits like me have always heard: "HP sells cars, torque wins motor races"
You need to compare torque values across the RPM range (the torque curve)in order to gauge relative performance, not just the peak torque value, cuz it is only given for a given RPM.
Hope this helps.....
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 7th, 2005, 12:29 PM   #7 (permalink)
bimini
bimini's Avatar
Torque is a big by-product of engine size...so the extra 200cc's will be helping the Seat there. The rest could be down to the turbo perhaps being more torquey than a supercharger because it may provide more torque boost at peak torque than a supercharger which may provide more torque boost further up the rev range where there was less torque to start with...and it could be a lower reving engine, engines which rev lower typically have designs which benefit torque more ...and piston amounts and configuration can also benefit torque production...a straight 6 or V8 will be more torquey than a straight 4 L v L due to the over lap.
Some cars like the mini have engines that are tuned go like spanked angry wasps, some cars have engines that are designed to perform like birds wings...torque is the measurement of how well they could pick up a brick, not how fast they speed through the air without one.
Manufacturers often design somewhere in between, so it can be hard to just say that one car should perform the same just because the CC's are the in the same area and so is their BHP.
The best solution to torque is a bigger engine and/or configuration...v8 m5 mini conversion should do the trick.
I wouldnt worry about it, if your keeping up with him on the road then its probably down to the engine performing better in other areas of the rev range, handling or better driving (that would be one to needle him back with...)
I hope this hasn't been a case of trying to teach grandma...excuse me if it has
United Kingdom View bimini's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 7th, 2005, 07:50 PM   #8 (permalink)
twouptons
What's this button do?
twouptons's Avatar
Local Time: 04:23 PM
This is why in Formula 1, the cars use big honking diesels with lots of torque and very little horsepower, because it makes them go faster oh, wait...
The "high torque" engines also produce a lot of power at those low RPMs (relatively speaking), and you can look at it that way, too, since you can get the power from torque and RPM. Once you have torque and rpm, you can pretty much use torque and power interchangably – as long as you have that rpm number to tell you how fast you're spinning. I can make 1600lb-ft of torque on my MINI with a wrench and a six-foot cheater bar – at something like 15 rpm...but it accelerates much better with its engine
pocketrocketowner is right, the torque values across the RPM range are the most important, but they also have to be taken in kind with gearing and tire/wheel size. You can multiply torque with a transmission or a change in tire diameter, but that may not make you go any faster...
And I can measure power at the wheels with a Cd, frontal area, and speed
-Eric
United States View twouptons's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 7th, 2005, 08:37 PM   #9 (permalink)
supercharged99
clinton steenkamp
supercharged99's Avatar
i had a SEAT IBIZA CUPRA R (180 bhp ) LIMITED EDITION.on a 51 reg.
this car could do 160 mph (yeah spank me if you want ) when i was running my mini '200 bhp,the mini felt quicker.
a guy ran a 280 bhp ibiza at YORK DRAGWAY, and my 260 bhp mini did better runs than him.
those cars will outrun the mini near the top end.
if you're both doing 90 mph the SEAT will probably start pulling away.
yeeeeeehaaaaaaa
DAMN THIS THING IS QUICK
Old Oct 7th, 2005, 11:02 PM   #10 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
all down to the mini's lovely aerodynamics
brick comes to mind
Old Oct 9th, 2005, 12:08 AM   #11 (permalink)
Idontbrakeforcorners
Idontbrakeforcorners's Avatar
physics
in respons to being able to calculate power at the wheels, ill actually giver some calculations
the get the drag force
Fd=.5(DPA)V^2
D= drag coefficiant
P= row density of object your traveling through (air)= 1.29
A= cross-sectional area
V=velocity
P=FV
p=power
f=force
v=velocity
power is measured in watts and 746watts=1HP
THis is assuming that there is no friction (i know )
But hey, assuming your in a vacuum, thats the HP of your car!
Old Oct 9th, 2005, 12:30 PM   #12 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
Fd=.5(DPA)V^2
D= drag coefficiant
V=velocity
P=FV
p=power
f=force
v=velocity
so whats all that lot prove??
Old Oct 10th, 2005, 03:29 AM   #13 (permalink)
pocketrocketowner
That it is REALLY silly to get hung up on HP numbers......as performance is based on a shot load of other factors.......
Old Oct 10th, 2005, 04:19 PM   #14 (permalink)
twouptons
twouptons's Avatar
Bwa ha ha ha ha! Too Right!
-Eric
Old Oct 14th, 2005, 12:48 PM   #15 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
United-Kingdom
Do you have a 260 bhp MCS??? - is it GTT? what mods have you had done?
Old Oct 15th, 2005, 11:54 AM   #16 (permalink)
supercharged99
clinton steenkamp
yep...
running pretty much everything ( head / cam / 63mm TOB / GRS intercooler / 17% pulley / 1 % crank pulley / GTT manifold / milltek cat back / typhoon intake .
yeeeeeehaaaaaaa
Old Oct 21st, 2005, 02:41 PM   #17 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
I useto drive an Astra GSI Turbo with 274lbft which was fast....but add the weight of the car, 5 speed box and turbo lag a BBR220 would just get away on the road. But on the drag strip we we're almost the same.
But who cares about drag strips?? I dont, I prefer the car to be fast pickup and acceleration while moving. I guess I better get saving : http://www.bbrgti.com/minit.php
Old Oct 21st, 2005, 06:08 PM   #18 (permalink)
badboyzbadboyz
MINI2 Jedi Master
badboyzbadboyz's Avatar
... do i need to get the 270bhp mod from GTT - or do i need to get a new car ???
I would hate to think what you would do if your mate got himself a Ferrari
England   Reply With Quote
torque vs bhp? Jay.B General Discussion 25 Aug 25th, 2005 05:20 PM
More important - torque or bhp? Pauly General Discussion 4 Apr 9th, 2004 08:31 PM
How can we get more Torque,not bhp???? dave22 Engine & Drivetrain Tuning 3 Sep 29th, 2003 11:14 PM
BHP and Torque ButtonIt Engine & Drivetrain Tuning 5 Sep 9th, 2003 05:23 PM
BHP/Torque Modifications GTT 280 Engine & Drivetrain Tuning 2 Jun 12th, 2003 08:41 PM
