Old Dec 8th, 2005, 11:07 PM   #21
XTREEM
XTREEM's Avatar
Local Time: 08:26 AM
And make sure you still have the stop screw doing its job of taking the weight, or the butterfly will binde and stick in the throat.
Australia   Reply With Quote
Old Dec 8th, 2005, 11:08 PM   #22 (permalink)
Blue_aerox
Blue_aerox's Avatar
Local Time: 11:26 PM
Something which isnt completely clear to me:
is this only possible on Sīs or can I do it on my One as well?
Proud owner of a new 2005 BRG Mini One
Not to mention the 128BHP chiptuning
Netherlands View Blue_aerox's British Racing Green & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Dec 8th, 2005, 11:48 PM   #23 (permalink)
XTREEM
XTREEM's Avatar
Only S
Old Dec 9th, 2005, 12:07 AM   #24 (permalink)
THE ITCH
Local Time: 05:26 PM
Thanks for your help in this matter John. One other question, both my repair manuals suggest that the O-ring on the throttle body should be replaced after removal. In your experience is that necessary?
Old Dec 9th, 2005, 02:01 AM   #25 (permalink)
Bootsy
Quote: Originally Posted by Loui
From what ive been told it seems they have been using something like thread lock to stop these things being tampered with
No, I think it is more likely it has thread lock to keep the adjustment from slipping once set. It's a good idea even if you adjust it yourself.
United States Male View Bootsy's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 9th, 2005, 02:42 AM   #26 (permalink)
MiniFr34k
fr34king n00b!
MiniFr34k's Avatar
Local Time: 07:26 AM
question: if u do this and 'fix' ur bpv, things like the VGS and Rhyephix valve - are they necessary??
Old Dec 9th, 2005, 06:00 AM   #27 (permalink)
XTREEM
XTREEM's Avatar
Just take care when removing and all will be fine, put a little oil on the O ring on re-assembly, its a good solid O ring not a flimsy thin thing. I have had mine on and off several times with no leaks.
Pete, I would still do the VGS
John.
Old Dec 13th, 2005, 01:06 AM   #28 (permalink)
MiniFr34k
fr34king n00b!
MiniFr34k's Avatar
lol ok john you've convinced me..
but have u got a pic of the tubing u use for the vgs?? im still unsure on that tubing your'e meant to use
Old Feb 3rd, 2006, 01:09 PM   #29 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Send a message via MSN to St00ge
VGS is not the same thing. The VGS controls the opening/closing of the Bypass valve, where as the Bypass Valve Recalibration makes sure the Bypass valve is sealed properly, i.e. doing its actual job, rather than leaking boost. Why compress air only to lose it in a crappy BV.
By the way, wats the PCV in PCV hose stand for John?
Old Feb 3rd, 2006, 01:45 PM   #30 (permalink)
62Lincoln
Local Time: 04:26 PM
Positive Crankcase Ventilation
Old Feb 3rd, 2006, 01:59 PM   #31 (permalink)
St00ge
St00ge's Avatar
oh ok, so am i right in thinking its that hose that clamps into the intake/throttle body hose?
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old Feb 5th, 2006, 05:42 PM   #32 (permalink)
parsey83
The Stig (2)
parsey83's Avatar
Local Time: 09:26 PM
I have trie to get at this valve but having a bit of trouble and would like some further verbal instructions if anyone is kind enough to give them, i can get the throttle body off ok with all hoses etc disconnected, i then found the valve and took out the two 10mm srews that run from bottom to top, i can see the hosing with the two circlips on there but i cant get any movement out of the valve as there just seems to be no space to move things, am i missing something?
Any help would be great and even some more pics
Northern Ireland Male   Reply With Quote
Old Feb 15th, 2006, 10:36 PM   #33 (permalink)
MiniFr34k
fr34king n00b!
MiniFr34k's Avatar
Ok - with the VGS ive been there and done that.
Without looking at the BPV, iam convinced the thing is misaligned and going to attempt a 'fix' - any tips from u folks b4 i do this?
Something about using bolts for ic horns and somethign about having some hose clamps ready?
Old Feb 16th, 2006, 09:58 PM   #34 (permalink)
MiniFr34k
fr34king n00b!
MiniFr34k's Avatar
Interesting news.
The MCS i bought is 2nd hand.
When taking a look at the BPV and how its connected to the I/C horn i noticed there was a SCREW HOSE CLAMP!!! like the ones that come with the Alta CAI- not like those other funny hose clamps that comes with minis (once they're off , they're off). So to me it seems like the previous owner had a go at fixing this bpv.. not sure. It will be interesting to see when i open this thing up.
modified bypass valve Jaw_F430 Engine & Drivetrain Tuning 4 Sep 15th, 2007 09:28 PM
Bypass valve seems to be leaking????? Loui Engine & Drivetrain Tuning 0 May 28th, 2007 10:26 PM
optimised bypass valve miniwurks MINI Cooper S 8 Feb 15th, 2007 10:04 AM
Bypass valve removal Scoobystu Engine & Drivetrain Tuning 9 May 25th, 2006 01:56 PM
Ryephix bypass valve? agile_moments Engine & Drivetrain Tuning 6 Aug 22nd, 2005 03:15 AM
