GizzmoUSA
Old Dec 8th, 2005, 05:48 PM   #1
alexg222
Local Time: 09:27 PM
Dealer says putting new Engine, How Can I tell?
Hello everyone,
So...My dealer screwed up on an oil change. They forgot to screw some cap in properly, and as a result, all my oil leaked out and my engine burned out.
Since it's their fault everything is covered, BUT I am a lilttle worried they might want to screw around and put in a refurbished engine.
I've let them know I want a brand new engine and they SWEAR that when they replace an engine they always put in a new one (he called it remans or something like that).
My question is...how will I be able to tell that it is indeed a new engine? Anyone had this problem before?
Let me know!!!
Thanks,
Worried as hell that my MINI will never be the same again
Old Dec 8th, 2005, 05:57 PM   #2 (permalink)
MartinSSZ
Yellow and Proud
MartinSSZ's Avatar
Send a message via MSN to MartinSSZ Send a message via Skype™ to MartinSSZ
"Remans" probably means remanufactured, which is essentially a rebuilt/refurbished engine, not a brand new one
United Kingdom Male View MartinSSZ's Liquid Yellow & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 8th, 2005, 06:59 PM   #3 (permalink)
Jaffa Racer
Jaffa Racer's Avatar
Send a message via MSN to Jaffa Racer
As Max says double check the engine number if its the same they repaired yours, if its different then its a new or recon engine, then your in to part numbers check what the service dept has n their system then check it in the parts dept.
Old Dec 8th, 2005, 07:58 PM   #4 (permalink)
alexg222
Is a recon engine bad?
All my friends keep saying that when a recon engine is put in their cars have "not been the same" (whatever that means...)
Old Dec 8th, 2005, 08:37 PM   #5 (permalink)
Jaffa Racer
recon from BMW aint gonna be bad, maybe a bad fitter LOL
Old Dec 8th, 2005, 11:38 PM   #6 (permalink)
Lohen
New Mini Specialists
Lohen's Avatar
Send a message via Skype™ to Lohen
We have had to rebuild and engine from parts of two different engines before, its is not a cheap job as there is a lot of work, and new engine parts required.
My concern is that the engine is probably quite screwed up inside if all the oil leaked out, as it would have been running dry which would have scored the bore. The cost of polishing/boring it out would be quite a lot as they would have to completely strip the engine so i assume that it will brand new. Also there aren't that many mini engines around for them to use a reconditioned one.
Why dont you ask the dealer "How do i know that it is new?" and see what they say.\
Andrey
Click Here To Visit Out Website
New MINI Specialists
www.lohen.co.uk
Old Dec 8th, 2005, 11:41 PM   #7 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 01:27 PM
Online
Another important question to ask ...
What is the warranty on the replacement engine?
Old Dec 9th, 2005, 11:19 AM   #8 (permalink)
robbo mcs
Track Addict
robbo mcs's Avatar
Local Time: 08:27 AM
Hi,
A "remanufactured" engine is standard procedure for a warranty engine replacement from BMW.
What happens is that a "blown engine" goes back to BMW. They throw everything away, apart from the engine block. This is checked to makesure that there is no structural damage. The engine is then rebuilt with all new parts, pistons, head, etc etc etc. This is built under strict factory conditions, eg controlled conditions to ensure no contamination of components with dust etc.
By law they are not allowed to use these engines for new cars, but are allowed to use them for warranty replacements.
They will not rebuild the engine from your block. You will get an engine that has been rebuilt some time ago, at the factory.
This is as good as a new engine, and it is way better than having an engine rebuilt in a dealership or workshop. In fact, there are some theoretical advantages from having a block that has allready been heat cycled and "seasoned" etc. Some of the BMW factory racecars from the 70's and 80's were purposely built from blocks of customers street cars that had been returned to the factory, because of some perceived engineering advantage. I have lost the link, but there was an interesting thread on this on the roadfly forums some years ago
However, as Lohen points out, I can't imagine there are too many returned mini engine blocks sitting around at the factory, so it is possible you may get a completely new one.
