GizzmoUSA
Closed Thread
Old Oct 16th, 2005, 03:59 PM   #1
Rickys'S
Rickys'S's Avatar
Local Time: 10:24 PM
Talking Check my engine bay-Guess the power!!
Please look at my attached picture
Here is my nearly finished engine, i say nearly as i am waiting for some silicone hose to replace my black catch can hoses!
Spec as follows:-
GTT Top mount Intercooler
GTT Big valve cyl head (stage 3)
GTT 18% pully
M7 Modifyed Charger
GTT idler & twin tensioner pullys
GTT Induction kit
Schrick Cam
GTT Exhaust Header
Milltek cat back
GTT 63mm Throttle Body
Modifyed Bypass Valve,Inlet Manifold & intercooler Snoots
JCW Injectors
2X GTT Oil Catch Cans (1 for each rocker breather)
Samco induction hose & SFS blue coolant Hoses
I think thays it
I say guess the power as it is going in for live mapping with the unichip piggy back ecu tomorrow , no more MTH
England Male
Old Oct 16th, 2005, 04:43 PM   #2 (permalink)
minicabrio
Clubman Convert
minicabrio's Avatar
Local Time: 11:24 PM
Haven't got a clue.............238bhp????
Thats my guess!!
United Kingdom Visit my Blog at the Motorcade Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
Old Oct 16th, 2005, 04:49 PM   #3 (permalink)
Rickys'S
Rickys'S's Avatar
Thats my guess!!
I hope not looking for 250+ will sell it if it only goes 238 ......well maybe not!
England Male
Old Oct 16th, 2005, 04:52 PM   #4 (permalink)
minicabrio
Clubman Convert
minicabrio's Avatar
I'd be happy with 238bhp.......
waiting with interest........
Old Oct 16th, 2005, 05:42 PM   #5 (permalink)
supercharged99
clinton steenkamp
supercharged99's Avatar
why did you not like the MTH map ?
yeeeeeehaaaaaaa
DAMN THIS THING IS QUICK
Old Oct 16th, 2005, 06:24 PM   #6 (permalink)
Hyper Active
Hyper Active's Avatar
My guess is 273bhp exactly, or there abouts .
England Male View Hyper Active's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile
Old Oct 16th, 2005, 07:24 PM   #7 (permalink)
Berthil
Berthil's Avatar
Local Time: 12:24 AM
I'm wondering too. I had Digi-Tec tuning and the MTH map even got me more power with the same hardware (I got the Milltek catback too). Next weekend I'm getting the MTH header with optimized tuner file and I expect some hp from it. It should get me to 240, yours is probably about 250.
EB/W R53 MCS Highly Modified
Netherlands Male View Berthil's Electric Blue & White 1st Gen MINI Cooper S Profile
Old Oct 16th, 2005, 09:04 PM   #8 (permalink)
Rickys'S
Rickys'S's Avatar
Lets start with the pros, MTH is very good and is relativly cheap as far as mapping goes,in my car with mild mods everything was fine and i was very happy indeed and would still be using MTH if i thought that there was'nt something availible that is better! But that is the point there is the dastek unichip which is a piggyback ecu that is live mapped to your car on the rollers to the spec i want and safely.
My point is that there is no way a guy a 1000 miles away can tell exactly what a engine is going at a given time, as no 2 engines are the same.
This has always been in my mind since i began on the tuning route, i wanted a safe live mapping process with a piggyback ecu that i could control with the operator that is doing the mapping work.
England Male
Old Oct 16th, 2005, 09:13 PM   #9 (permalink)
Loui
230whp an counting
Loui's Avatar
sounds interesting totally true about the a guy miles away knowing what an engine is doing, interesting to see what the new map does to it
England Male View Loui's Solid Black & Body Color 1st Gen MINI Cooper S Profile
Old Oct 16th, 2005, 09:56 PM   #10 (permalink)
Berthil
Berthil's Avatar
That's why MTH requires your current software if you want a tuner file or the tuner file for the header (not the standard MTH file). The download of your software has te be send to MTH so they can see from the file how your engine is performing, and can make changes according to the readings in your current software. That's why the ecu has to be reset after uploading the new motormanagement, to reset the stored readings acquired with your previous software. So a thousand miles away is not accurate since you are sending your performance readings to MTH.
Old Oct 16th, 2005, 09:58 PM   #11 (permalink)
Loui
230whp an counting
Loui's Avatar
Id still rather it be done live, on a set of rollers, maybe im a bit old fashioned in that respect
Old Oct 16th, 2005, 11:39 PM   #12 (permalink)
notts04chillimini
hey lightbulb head....
notts04chillimini's Avatar
Send a message via MSN to notts04chillimini
England
i run my car with mth tuner file, but yes if i was to go all out on the tuning then id want it to be mapped in front of me on the rollers
England View notts04chillimini's Chili Red & White 1st Gen MINI Cooper Profile
Old Oct 17th, 2005, 02:49 AM   #13 (permalink)
minigolf
Blue is the colour!
minigolf's Avatar
Local Time: 08:24 AM
89hp.
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile
Old Oct 17th, 2005, 05:18 PM   #14 (permalink)
1320autos
1320autos's Avatar
Online
Just to add my 2 cents but how does live mapping on rollers be any better than someone doing it a 1000 miles away;
How do the rollers generate the g force when you are accelerating??
How do the rollers generate a wind from 5mph to 140mph??
Rollers and engine dynos are good for setting up or trying something to see the difference but don't believe the figures until you can test it in the real world i.e dragstrip, then whatever your mph is, represents your geniune bhp.
Also peak numbers doesn't propel your car quicker, how long do you spend at 6900??
IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT
Old Oct 18th, 2005, 04:09 PM   #15 (permalink)
Loui
230whp an counting
Loui's Avatar
Thats a fair comment because you can never recreate the airflow at speed, an you do get slip on the rollers
Old Oct 18th, 2005, 04:42 PM   #16 (permalink)
Il Generale
Il Generale's Avatar
how many hp have you reach with the mth tuner file?
thanks
Italy
Old Oct 18th, 2005, 05:27 PM   #17 (permalink)
Revolution Mini Works
Mini2 Sponsor & Tuner
Local Time: 03:24 PM
I would say a "true" hp for that car would be about 205 WHEEL hp.... let's please stop with the BHP guestimations.... it's silly
Old Oct 18th, 2005, 06:07 PM   #18 (permalink)
SiBradbury
"I'm kind of a big deal"
SiBradbury's Avatar
Where do Bmw get the Cooper S horse power quote from? Engine or wheels?
Old Oct 18th, 2005, 06:16 PM   #19 (permalink)
from an engine dyno which 99.9% of the poplulation doesn't have... so why guess at something when you can read the whp on the dyno's that we have? It only matters what is at the wheels anyway... I guess it's comes down to people liking to believe they have more HP than they really do....
Old Oct 18th, 2005, 06:21 PM   #20 (permalink)
SiBradbury
SiBradbury's Avatar
Surely if its not that silly then is it?
I mean if you want to make a comparison between standard power and post-modification power then it makes perfect sense to quote crank bhp if thats the base to work from.
Closed Thread
Engine bay on Fire!! n944 Faults & Fixes 11 Feb 13th, 2007 02:14 AM
Engine bay temperature? -=cHiLli=- Engine & Drivetrain Tuning 4 Aug 15th, 2006 02:02 PM
Running power cable thru into engine bay! Neil's Missus Interior & Ice 21 Sep 16th, 2002 10:51 AM
