Performance Torque
Old Oct 12th, 2005, 01:57 PM   #1
venox22
only the brave!
venox22's Avatar
Local Time: 10:20 PM
Send a message via AIM to venox22 Send a message via MSN to venox22
Supercharger Fitting?
How long does it take to change the supercharger?? hard or easy to do??
United Kingdom Male View venox22's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 12th, 2005, 02:23 PM   #2 (permalink)
XTREEM
XTREEM's Avatar
Local Time: 08:20 AM
Well that depends on your mechanical prowess???? its not rocket science but not a 1 hour job either. You have to be prepared for your car to look like this.
Australia   Reply With Quote
Old Oct 12th, 2005, 05:46 PM   #3 (permalink)
supercoopers
supercoopers's Avatar
Local Time: 09:20 PM
It's a 4- 5 hour job if you have done it before and you are confident with working in small spaces, and can be done without the level of disassembly shown Xtreem's picture...
To get the supercharger off without removing the entire front of the car is possible. I would drain the coolant out as well and remove the supercharger with the water pump as a unit so that you can reattach them properly with both parts off of the car.
The only other 'fiddly' bit is getting the intake manifold off on my car because the studs on the head are slightly too long and catch on the output intercooler snoot. Other than that, it's easy. Just be careful not to introduce anything into the intake path i.e. bits of grit etc when putting the supercharger back on, otherwise you will end up with a rather expensive paperweight!
Hope that helps.
Henry
Old Oct 13th, 2005, 07:50 PM   #4 (permalink)
supercoopers
Quote: Originally Posted by Max
Agree with the above... do not try this at home
Who the hell did the work on that?!
The bloomin alternator looks like it's gonna rip the connectors off of the wires...it wouldn't have been much more extra work to take the alternator off to eliminate potential problems down the line but oh well
Henry
p.s. it's not that scray a job...get yourself a decent tool kit and get cracking
Old Oct 14th, 2005, 08:55 AM   #5 (permalink)
venox22
only the brave!
venox22's Avatar
Thanks, am quite a competeant mechanic, have a HND Motorsport Technology, but am a bit of a fairy when comes to dismatleing so much!!!
Old Oct 14th, 2005, 09:05 AM   #6 (permalink)
XTREEM
XTREEM's Avatar
Why it may be possible to do the job with less dis-assembly than mine it would be a bugger of a job, Its well worth making some work space in my opinion. The alternator doesnt need to come off like in Max's photo, you just lossen the bolts and the charger will slip out.
John.
Old Oct 14th, 2005, 03:27 PM   #7 (permalink)
k-huevo
Trailer Trash
Local Time: 04:20 PM
It can be done with the radiator support in the service mode and without draining the radiator; as long as you don't have a problem with hyper-extending the elbows. However, it helps to have experience from doing it once with the front end off. If you take off the water pump at the same time be sure to replace at least the external o-ring. Whichever method you chose to approach this, replace the green rubber/plastic supercharger intake gasket and the metal output gasket. Plan ahead, consolidate maintenance, and torque the idler pulley to spec along with all the other bolts (a loose idler pulley can contribute to poor belt health).
United States Male View k-huevo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Fitting a supercharger to a mini cooper hotlemon Engine & Drivetrain Tuning 9 Jan 23rd, 2006 11:55 PM
supercharger fitting jionty Engine & Drivetrain Tuning 1 Sep 5th, 2005 12:53 AM
Alta Supercharger Pulley FITTING?! mini123 Engine & Drivetrain Tuning 3 Jan 12th, 2005 05:38 PM
Fitting Supercharger to one/cooper-theoretical silver_mini Engine & Drivetrain Tuning 8 Aug 9th, 2004 07:06 AM
Supercharger Belt fitting stu(pid) Engine & Drivetrain Tuning 7 Dec 10th, 2003 12:49 AM