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 9th, 2005, 11:54 AM   #9 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
I think youll find you WILL get a brand new engine,so dont worry.
Regards Roland GT Tuning
Old Dec 9th, 2005, 12:11 PM   #10 (permalink)
OZChris
Interesting enough a couple of years ago, my wife's new Suzuki Grand Vitara had an engine failure at 5 weeks, and we got the 'a new engine would be put in' story. On further investigation, Suzuki can order replacement engines without engine numbers, so that the original engine number can be stamped in. In the end, I negotiated a new replacement rather than the replacement engine.
Just my 2 cents.
Old Dec 9th, 2005, 08:47 PM   #11 (permalink)
Paul Webster
Paul Webster's Avatar
Quote: Originally Posted by Max
Plus where would they get a second hand engine from?
I've got 6
It's not how much you spend but how well you spend it
Old Dec 10th, 2005, 12:25 PM   #12 (permalink)
Lohen
Lohen's Avatar
Robbo
I think you are referring to the era when they built their turbo formula one engines from blocks that have been weathered. Weathering normally involved things like leaving the block out in the rain outside and p*****g on it and etc. It was the time 1500bhp formula 1 from around 2 litres capacity
Imagine having one of those!!!! it wont last very long but you could go very far in that time.......
Quote: Originally Posted by 1320autos
I've got 6
Why and where from??? An what on earth are you planning to do with them??
Andrey
www.lohen.co.uk
Old Dec 10th, 2005, 01:17 PM   #13 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
Local Time: 10:27 PM
I've got 6
now thats just greedy!!
Japan Male   Reply With Quote
Old Dec 10th, 2005, 03:33 PM   #14 (permalink)
MiniService
Local Time: 05:27 PM
you will get a remanufactured engine, you will not no the differance, it is good as new and half the price
Old Dec 10th, 2005, 04:44 PM   #15 (permalink)
Cooper54
Lightweight
Cooper54's Avatar
I wouldnt except a new engine, I would want a new car with such a mass screw up from mini..
Old Dec 10th, 2005, 07:28 PM   #16 (permalink)
MiniService
Youve gotta be outta your mind to expect a 30,000 dollar car for a 5,000 dollar screw up, and acutlly much less at dealer pricing
Old Dec 10th, 2005, 08:08 PM   #17 (permalink)
Pansmiker
MINI Convertible
It is reasonable to expect the dealer to make good their mistake. It is also reasonable to expect that there is some sort of additional compensation for the inconvenience / hassle. Have you had any luck on this front?
Paul
The speed of the hand deceives the eye and sometimes blackens it!
Old Dec 10th, 2005, 08:22 PM   #18 (permalink)
Paul Webster
Quote: Originally Posted by Lohen
I.Why and where from??? An what on earth are you planning to do with them??Andrey
We recycle new Mini's
Old Dec 10th, 2005, 09:41 PM   #19 (permalink)
MiniService
Paul
Make good their mistake, absolutely no reason in the world they shouldnt, additional compensation, I also agree here to an extent, but to say a whole new car is alittle bit rediculous
Old Dec 11th, 2005, 02:29 PM   #20 (permalink)
Lohen
Lohen's Avatar
In the US? or UK?
Andrey
www.lohen.co.uk
Sudden Engine failing .....sounds like a tractor! Dealer says NO OIL ARotheram Faults & Fixes 36 Jun 15th, 2007 01:49 PM
Help! Mini dealer service says I need new engine cgaimon Faults & Fixes 9 Mar 27th, 2007 09:09 AM
knocking noise when putting foot on acelerator or taking it off.........engine mount Fabio Faults & Fixes 38 Apr 20th, 2006 07:17 PM
anybody putting more than 30,000 mini vanilli General Discussion 16 Mar 18th, 2005 05:18 PM
Putting an 'S' engine in a base Cooper mbroderick Engine & Drivetrain Tuning 11 Nov 1st, 2003 09:21 AM
