Visit Lohen!
Old Oct 21st, 2005, 08:34 PM   #1
FunkyJMan
MINI Mover
FunkyJMan's Avatar
Local Time: 10:27 PM
Send a message via MSN to FunkyJMan Send a message via Skype™ to FunkyJMan
MTH Help
Hi All,
I have MTH on my car and it's been running ok but I am selling the car and have tried to transfer the standard map back on however the standard file transfered half way accross then it came up program error and the car will not start even after an ECU reset and it has blocked the dealer diagnostics out also. Everytime I try and upload it fails halfway through, has anybody else had this problem and managed to resolve it? Otherwise looks like I will have to buy a new ECU
If anybody has any advice that would be great.
Jamie
England Male View FunkyJMan's Pepper White & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 21st, 2005, 09:31 PM   #2 (permalink)
M111 CGC
Mini Madness
M111 CGC's Avatar
Local Time: 09:27 PM
Send a message via MSN to M111 CGC
I would re-read the main MTH thread with regard to laptop software interruptions if I were you - I think other people have experienced issues with background software, even image files causing the ECU map upload to fail.
http://www.mini2.com/forum/showthrea...t=97748&page=3
2007 Clubman Cooper D ~ 2004 Cooper S JCW
United Kingdom Male View M111 CGC's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 22nd, 2005, 08:44 AM   #3 (permalink)
Rickys'S
Rickys'S's Avatar
Jamie, my laptop did this alot, you need to make sure there is nothing running except for cartune.
stick with it mate it will work.
Old Oct 22nd, 2005, 08:51 AM   #4 (permalink)
FunkyJMan
MINI Mover
FunkyJMan's Avatar
Ok thanks for the help, Im going back down today to try again I will make sure nothing is running.
Jamie
Old Oct 22nd, 2005, 12:06 PM   #5 (permalink)
Profpatpending
Forum Hardened
Profpatpending's Avatar
make sure the screen saver is turned off,
all email programmes and disable all network connections.
the slightest interuption will cause it to fail,
so make sure your laptop is dedicated to only run cartune while you are uploading.
Old Oct 22nd, 2005, 01:49 PM   #6 (permalink)
FunkyJMan
MINI Mover
FunkyJMan's Avatar
Got it going now thanks, made sure nothing else was running and worked first time today thank god
Thanks for all the help.
Jamie
Old Oct 22nd, 2005, 02:14 PM   #7 (permalink)
jon vital
jon vital's Avatar
I read a lot of these threads that say similar things. Why don't MTH make the software more bullet proof or put a dialog box that tells you to close all other programs/services before starting?
Old Oct 22nd, 2005, 03:37 PM   #8 (permalink)
MiniDSW2005
Local Time: 05:27 PM
I would suggest to do the file transfer though safe mode or...
Go to Start, Run, enter MSCONFIG within the run window to bring up the sys utility tools. Go to Startup tab, turn off all the startup items... Restart the computer.
Once you have your Windows screen comes back, run Cartune (bring up the program only), go to Task Manager, Process tab, you will then see a file names "Cartune.exe", right click on it, priority, chnage to High, close task manager. Now run the Cartune process again.... Make sure you do not touch anything while the file transfer (for example, light on/off, door open/close and etc...). You can leave your car and wait for 4~5 minutes, then come back. If you see the screen looks like it is freezing, you can left click on the Cartune, it will then come back with the progress bar... Or it may gives you the message "Transfer Complete".
Good luck, there is no need to purchase a new ECU, it should still runs fine.
Happy motoring!
Canada   Reply With Quote
Old Oct 24th, 2005, 01:53 AM   #9 (permalink)
sa3dos
Black Cat Owner
sa3dos's Avatar
Send a message via MSN to sa3dos
This problem had happened to a friend of mine as we were uploading the MTH file,
after so many trials, we noticed that it is extremly important to not move any thing in the car as the Upload is in progress.
Suggestion, as soon as you hit Upload in CarTune, make no movement whatsoever to the laptop or the cable connected.
If it fails, then its an error in the computer you are using, try performing what they have suggested above.
DONT PANIC, flashing the ECU will always work without the need to contact your dealership or whatever.
Canada Male View sa3dos's Solid Black & White 1st Gen MINI Cooper Profile   Reply With Quote
MTH Standard v MTH Tuning mini.marvel MINI One 4 Sep 22nd, 2006 11:22 AM
Changes at MTH??? venox22 Engine & Drivetrain Tuning 25 Jun 29th, 2006 05:18 AM
