| MINI2 Regular Join Date: Jul 2005 Location: Auckland Local Time: 10:26 AM
Offline | Problem with outside temperature indicator Perhaps someone might be able to identify a problem I have. When I turn on the ignition (before starting up) there is a beep noise and the outside temperature gauge flashes off and on. Then the flashing stops and the outside temperature reads minus 40 degrees C and stays on that - even with the car moving. Obviously it is not that temperature outside the car and there must be a malfunction somewhere. Do I need to remove the bumper to check the sensor behind the grille, or is there some sort of reset procedure? The car is about a month out of warranty. Any help would be appreciated thnks |
| Waiting (im)patiently... Join Date: Jun 2005 Location: Stittsville, Ontario Local Time: 04:26 PM
Offline | The problem is clearly that the temp is not being read right. The rest of the behaviour (the beep, the flashing of the reading, etc) is correct for what the readout is (-40) - it's just that the temperature being reported is clearly *way* off. I would suspect that the lead itself is either damaged or disconnected, causing the unit to read -40c (presumably the lowest number that the guage allows). I've got *no clue* how to go about proving / fixing it though... good luck! |
| Temperature Problem Please Help | al5774 | Faults & Fixes | 13 | May 29th, 2007 12:17 PM |
| Fuel indicator problem. | Azure | Faults & Fixes | 1 | Oct 25th, 2006 06:58 PM |
| Outside Air Temperature Indicator | erazo | Faults & Fixes | 3 | Sep 11th, 2005 10:20 AM |
| High Outside Air Temperature problem? | m1les | Faults & Fixes | 7 | Aug 22nd, 2003 09:28 PM |
| hard to start problem temperature sensitive? | GordonD | Maintenance & MINI Care | 1 | Oct 9th, 2002 09:08 AM |
